Question about U-Line 75R Refrigerator
Does not cool
No cooling at all settings. has electricity as light comes on when door opens.
  • 286 Answers
Lights on but doesnt run? Replace the control
Posted on Oct 08, 2009
I have a mcbr1020w 10.0 frig. will not come on. just replaced the start device.
What does it mean "does not come on"?
Is it not cooling despite the compressor is running (in this case cooling liquid is lost), or is the compressor not running (nothing to hear, in this case the thermostat is defective) or may be when you open the door, there is no light inside (then the refrigurator has no power).
So check light (no, power is missing)
Check compressor(nothing to hear, thermostat is defective)
Compressor is running (to hear, cooling liquid lost)
The replaced start device you can check by using a bridge (cable with two clamps) between the contacts, but please do that only when you are familiar with electricity, it's not without danger. At best ask an electrician for help.
Nov 09, 2014 | Refrigerators
Replace light in KEMC378KSS microwave
The oven lights are 12-volt, 5-watt maximum halogen bulbs. They
will come on when the oven door is opened. On double oven
models, both upper and lower lights will come on when either
door is opened. The oven lights will not work during the Self-
Cleaning cycle. When the oven door is closed, press OVEN
LIGHT to turn them on or off.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
Feb 04, 2013 | KitchenAid KEMC378KSS Electric Double Oven
Door won't open after self cleaning and cool down has stopped.
if you are sure it has cooled down cycle it again to clean hitting the cancel button shorty after it starts
Dec 09, 2011 | Maytag CWE5800A Electric Double Oven
Lights come on when door opens but does not seem to cool. Lights which used to indicate temp setting for freezer and refridgerator do not come on at all. Freezer is not cooling at all. But lights do...
The thing i would check was the main control board on the back on the side about a foot and half up LEFT SIDE. It seems to be that the things that are conrtolled by low voltage are out because the board has fried. In most cases it's pretty easy to see if the board is the problem, by removing the cover there and you will see soot and burnt components on the board.
Gene
Aug 19, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Both freezer and fridge just stopped cooling. The lights come on when the doors are open and it sounds as if it's trying to run, but no cooling.
The problem can be temperature not set properly or any of fridge or freezer door not closed properly and cool air is getting leaked out. This are basic possibilities which first needs to be checked. But if this possibilities are checked ok and still the problem is same, then its weak compressor issue. Click the link below for more details:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
This will help. Thanks.Helpmech.
Aug 07, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
I have a flashing locked door light and cannot open the oven.
The oven is locked because the temperature inside the oven has not dropped below the locking temperature. Press Clear/Off button and allow the oven to cool. Oven door should open once it has been cooled below the locking temp.
Feb 17, 2011 | GE Profile JKP18 Electric Single Oven
Flashing Locked light. Cannot open the oven door
The fridge is not cooling and the freezer is not freezing. The light is still coming on when we open the doors. It sounds like the compressor is still running. What do we do?
the fridge is not cooling and the freezer is not freezing. The light is still coming on when we open the doors. It sounds like the compressor is still running. What do we do?
Mar 09, 2010 | Kenmore 73503 Stainless Steel Bottom...
Oven door is locked and won't open
oven door locked during cleaning then would not unlock after cooling
Jan 19, 2010 | GE JKP86 Electric Double Oven
U-Line 75R Refrigerator Logo
183 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
