Question about Dell (0Y4801) for Inpsiron 600M, Latitude D600 Motherboard
Looking PCI Device
Everytime I stat my Windows xp pro machine it opens a window saying it is looking for a new PCI device. Nothing has been added to this machine. No cards, no external devices, no new mouse or keyboard, not even a USB memory stick. Any ideas
    President:
  • 2,351 Answers
Check Device Manager.
Open System Properties. Click on the Hardware tab than click on Device Manager. Scroll through the listed icons. If you see a yellow ! or ? than there is a device that XP is barking about.
Posted on Dec 19, 2007
I have recently replaced xp on my desktop pc for vista , and now the sound does not work, it keeps saying there is no audio output device installed or audio controller, i have been on device manager a
1. no audio device, if you sound card is integrated , first to CMOS inside look at sound card was disabled or not, then again consider driven of problem,
in device management Manager in look at is has yellow of question mark or is laments,, some words on double-click the device (into driven CD), click Update driven program, by prompted update can (don't said you does not yo).
also directly can be placed in the driver CD to install the driver, after installing your reboot should resolve the issue.
2, and if sound card is independent, first look card gold finger whether oxidation, as found gold finger gloss Dim found block rubber wipe to oxidation layer, again see PCI slot within whether has product dust, if has words with rubber blowing blowing clean dust, again with new of Yuan folding up to slot inside wipe about, then will sound card insert PCI slot within, must to plug tight, also no on for a slot try try. Determine Board connection when there is no problem, follow the steps to install drivers, in case of hardware damage alone will solve the problem.
Sep 04, 2012 | Microsoft Windows Vista Home Premium with...
Fujitsu fi-4120c scanner on Windows 7
Hi ocdaveymac
Fujitsu fi-4120c scanner drivers can be found at
driverupdate us .
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Mar 09, 2010 | Fujitsu fi-4120C Path-Through Scanner
Canon Canoscan D1259U2F dont have any driver for Windows 7 64-bit
the only successful method I found for using CanoScan D1250U2F in 64 bit Windows 7 (I guess the same would be for 64 bit Vista) is to use Windows XP Mode in Virtual PC (attach the scanner as USB device and that's it - works perfectly)
I had a problem with Windows 7 detecting the device as CanoScan (needed for Windows XP Mode to detect is as USB device and allow attach) - the solution was to unplug the scanner, plug it in and CANCEL Windows 7 hardware detection process before it finishes - this leaves it as "CanoScan" device (auto-detect will leave it as "Unrecognized device" and with that unusable/un-attachable in Windows XP Mode)
latest versions of Windows XP Mode will make your hard drives accessible as network locations (no need for external media)
Jan 01, 2010 | Canon CanoScan D1250U2F Flatbed Scanner
Microphone des not work
There are two items you'll need to check. First, when you boot your system press the Delete key to enter the bios. Open the Advanced tab.
Make sue your Audio is set to [Enabled].
For windows XP operating systems check within windows Device manager. Click the start button, open control panel. Double left click on the "System" icon to open. System properties window will open. Click on the Hardware tab than click on the "Device Manager" button. Scroll down through the icons until you come to: Sound, video and game controllers. If there is a problem with the driver you will see something like. Unknown pci controller or simple pci controller. If you do not see something either of these than there is nothing wrong with your driver software. Make sure you setup your microphone. Open the windows "Control panel". Than open, "Sound and Audio Device". Click on the Audio Tab. Under, "Sound playback" the Default device should read as; Realtek AC97 Audio. Now click on the Voice Tab. Under "Voice playback" the Default device should read as; Realtek AC97 Audio. Lastly, you need to click the "Test hardware" button. Follow the instruction from windows. It wouldn't hurt to check windows for updates. If you still do not have use of the microphone than the intergraded sound controller is defective. This can’t be repaired. You can disable the intergraded sound controller in the bios. Than buy a PCI sound card and add it into an opened PCI port.
Hope you find this helpful.
Mike
Nov 03, 2009 | Intel D865GVHZ Motherboard
Computer sees drive as Generic USB Device
Hi Brian, It certainly sounds like either your drive enclosure or the drive itself has some failed circuitry. You can try moving the drive into a new enclosure, if you're not sure how, take it to a local computer shop and have them transfer it into a new enclosure and test it for you. If it works in the new enclosure, you're done! If not reply back here by adding a comment with your country and city and I'll pass along a recommendation for somewhere to send the drive for data recovery. Chris
Jun 05, 2009 | Cavalry Storage EXTHD 500G|CAVA U2&ESATA...
HP Deskjet 4280 scanner problem
Possible causes
  • The system resources are too low to facilitate scanning.
  • The USB controller is sharing an Interrupt Request (IRQ) with another device.
  • There are multiple entries (ghost entries) of the scanner in the Device Manager.
Step 1: Open the System Information tool Windows 98, Me, and 2000 Pro Click Start , Programs , Accessories , System Tools , and then System Information . The Microsoft(R) System Information window opens. Microsoft® Windows XP Click Start , Help and Support , Tools , My Computer information , Advanced System Information ,and then Detailed System Information (msinfo32.exe) . The Microsoft System Information window opens. Step 2: Verify the available system resources If the system resources available are below 50%, the scanner may have difficulty transferring the scanned image to the computer and will stop in the middle of a scan.
NOTE: Windows XP does not give system resource information in the System information window. Skip to Step 3 if using Windows XP.
  1. Select the System Information linein the left side of the System Information window.
  2. In the right side of the System Information window, verify that System Resources are 50 percent or above.
  3. If the System Resources are lower than 50 percent, increase system resources .
Step 3: Check for IRQ sharing between USB and other devices The USB controller normally shares an IRQ with the IRQ Holder for PCI Steering device. While this device does not cause any conflicts, other devices on the same IRQ may cause a conflict.
  1. With the System Information tool open, click the plus ( + ) next to Hardware , then IRQ’s . In the screen to the right, information about will appear showing which IRQ a device is using.
  2. Verify the USB controller is on an IRQ with nothing else sharing it except the IRQ Holder for PCI Steering. Examples of USB controllers are listed below:
    • Sis 7001 PCI to USB Open Host Controller
    • Intel 82371AB/EB PCI to USB Universal Host Controller
    • Intel 82801 BA/BAM USB Universal Host Controller
  3. If the USB controller is sharing an IRQ with another device besides the IRQ Holder for PCI Steering, contact the computer manufacturer for assistance in moving it to another IRQ.
May 22, 2009 | HP DeskJet F4280 All In One Printer InkJet
Windows me to windows xp pro sp3...no sound
Take the modem out.Then start the computer,go to the device manager and start at the top of the list and right click and update drivers for each item Including the bus,then restart.
Also,If you don't really need dial up,Leave the modem out.
If you do need it,Wait until you have updated all the system devices and then put it back in.
Please rate this a fixya.
Feb 10, 2009 | Gateway Computers & Internet
CL51-15 USB Port Problem
I have the same problem with the USB's not working. Suppliers say Motherboard problem. solved it by purchasing a PCMCIA to USB port. at least i now have 2 USB ports. you could probably get one with 3 ports.
Kevin S.A.
Sep 26, 2008 | ASI CL51-15 Notebook
GeForce4 MX 420 Video Card
First question: Are you sure you have a PCI card?
there are several points here:
Make sure you have the monitor connected to the correct output on your computer. (In this case to the output of the graphics card, not to your onboard output)
If you have a PCI card set bios to PCI
Setting it to AGP means the computer is looking for a graphics card in you AGP-slot on you motherboard.
I cannot help thinking, that you actually have a AGP card in a AGP slot and that you computer is not working on onboard, but on AGP. But you can check which graphics device is used, in display properties (right-click Desktop, Properties, Settings)
Please post some feedback
Apr 04, 2008 | VIA P4MA Pro Motherboard
Ei systems 4411 Battery driver/not charging
first of all check this battary with another same configured laptop of your's.. i guess this problem should be with your battary...
thanks
Mar 31, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
46 people viewed this question
Clive
Clive
Alun Cox
