Question about Fujitsu Siemens Computers & Internet
Screen full of horizontal lines on my Amilo L series laptop
Screen of scrolling white horizontal lines against a black background. no visibility of windows login page. suspect graphics card failing??
  • marktyan
    marktyan May 11, 2010
    could be the monitor or the invertor for the monitor.... or the system got too hot and damaged the video chipset... please clarify more details for the diagnosis
bmwrider
  • 215 Answers
SOURCE: Redless screen
The white lines on the darker backgrounds are more than likely retrace lines. Usually caused by a leaky capacitor in the horizontal sync circuitry. If the red comes and goes it's probably a dry joint in the red drive. If you're handy with a soldering iron try resoldering the solder joints on the CRT neck board. If that doesn't do the trick then perhaps the drive transistors are on the motherboard. Just look for 3 transistors usually in a row and somewhere very close would be adjustable pots with the letters R.G and B printed near them. Even a simple gentle tapping with a plastic end of a screwdriver around that area may make the red flash on and off. Just resolder around that area and you'll know it's fixed when the red stays on. Just make sure the power is unplugged when working on the set and stay well away from the EHT and power supply areas. They can give you a nasty shock even if it is unplugged. Actually with live chassis TVs it's always best to use an isolation tranformer. If any of this is over your head the say hello to the repairman :-) BMW
Posted on May 31, 2006
  • 556 Answers
SOURCE: white horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Posted on Sep 21, 2007
  • 3 Answers
SOURCE: Laptop screen has horizontal white lines running across half the screen
Ive encountered laptop screens that are bad, with broken connections or a small carack on the very edge of the screen. I have an old laptop with the very bottom line of pixels dead. But as i push on the edge of the screen they flicker. Try carefully squeezing around the edge of your laptop screen near the lines. Its possible the screen itself is defective and need replacing.
Posted on Dec 23, 2007
janelu
  • 93 Answers
SOURCE: black and white horizontal lines in my asus a3000N laptop
Sound like the cable was lose between LCD panel and Motherboard. You can't do by yourself. Hope the laptop is still under warranty repair.
Posted on Nov 13, 2008
  • 3940 Answers
SOURCE: black and white lines after bios screen before boot up
The issue appears to be cosmetic if the system boots to WIndows and there are no display issues using the system. Some systems I've seen have a bit of video distortion between the BIOS splash screen and the desktop. A couple things may change that. Update the system BIOS and the video driver to the most current available
Posted on May 23, 2009
I got some white patches appeared on my led which is very visible in black back ground which is awful my product is sony vaio E series laptop can any one tell me why does those spots appeared
That's called backlight bleed. It's a known issue with certain models of the LED screens. I had a similar issue with my previous laptop, a Lenovo G560. The only solution is to replace the screen.
Nov 18, 2013 | Sony VAIO E Series VPCEB36GX/BJ Notebook
WHITE SCREEN ON SAMSUNG LAPTOP
Prior to the Windows splash screen do you see graphical issues ( black background, white writing, or bios splash screen) if you don't then the problem is with windows and will need to be reinstalled. Samsung ship laptops with a windows cd and is a fairly basic wizard. If you don't know how to do this google is full of guides. If you however see graphical problems right from turning the laptop on then there is likely to be a hardware fault straight from the factory. Contact Samsung and they will repair / replace the laptop through warranty. I have seen several Samsung laptops brand new from the box do this and It turned out to be a hardware issue and was replaced on warranty. Good luck.
Apr 17, 2013 | Computers & Internet
Black screen with flashing horizontal lines
it can be the fibre or someone pressed the screen on the topside or plced something heavy on it
Apr 14, 2017 | Compaq Presario C700 Series Laptop...
Horizontal white lines 27A43.
You have some bad capacitors. They are located very near and next to your vertical IC. I would guess you would have to replace maybe four of these! Thanks for asking!
Jun 12, 2010 | Toshiba 27A43 27" TV
Screen problems on re-assembled Satellite L30
You must reconnect screen cables, try to make it very strictly. They loose sometimes. This screen problem is typical for a bad connection.
Mar 29, 2009 | Toshiba Satellite P30 P35 Series Notebook
Very fine blue lines veiwable when the background has black in it
You need to adjust (actually bit decrease) G2 volts (calls Screen volts) of Blue gun.
If you are familiar with big TV repair and have electronics knowledge then let me know to guide you further.
thank you.
Dec 13, 2008 | Sony KP-51WS500 51" Rear Projection...
AMILO M1451G display
if you can notice this problem in the BIOS then the problem is with the Display adapter .. if you newly bought your computer i suggest you send it back
Dec 29, 2007 | Fujitsu Siemens AMILO Pro V2010 Notebook
White horizontal line down middle of TV screen
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
Computers & Internet Logo
57 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Marcin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
