Question about Acer Computers & Internet
My acer extensa 4420 cd/dvd disc drive is not working. It is not even listed in the device manager anymore. what do I do?
  • 63 Answers
Try doing the steps outlined in these article:
http://support.microsoft.com/kb/314060
Posted on Oct 01, 2009
Acer extensa 4420 cd driver not working
You can find the driver here, http://www.acer.com/worldwide/support/ , try a reinstall or Open the Device Manager, select DVD/CD Rom drives, update or roll back the driver. Have you done a OS upgrade? Have you tried a System Restore to a date before this issue?
Mar 28, 2013 | Acer Computers & Internet
4420 COmputer won't boot up
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
could be a dirty graphics card you might have remove the graphics card and clean the socket
also check your computer ram and cmos battery to make sure they are securely seated and the battery has plenty of charge
hope this helps you
Sep 13, 2011 | Acer Extensa 4420 (484U101011) Motherboard
When i reboot machine it not took the cd- dvd rom as a device, so i cant play cds anymore
Try going into device manager,select this device from the list and follow the troubleshooting guide for your cd/dvd drive
Nov 23, 2010 | Acer Extensa 4220-2148 Notebook
Extensa 4620-4963 - dvd drive has disappeared!
i have acer Extensa 5210 but the laptop is working properly but the dvd drive is not working
Apr 14, 2010 | Acer Extensa 4620 Notebook
My acer Extensa 4420 not booting up
dell inspiron 6000 pc note book or
acer Extensa 4420 which one ? either or sounds like hard drive is shorting out and you need to change it  lala linda
Dec 23, 2009 | Dell Inspiron 6000 Notebook
My acer Extensa 5620Z DVD/CD ROM drive is detected as USB mass storage that provides internet(Modem). When I remove the internet modem, the CD ROM is not listed in My computer. When I put CD or DVD in it...
That is a Vista problem with ACER. Delete the reference in device manager and restart and let the comp reco0gnize and reinstall ...just follow the screen instructions.
There is a registry setting that needs deleting but only if this doesn't work.
Nov 03, 2009 | Acer Extensa 5620 Notebook PC
Acer extensa 5620 notebook dvd-cd rom doesn't read my dvd. i think i uninstalled driver. how can i find dvd writer driver for my notebook?
go to device manager under System Properties. Locate DVD/CD Drives, expand it, select your drive, right click and then left click on properties, select the General tab and check the state of the device IT SHOULD indicate the device is working properly, if so or if not, select the Driver tab unomstall the driver, reboot, see if Windows will reinstall the driver as it should recognize the device as a new drive. If not return to the device manager and reinstall the driver.
Feb 19, 2009 | Acer Extensa 5620-4020 Notebook
I have an acer extensa 5420 and the disc drive will not play cds or dvds
Hi, your pc might have a hardware problem issue.
The disc drive might have gone bad already and need to be replace it. If the laptop is still under warranty, I would go ahead and consult with the manufacture for replacement.
yourcan verify if the window is cause the problem by right click on My Computer icon on your desktop and select Manage and Device Manager. If you can see the DVD/CD ROM drive status with Plus sign next to it, click on the plus sight and you should see your dvd/cd rom drive install on your Laptop. This mean window is reconizing the device but the device doesn't read the disc because it has a problem.
Hope this help.
Kam
Dec 10, 2008 | Acer Extensa 4620 Notebook
CD/DVD doesn't work lists code 10
I had anoton anti it jam up my op. drive. hp put in 2 new ones unde wart, What I found ot was norton had a bug. they would not help me stated the program was out of wart. I had 296 days left.and all info. from the time I bout it .W hat Idid washed norton out of my sysm. installed McAfee. having no more problems..W.LS. Pekin ill.
Sep 27, 2008 | Computers & Internet
I can't finalize a DVD on my Acer Extensa 4420. I follow the instructions, but the DVD is only readable in my Extensa, not in any other system.
Have you got a dvd/rw drive or dvd rom drive,
A DVD/RW drive will write DVDs
A DVD Rom Drvie will only read DVDs
If its a DVD/RW then remove device and reinstall
if you need more info please tell me what OS your using and make and model of your machine or pc
Thanks for your request.
Jul 20, 2008 | Acer Computers & Internet
Computers & Internet Logo
1,133 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
