Question about Bosch SHU3305 Dishwasher
Cycle time The cycle is taking 3 hours to go through a wash at 65 in a slimline model
  • 330 Answers
First, read the manual before touching the settings. You need to set it up carefully but don't always change it unless you understand it. Secondly, if there's no change, call the Dealer.
Posted on Jun 24, 2008
I have an Aqualtis 9l29i washing machine. It is working fine but the wash cycles are all ridiculously long.Put it on the quick wash yesterday,three hours later still washing!! Suggestions please?
1. Front load machines always have much longer cycles.
2. The machine you have has a time saver mode on most cycles.
3. Check with your local Ariston reps on the time various wash cycles should take with your model if this is not specified in the user manual, which it normally would be.
4. These are notoriously bad over priced machines which will give you trouble early in ownership and are expensive to fix. For half the price you can buy a good top loader that will give you at least twice the trouble free years of use and not run ridiculous wash cycle times.
Jan 03, 2016 | Washing Machines
Dishwasher takes a very very long time to wash
It could be that it takes a long time for hot water to reach the dishwasher so it fills with cold water. the control may wait for the water to warm up before advancing. Try running the water at the sink until warm before turning on the dishwasher. This may fix the problem. Some models have a water turbidity sensor and will wash until the water is clear. Excessively dirty dishes will cause extended run cycles.
Oct 07, 2014 | Dishwashers
Fisher washer stays on clen for over 3 hours
"Fisher washer stays on clen for over 3 hours" ???
I think you mean the "Dishwasher stays in the clean cycle for over 3 hours", right? First question is "What cycle?" If it's the Pots and Pans cycle, or "Pro-wash cycle" , or "Normal cycle with extra wash heat or sani-rinse options selected, then yes, this is normal! A Normal cycle (without added heat) will take about 2 hours. And a short or quick or 1-hour cycle will take less.
Sep 25, 2014 | KitchenAid Dishwashers
Zanussi progress 1200
check the filter for blockages
May 01, 2014 | Washing Machines
Lg tromm manual
Problem is too much soap. Wrong soap. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
Jan 17, 2014 | Washing Machines
I have model #FGBD243KF1, Gallery 24" stainless. The wash cycle is taking almost 2 hours. Should it take this long? Also, when switching cycles during the wash time the motor whines a bit. Is this...
these units are pre programmed they can wash that longer and sometimes up to two hours and fourty five minutes. there are alot of factors involved.your unit sounds like it is running normally. at this time
Mar 27, 2011 | Frigidaire Dishwashers
Our dishwasher takes about 3-4 hours to run a cycle. My brother has the same model and it takes about an hour. Is there an adjustment that we can make to correct this? Thanks, Karla
make sure that your filter in the bottom is clean and if you are using the automatic wash cycle, it will wash until the water is clean. Sometimes it will take an hour, sometimes it will take close to 2 depending upon the level of dirty dishes in the dishwasher. And don't rinse! They work better on dirty dishes.
Jan 05, 2011 | Bosch 24 in. SHX46A05UC Built-In...
Dishwasher takes 3 hours to wash, even on the light cycle
whirlpool Quiet partner 3 the clean light is flashing 7 times what does this mean
Mar 12, 2010 | Whirlpool Dishwashers
Dishwasher runs for 3 hours
You may be running the sani-wash or heated drying. The heat element in these things takes a long time.
Check these and turn them off - then try another wash cycle and time it to see - should be one hour or less
May 03, 2009 | Dishwashers
Kenmore Elite he3t model 11045972404
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Bosch SHU3305 Dishwasher Logo
150 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
