Question about Iomega ScreenPlay
No disc on TV, no conection by USB on PC, and a small noise on HD
After some months working properly, my Screenplay HD 1,5Tb, just today decides not to work...
On TV screen, after the Screen play logo, appear a message of NO DISC (in spanish NO HAY DISCO). While, a low noise comes from the HD each 2-3 seconds... If I choose any option on the remote control, the orange light flashes and then stops lighted, but nothing happens...
When I went bak to the PC conecting the HD by USB, nothing happens...the unit doesn't appears, the pop-up menu to choose what to do doesn.t appears....
I've checked all the connections...
I have less than 30% of space in use...but a lot of pictures of my daughter, and I don,t want to loose them¡¡¡
Any idea??? Thanks in advance¡¡¡
toni
SOURCE: Iomega Screenplay Pro HD - No Menu
I had the same problem with the Screenplay Pro HD. My Iomega was working fine and one day after exchanging files with a friend I got the logo, then the loading message and then it went into a black screen while the blue light kept blinking.
Obviously the connection to the TV was fine because the logo appeared.
I solved the problem by downloading and reinstalling the firmware.
I downloaded the firmware from the iomega web site.
Notice that during the installation process you get the message that it will delete your data and then shortly after you have the option to delete or keep it. Hang in there. This part is a little nerv wrecking.
Hope this helps.
Rainer
Posted on Jan 03, 2010
SOURCE: My Iomega Screenplay 500 isn't working
Your Iomaga Hard Drive is broken. The clicking noise is the heads ggrinding off the palate and this problem can not be fixed. If your player is less then 1 year old it is guarenteed and should be replaced. Otherwise, it the hard drive inside needs to be replaced!
Posted on Feb 07, 2010
SOURCE: Iomega Screenplay Pro HD Multimedia Drive works on PC but not on
If the blue light continues to flash after the screen goes black, then you need to reinstall the firmware. Look at http://screenplayprohd.wikia.com for information about getting the firmware and installing it.
If the blue light goes solid after the screen goes black then you probably just need to switch the NTSC/PAL selection. Press that button on the front panel several times, waiting a few seconds inbetween in press. If it continues to be invisible, plug the drive into another TV using the composite cables instead of HDMI to confirm if the menu comes up at all. If it does, reinstall the firmware.
Posted on Apr 06, 2010
SOURCE: Iomega Screenplay buzzing no Disc wont bring up Folders
I have a Screen Play HD. It was working fine until today when suddenly all my computers can't detect it. I tried a different external disk, it worked fine.
Posted on Sep 14, 2010
SOURCE: Displays No Disc on TV
Hi jasnarysheuv,
Did you fix the problem you had? If so could you tell me what you did? I formatted my Iomega Screenplay HD Mulitmedia Drive (500gb) last night on my mac and now it displays 'no disc' when I hook it up to my tv.
Any help would be grateful.
Posted on Nov 16, 2010
I got a windows 7 - 64 bit. the screenplay director hd media player from iomega doesn't show up when connected via usb. what should i do?
Quoted from Iomegas website
When connecting a ScreenPlay to the USB port on a computer, you should always power down the ScreenPlay first, then connect the USB cable and turn power back on. This changes the ScreenPlay from video mode that allows it to communicate with a TV set to USB mode that allows it to communicate with a computer.
When you want to reconnect the ScreenPlay to a TV, use the safe removal process for your operating system to unmount the drive, then power down the ScreenPlay and disconnect the USB cable. Turn power back on after the ScreenPlay is correctly connected to the audio/video connection on the TV set.
To ensure that the ScreenPlay is correctly recognized, do not connect a ScreenPlay to USB and a TV set at the same time.
Do the above and your screenplay director will be recognised by your pc
Please vote for me if you found this info useful
Apr 22, 2011 | Computers & Internet
Why is it that I canot get sound on all the vidios that I play back on my TV from my Screen Play I can only get sound on a few ?
Hi Mary,
Please check the format of the video that you are trying to play.
this Iomega ScreenPlay Plus HD Media Player is certified to play popular DivX video, and supports many of today's popular CODECs and file types, including H.264, WMV and MKV, as well as plenty of others. (For a comprehensive list of supported video, audio and photo files. Most probably the video that you are trying to play is .3GP or .FLV.
For this you need to convert the video files to supporting format like DivX®, DivX Plus™ HD (MKV), XviD, AVI(Xvid, AVC, MPEG1/2/4), ISO, VOB, MP4, MOV, MKV,H.264, WMV, RMVB and MPEG.
Thanks,
Satheesh
Jan 21, 2011 | Iomega ScreenPlay Plus HD Media Player 1TB...
Brand iomega screenplay tm pro hd multimedia drive my problem is when i conect my usb cable to pc it is not been picked up in my devoices when i put in a memory stick it comes up right away
Are you using the USB 2.0 device connector (the connector right above the power connector) connection to your computer and not the USB 2.0 host port (located above the ethernet connector) ?
Dec 16, 2010 | Iomega ScreenPlay
I need to download iomega Screenplay 1T user manual
You should be more specific with which unit you have when asking questions about it.
ScreenPlay Director HD Media Player: User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hdd2010/spdirector/en/main.html
ScreenPlay Multimedia Drive: User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hdd2008/scrnply/en/consolidated/main.html#scrnply
ScreenPlay 60GB Multimedia Drive User's Manual: http://www.iomega.com/support/manuals/allhdd/screenplay/en/main.html
ScreenPlay HD Multimedia Drive: User's Manual: View Online [HTML]: http://www.iomega.com/support/manuals/hdd2008/sphd/en/main.html
ScreenPlay Plus HD Media Player: User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hdd2010/scrnplyplus/en/main.html
ScreenPlay Pro HD Multimedia Player: User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hdd2010/scrnplyprohd/en/main.html
ScreenPlay TV Link User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hdd2010/sptvlnk/en/main.html
ScreenPlay TV Link HD Media Player Director Edition: User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hdd2010/sptvlnkdir/en/main.html
Oct 10, 2010 | Iomega ScreenPlay
I have a IOMEGA Screenplay Pro HD 1 TB drive. It was all working fine on TV and PC. But suddenly after I used it with my PC for transferring files, I switched it off and then connected it to the TV. Now...
have u tried the tv sys button on the remote ? reperat a few times as it cyclels thru the formats. or the source button. first disconnect the usb
-will power
Nov 13, 2009 | Iomega ScreenPlay Pro MP3 Player
Resolution not supported error on Iomega SCREENPLAY HD 500gb
Avi files should be 700 or below when playing on a conventional tv,625 or 525 prefered.
if set to hd format trough HDMI output the display warning will not appear has the iomega will upscale trough the HDMI output,and will suport any resolution.
Nov 11, 2009 | Iomega ScreenPlay
Hi jasnarysheuv,
Sep 28, 2009 | Iomega ScreenPlay
Jul 06, 2009 | Iomega ScreenPlay
Iomega ScreenPlay Logo
302 people viewed this question
Top Iomega Televison & Video Experts
Martin Murray
Chris Larocque
Are you an Iomega Televison and Video Expert? Answer questions, earn points and help others
