Question about Maytag Neptune MAH6500A Front Load Washer
Crack in the outer tub Maytag Neptune washer MAH3000
The crack causes a lot of water to leak as it is at the bottom of the outer tub.
I have not repaired it yet but got PolyWeld from Tap Plastics assuming it is some kind of PE (Polyethylene).
Tap plastics told me to test the material with any kind of glue. If the material reacts with the glue, then it is likely repairable with the Poly Weld glue. There is a video of the repair on their website.
5 Suggested Answers
  • 883 Answers
SOURCE: neptune washer
it may be plastic?
Posted on May 23, 2007
  • 409 Answers
SOURCE: Neptune washer MAH5500BWQ
hi there,
looks like you have a leaky boot. you can purchase the part yourself at www.reliableparts.com
not sure about the labour to put it in, since i'm not sure where you live.
also, please supply the model # off your washer.
Posted on Sep 15, 2008
SOURCE: Repairing leaking Maytag washing machine
Maytag Appliances are ****!! Don't buy Maytag. Spent $2500.00 in 2005 on Maytag Neptune washer and dryer. They have been nothing but trouble. Washer has water running in tub constantly. Recall on ground and recall on footing. Dryer making loud noise when drying clothes.The Maytag man is dead and gone.
Posted on Oct 10, 2008
  • 5 Answers
SOURCE: Water leak from bottom of Maytag Neptune washer
The water pump is cracke,. replace the water pump. Peter
Posted on Mar 18, 2009
How to stop squeak on Hotpoint Washer?
see the causes:
During fill only
air gap deformed or crack, the tube crack cause leak,inlet spout crack cause leak.
During drain and spin only
main drain hose, inspect the hose,plastic outer tub can rust or split you must replace the entire outer tub
All the time
check hose for cold and hot water,main tub seal, pump leak replace,outer tub replace.
God bless you
Jun 19, 2012 | Hotpoint Washing Machines
Water leaking from my Maytag Neptune model FAV6800AWW Serial number 15646382GA Leaks during wash cycle imediately and during complete cycle. Enough water to saturate 2-3 towels and clothes come out...
Could be a Tub Seal leak my 1st choice. Could also be a leak caused by a cracked outer tub, issues from the hoses from the drain line connections to the drain pump, drain pump and or drain line.
Are you going to try to DIY the fix?
Sep 07, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Leaking at bottom of washer after it spins out not alot of water but a pain in the ****, how do you get in to the back of the washer?
The FAV6800A and FAV9800A only have access thru the front panel and washer top once released fromt the base......no rear or side access. See Pick of Outer Tub removed for Tub Seal and bearing replacement.
Google ""16022808.pdf"" to find the Service Manual.
Page 33 will show ou how to release the top cover and page 41 for front cover removal.
If you have wash water leaking down on the Clutch Pulley I feel you have a Tub Seal leak. The issues could be related to the drain hose/drain pump or cracked outer tub.
I don't troubleshoot on this forum to difficult to carry on thread. Google ""Neptune TL Washer FAV6800AWW"" or ""FAV6800A/FAV9800A Outer Tub bearing replacement"". Two DIY forums I frequent that I feel are true DIY forums.
Sep 04, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I've got a crack in the inside tub. The fiberglass part. How do I remove the one side to repair this. And I take it 'J B' Weld will do the trick? LOL Thank you, Mary
Mary,
Google this ""16022808.pdf""
That will you take you to the FAV6800A/FAV9800A Service Manual. The SM will take you thru front panel removal. the front panel and the washer top raised are the only access points for the FAV6800A and FAV9800A Maytag Neptune TL's.
JB weld should do it. I would rough up the crack area and place pice of fiber glass mat and resin.
Mary,
That will you take you to the FAV6800A/FAV9800A Service Manual. The SM will take you thru front panel removal. The front panel and the washer top raised are the only access points for the FAV6800A and FAV9800A Maytag Neptune TL's.
JB weld should do it. I would rough up the crack area 60 grit light sanding and place piece of fiber glass matt and resin.
How did this happen? Any sever wash tub swings in Spin Cycle?
I don't use this forum for deeper DIY support it's too difficult to find my older post for reference and no editing features.
Google this ""FAV6800A/FAV9800A Outer Tub bearing replacement"" I support a lot of owners like you and myself at that site. Fixya is OK if you can get help for this TL.
Good Luck dh1200s
If your machine is a FAV6800A or FAV9800A here is a pic with the front panel removed. I'm working on preventive maintenance for DC/UC unbalance errors associated with the Clutch Pulley a common failure with this TL..........Good Luck dh1200s
Pic with the outer tub removed for Outer Tub bearing rebuild work.
Aug 05, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune tl leaks from the bottom while it washes MODEL #FAV6800AWW it leak about two to three cups of water for each load,about one drop per second.
Possible Tub Seal leak, leak from Outer Tub, Sump Cap, Drain Pump, Drain Line.
You need to pull the front cover off the machine and ID the leak source. If there wash water over the Clutch Pulley I would suspect a Tub Seal issue.
You can't link to the Service Manual form this site.
Google Maytag Neptune load unbalance and see if you can find support for the Service Manual.
Oct 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
About 1 minute into the cycle water starts running out from underneath of the washer. Checked all the hoses that are connected to the back and none are leaking
this is either the front seal that goes from the outer tub to the front of the washer or a hole in the outer tub itself or one of the hoses underneath the seal and the hoses are easiest to check you can take a cup of water and slowly pour it into the front seal. take care not to overfill it to where it spills into the tub and see if you are getting water on your floor from that. the hoses tip the washer up onto its back and look at them from the bottom for any cracking etc. the tub itself can only rust out on some of the neptune models or on others is plastic and can get punctured. just have to look for damage with a light and a mirror.
May 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune leaks several hrs. AFTER I finish using it.
Check the easy stuff first, fill hoses tight?- drain hose cracked?
Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker.
if that is checked then ---------------
t leaks Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Apr 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Mar 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Atlantis Top Load MAV6250AWW Drum Leak?
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
During fill only
All the time
Oct 22, 2008 | Maytag Atlantis MAV7260B Top Load Washer
My front loader is leaking water from the bottom
During fill only
All the time
During fill only
All the time
Oct 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH6500A Front Load Washer Logo
143 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
