Question about Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool front end loader washing machine is leaking from the degergent dispenser.Also, when it is on the spin cycle, it makes a load noise and it will occasionaly leak from under the door.
  • Anonymous Mar 23, 2014
    westpoint
We just had the same problem. After taking out the detergent tray, we saw the water was not draining into the drum. Feeling around the door seal in the upper corner (there is a small opening all the way around, between the door seal and drum seal, that you can fit your fingers into - please unplug your maching), my husband felt some fabric, and pulled out a mangled toddler pillowcase, which would have been in there for about two - three loads prior to finding the leak. Odds are you may have some medium size fabric piece in there, and is likely is the blockage. This is where the water seems to drain from the detergent compartmemt to the Drum.
Posted on Sep 29, 2009
Knocking during spin cycles, and water coming out of soap dispenser
hello, usually the knocking noise is a failed bearing. If it is the bearing it cost alot to repair. Try lowering the front legs to stop the leaking. hope this helps.....
Jun 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Loud clanking noise during spin cycle. Will not
If it is a front loader, then remove the rear panel, remove the belt, and soin drum by hand, if it feels rough, or is noisy and rumbling, then the main drum bearings have failed.
This is a major repair.
Feb 01, 2010 | Whirlpool LHW0050PQ Front Load Washer
My front loader washing machine is making a kind of squeaky noise when it spins. The washer is working..but wondering what it could be.
If the noise comes from the drum rather than the back of the machine it could be the drum bearings on their way out.
With the drum empty take hold of the top and bottom of the drum edge (from inside the drum). Gently try to lift and lower the drum, you may hear a slight knock - that's the bearings failing. Water enventually gets past the seal on the bearing and degergent in the water dissolves the grease in the bearing, causing it to fail.
Sep 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
No spin cycle on Whirlpool duet model ghw9100
If front loader, take top off (dissconnect plug) check the beltmay be broken- the motor may be spinning on its own
Also spin the drum round to make it has'nt seized
Jul 22, 2009 | Whirlpool GHW9100L Front Load Washer
During spin cycle washer spins fine but toward the end of the cycle it spins out of control like it is out of balance? Any help is greatly welcomed.
Some front loaders have a super high speed at the end of the spin. Front loaders don't like small loads, the laundry does not spread out evenly enough for a balanced spin.
May 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Noise at the end of spin cycle
possible bearing going out in your barrel.
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Front loader problems
call repair before warranty runs out...possible door switch if it's a loud humming noise ..try pressing in on door latch side to see it hum changes
Sep 06, 2008 | Frigidaire GLTF2940ES Front Load Washer
Cabrio he toploader leaking on towel/sheet cycle only
It is possible that the dispenser is leaking. It is typically the left front dispenser, you may notice a puddle on the left side. ???
Jan 09, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Dec 29, 2007 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
299 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
