Question about PSC PowerWedge (fd-000-22) Bar Code Reader Adapter
PSC QS6000: Do I need drivers to connect to a PC?
PSC QS6000 with a PSC Power Wedge 10: Do I need drivers to connect to a PC?
  • jason_mader Sep 29, 2009
    Where do I get these drivers?
    Genius:
  • 1,027 Answers
I beleive so.
Posted on Sep 29, 2009
Ive got a second hand psc qs6000 plus barcode scanner. where do download its driver.
If you are looking to program your scanner:
USB Interface
Keyboard Interface
If you are using the USB interface, make sure you are plugging the scanner either directly into the computer, or if you are using a USB hub, it is a powered hub.
I hope this helps.
Aug 20, 2009 | PSC QS6000 Plus Handheld
Windows XP does not recognize the Handheld scanner.
My guess is that the USB hub needs to be plugged in ... if for some reason the usb hub doesn't allow you to plug it in then you need to get one that you can plug in... because I believe the scanner is using more power that the usb port can power. Scanner usually need to be plugged directly into the computer or they need to be plugged into a powered hub.
I hope this helps!!!
cdixon18
The Man Inside the Machine
May 11, 2009 | PSC QS6000 Plus Handheld
QS6000 Plus with USB programing question
The document below programs the QS6500 Plus Scanner
R44-2805A Rev C
Available from
http://www.scanning.datalogic.com/sitefiles/manuals.aspx
Jan 27, 2009 | PSC QS6000 Plus Handheld
I need an owners manual
You can download a manual (06656 User's Guide/Programming Guide) at the DataLogic site. They bought PSC in 2005.
http://www.scanning.datalogic.com/sitefiles/result.aspx?m=Product%20Manual&p=53XX&l=english&d=1&t=search&s=NonCurrent
If your cables are connected between your keyboard and PC, be sure to set up the correct Keyboard Wedge Parameters, beginning on Page 34, to allow connectivity.
I'd start by scannig barcodes "CE" and "ZA" to reset to default wedge values. If that doesn't work, I'd procede to sc an "CF" for PC=AT,PS/2.
Pages 36 & 37 address the Caps Lock issue, where the scanned value is in the wrong upper or lower case.
Have a nice day,
Label_Guy
Jun 12, 2008 | PSC Quickscan GP5385 Handheld
Psc qs6000 plus
If, during the programming session, you find that you are unsure of the scanner's settings or wish to reset the scanner's configuration, use the Return to Factory Settings label available in the Programming Overview section of the above programming guides. (Note: Use this label with caution, as it will disable ALL features that may have been programmed since the scanner's installation.)
Apr 08, 2008 | PSC QS6000
Programming a USB PSC QS6000 Plus
Everything you need is came from your system mechanism. The only way to control your requirements is came from your programm coding.
at the start of the string sending must be filtered and rearrange from your program mechanism.
From what system you need to used barcode scanner? Are you using POS?
Hope you like my solution please rate me Solved.
best regards,
Philip
Nov 04, 2007 | PSC QS6000 Plus Handheld
QS6000 Plus barcode scanner
you can not change a qs6000 from ps2 to usb by just changing the cable. the interface inside the unit needs to support usb, to check this look at label with the serial number and if it says "I/F=KBW/RS" your our of luck, and can only use ps2 or rs232. if it says "I/F=UW" then you can just scan 3 barcode from the manual to set the interface to usb
Aug 28, 2007 | PSC QS6000 Plus Handheld
IBM Powerd USB not working
Are you using a USB 2.0 port?
Try a different USB cable.
PSC QS6000 Plus FAQ
Nov 28, 2006 | PSC QS6000
PSC PowerWedge (fd-000-22) Bar Code Reader Adapter Logo
198 people viewed this question
Top PSC Televison & Video Experts
Are you a PSC Televison and Video Expert? Answer questions, earn points and help others
