Question about Garden
I pull the cord and it doesnt replace it self back so i can try to pull the cord again. if i do get a good pull its kinda hard to pull. i replaced the oil and the spark plug. i got the mower from someone and it was out in the weather prob for most of the summer. can someone help
    Sergeant:
  • 302 Answers
You may have gotten the rope on top of the spool that it returns on. Take the cover off the engine that contains the starter cord and the problem should become apparent. If it has been out in the weather you may have to clean it and lubricate . hope this helps.
Posted on Sep 29, 2009
How do fix a homelite mp88 portable chop saw that has been liquid locked
rey taking the spark plug out and turning it over with the cord a few times to remove the liquid from the chamber and sump
Feb 15, 2017 | Homelite Garden
How to fix my Tanaka chainsaw rope to recoil back?
replace teh recoil section as there is a problem with the spring or the pulley section holding the cord.
Apr 26, 2015 | Tanaka TCS33EB/14 32 cc Gas Powered 14-in...
Have Homelite Yard Broom II UT08514. Fuel filter fell out of tank when I dumped old gas! Which little black tube (way back in the tank) does it belong on and how do I reconnect it? thanks
I have a GBI 22"v leaf blower anyway i replace a pull cord on blower but dosen't pull cusae it hard to pull i took everything apart again and again and still hard to pull the cord ok help me pelase.
Dec 18, 2011 | Garden
The pull start cord will only move about 3-4 inches and then it stops and then cord stops, Troy built- Briggs/Statton 21 inch self-propel lawnmower.
The mower's drive shaft may need to be lubricated. If you turn the mower over and try to move the blade by hand (with the mower off, of course) does it move, or is it hard to move? If it's hard to move or it won't move at all, lubricate the shaft by squirting some WD-40, 3-In-1, or other lubricating oil onto the drive shaft where it meets the chassis of the mower. Squirt enough oil to cover the circumference of the drive shaft, then try to spin the blade again. It should at least spin a little bit now. Squirt some more oil and spin the blade again, until the blade spins easily. Then turn the mower back over and try to pull the start cord -- it should pull normally now.
Jun 05, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Self Propel Cord Replacement too loose!
measure it from the old cord thats the easiest way ?
Aug 26, 2009 | Toro Lawn Mower With Toro Power Tools
Cord is pulled out what do i do?
take off the part the cord goes into and put the cord back into it its spring loaded probly kinda tricky its diffrent on each model but there should be a place to tie the the cord into and put it back together cord probly dry rotted if the cord is in really bad shape you can buy a complete replacement
Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Self clean not stopping
you will need to turn the breaker off and turn it back on (kinda trying to "reboot" ) if that doesnt help the control will need to be replaced. in that situation it would be good to replace the oven temperature probe as well.
Mar 13, 2009 | Frigidaire FEF352 Electric Kitchen Range
System turns on however hard drive will not cycle nor will mouse or key board activate
Turn power off and unplug power from computer.
Unplug printers,backup drives and speakers.
Open case and unplug power supply from the board.
plug power cord back in press the power button.
Of course nothing will happen.
unplug power cord again.
plug power supply back into the board.
plug power cord backup and press power switch.
If nothing happens unplug power cord again.
pull out your memory sticks and plug cord back in and press power button.
Of course not much will happen.
But really something is happening to your computer so continue.
Pull power cord and replace memory sticks.
replace power cord and press power switch.
Continue this pulling out pci cards one at a time until you find out what the problem might be.
Try different keyboards and mice too.
Good Luck
Oct 27, 2008 | Intel Computers & Internet
Replace headlight
It is quick and extremely easy to replace the headlights on the envoys. Look at the top of the headlight assembly. you will see a kinda large lever you can pull up. Pull it up and the entire headlight assembly will be released from the car. Be prepared to hold it, and whatever you do, do not touch the new bulb with your bear hands!!. Kinda self explanitary once you get the bracket loose by pulling up the lever. Replace the bulb, and put the assembly back in the same way,, and press back down on the lever. Your done,, takes about 2 to 3 minutes.
Jul 18, 2008 | 2002 GMC Envoy
Garden Logo
66 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
