It seems to work just fine until the end it leaves water pooled in the bottom. It was working fine for the last six months then just started leaving water at the end. It drains throughout the cycles but does not seem to drain at the end or drain competely.
-   Yes, I have the same problem with our kenmore dishwasher model 58715152400.
Jake, on the site, applianceblog.com/archives/2005/01/, had the same problem too, said the drain pump motor bearing was sticking. He replaced the drain pump motor, with a drain pump assembly, # 1378825, from RepairClinic.com for around $37 dollars.
-   Guest
Feb 18, 2008
-   I am having the exact same problem. Mine is a kenmore 58715152400. There is always water left in the bottom that will not drain out. It's not leaking or anything it just won't drain that last little bit. Help!!-   blueyedcurls
