Question about Reddy Heater-30-55,000 BTU Variable
Ready hater 110,000 btu
SEEMS LIKE WHEN IT GETS ABIOUT HALF EMPTY WITH FUEL. IT STARTS KICKING ON AND OFF. AND IT WILL BLOW SMOKE. WHEN IT KICKS OFF THE FAN IS STILL RUNNING
  • 625 Answers
Replace the nozzle and check the fuel filter - if this is a kerosene heater. under the access plate is a round filter - remove it completely or change it.
Posted on Dec 18, 2007
My Dayton 110,000 btu kerosene torpedo heater... The fan kicks on for a couple secs then kicks off it seems as it's not getting any fuel what should I do
Could be the Flame out sensor cutting the power to the electrics and therefore the forced air fan. It forces the heater to shut off should the flame extinguish. It might also be the temperature limit control which also turns the heater off if the internal temperature rises to an unsafe level. If either of these two possibilities the unit may need a service.
Dec 09, 2014 | Heating & Cooling
It starts up good then stops and a big cloud of smoke comes out. Got a new ignighter (50$) but still doing the same. can you help me?
http://www.bealsmotor.com/manuals/113282-01.pdf You could have an air problem. Take the cover off the heater and see if it runs ok, if it does then you have an air problem, check for bad lines or cracked housings
Oct 16, 2014 | All-Pro Kerosene Garage Shop Heaters - All...
Have a R35a that was stored with kerosene for 2 yrs. Electric motor runs and it tries to ignite. belches some smoke and heat intermittently then just blow air
your pic is a propane heater but model # a kero heater any way check lines to the air and fuel for cracking filters have to be clean in the heater and foam on the out not sure what the pressure is for that model but findable table on the ready heater look up get the old fuel out and new in good luck ready was the best
Nov 30, 2013 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater kerosene 110,000 btu . plup it in, fan runs, blows smoke out the front, leaks kerosene also from front, i have cleaned photo cell, replaced plug, cleaned filter and checked lines for cracks,...
Just because there is fuel & spark does not necessarily mean there will be combustion. The fuel must be delivered at the correct pressure, the correct volume, and must be delivered as a fog- not a mist.
My suggestions:
  1. set the pump pressure
  2. be sure the fuel filter is clean
  3. be sure no air leaks or vacuum leaks
  4. Desa recommended annual replacement of the nozzle. They wear out. When was the last time yours was changed?
More troubleshooting tips
Oct 20, 2011 | Reddy Heater-30-55,000 BTU Variable
My ready heater 100,000 will run for app. 5hrs then flame out and blow smoke or unburned fuel the same several times pressure is right
If the heater continuously has a 5 hour run-time check to see if the fuel pickup tube goes to the bottom of the tank. If broken, cracked, or shortened the fuel will stop being picked up when air is sucked rather than fuel.
Feb 08, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
My 110,000 reddy heater flames up then after a minute or two just blows cold smoke???
Time for a Full tune-up, plug--fuel filter- 2-air filters -vanes in the pump.
Dec 13, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Dayton Salamander Heater - Blowing Unburnt Fuel/Smoke Randomly
I have seen this before, you need to replace the nozzle.
Feb 01, 2009 | Dayton (3E386) Heater
Colman Furnace keeps kicking on & off
Denise, my heater not a coleman (a monitor heater (oil) kept turning off when the temp got really cold. I would advise you to ask if you can do this, I addded an additive to my drum outside which holds the fuel. Because the deisel thickens up when it gets cold, which makes the heater have a harder time distributing the fuel to the heater. So far the heater has not kicked off.
Jan 09, 2009 | Coleman Propane Forced Air Heater...
Saab 93 2001 - kicks out white smoke when started then drives ok until it gets to certain temp then starts miss firing and kicking out smoke
is car consuming any antefreeze? does the temp fluctuate? on worst case, you could be looking at poss. headgasket problem white smoke is usually antifreeze. black smoke is fuel, and gray smoke is oil
Nov 30, 2008 | Saab 9 Cars & Trucks
Reddy Heater-30-55,000 BTU Variable Logo
106 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
