Question about Acer Aspire 6920 Notebook PC
No power wont charge battery power cord works though
  • Acer Master
  • 32,281 Answers
Check the power adapter with a multi-meter, the voltage of the power plug that plugs into the power socket on the laptop should be slight higher than the voltage that is printed on the label on the adapter.
If it is faulty, there are replacement power supplies available on the Internet or at your friendly computer shop.
If the adapter is OK then the power socket on the laptop is faulty or this socket has a dry solder joint connection on the motherboard.
You can test this by wriggling the power plug when it is connected to the laptop, if the charge LED flickers and if you hold this plug in a certain position the charge LED stays on without flickering, then the power socket is faulty.
This can be repaired, but requires the laptop to be completely
disassembled. I suggest you get a quote first.
Posted on Sep 28, 2009
My tablet wont turn on unless connected to a power supply and when its connected the screen stays black
I'd check the tablets internal battery and also the cord and plug from the charger. Though the cord powers it enough to run the connection may be too insufficient to -keep- the battery charging. I would also turn the device completely off while troubleshooting.
Jun 27, 2015 | Tablets & eReaders
My tablet wont charge unless turned on but battery is so low it wont turn on so cant charge it up.heeeeeelllllpppp
You Power Cord must be bad. If you cannot get on the laptop by using just the power cord, then the power cord is bad and needs to be replaced. Also it sounds like you've been operating off your battery since the power cord is bad, but now the battery is dead because the bad power cord was not charging it.
Get a new AC Adapter and Power Cord. Or it could be that the pin where you plug the power cord into the table is damaged or broken.
May 15, 2012 | Archos 101 Internet Tablet 16GB 10.1"...
My Asus Eee PC 1001PXD battery won't charge. The charges light is on but nothing happens and now the battery is completely dead and I cannot get my notebook on
Your problem is far more than the battery. Your problem is the power cord. Laptops for the most part will work off the power cord even if the battery is dead or even if the battery is not in the laptop. Your power cord charges your battery and if it is bad it will not charge it. You've been working off your battery even though you might have had the power cord plugged in, but if it's bad and not charging the battery, the battery drains and then you can't get the laptop to power on at all. Go purchase a ac adapter and power cord that is designed for your system. Don't buy one that some of the big box stores sell that has a an interchangeable plug at the end designed to fit just about any laptop. Those will eventually burn *********** board out.
Mar 20, 2012 | ASUS Computers & Internet
Power Button Wont Work
If there is no power at all the problem could be that the Power Cord is bad or the Motherboard is bad. The guys at: http://www.generalsystemsconsulting.com can help you. They will fix it and ship it back by Fedex or UPS. Get a quote from your local computer shop then try them.
Mar 10, 2012 | HP G60-235DX Notebook
There is no power from the battery or the adapter and the laptop does not recognise the adapter is plugged in. there are no lights coming on and the power button is doing nothing
Your battery maybe out of charge. Thats why nothing happens when you press the power button. The battery may not be charging because the power cord might not be working. Try another power cord.
Try removing the battery and plugging the power cord and switching on the computer. If its the problem with the power cord the computer wont start. If it starts, the power cord is working fine.
Nov 18, 2010 | Acer Aspire 5920-6727 Notebook
Battery will not charge/ keep computer on. laptop must be plugged in to be used. I have tried a different battery and power cord (my wife by sheer coincidence bought the exact same model laptop as me a...
Sounds to me like the transformer circuit that enables the batery to charge. If you have bought your machine within the last 12 months it should still be covered by warranty so go back to the supplier. If not covered I wouod still try as it is not beyond reasonable expecations that the machine will operate perfectly in very way for more than 1 year.
Feb 13, 2010 | Acer Aspire 3000 Notebook
Psp carge light wont come on and psp wont turn on
You either have a bad battery, or a bad power supply that charges the unit (power cord). If you have a friend that also has a PSP, try swapping out the battery to see if that works, and or try another power cord to see if the charging indicator light comes on. I think that possibly your battery is dead and the power cord might be bad. You can find good deals for both the battery and cord on ebay. Good luck!
Nov 07, 2009 | Sony PlayStation Portable (PSP) Console
Wont charge and get get it to stay on,
Check Power supply first.
use another one and check if battery is charging.
Jan 12, 2009 | HP Pavilion ze5270 PC Notebook
Cx2620 gateway wont turn on
Possibly Need a New DC Jack In Your Laptop... the DC JAck Is The Port Where Your AC Adapter Plugs Into...
Though You SHould as well Check For Proper Power To Your CHarger Cord.. Not all AC Cords That Have Their Lights On Are Able To Charge...
To CHeck If It's The DC Jack... Remove Your Battery..... Plug In the AC Adapter Cord... Power On... If You Get No Lights/ No Power/ No Fans Etc..... It's Your DC Jack
Nov 20, 2008 | Gateway Convertible CX2620 Notebook
Startup/charge issue
hi.. unfortunately i've seen many cases like this and it looks as if from what you are describing that your laptop is fried if there is no boot up at all.. how old is you laptop and what brand is it?
Feb 19, 2008 | HP Compaq Presario V2000 Notebook
Acer Aspire 6920 Notebook PC Logo
167 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
