Question about HP Officejet 6310 All-In-One InkJet Printer
6310 - Printing from PC and faxing work fine. Problem is with copying. It appears to start the process and the display shows "copying". It pulls the paper partially through and then nothing. When power is pulled the paper will feed through. But it still will not copy when power is plugged in again. Thanks.
    President:
  • 787 Answers
Probably the scanner section is jammed.You need to disassembly your printer and manualy bestir the scanner section.
Posted on Sep 29, 2009
I have a fax-jx200 it shows ;auto print off . so there are faxes in memery how do i get to turn off auto print.
Press [ON/OFF] to select <auto print off>
The fax starts receiving documents to the memory
To cancel press [ON/OFF] again.
Oct 20, 2011 | Canon FAX-JX200
Having problem with fax machine
1. Your issue is possibly due to an un-sent message in the queue of the fax spool
a. unplug the fax and wait 30 second then plug it back in the AC socket.
2. check the display window to see if you can fax
3. Select the fax button punch in your fax number if you hear dialing then the fax is sending. Wait for a fax response.
Repeat steps 2 and 3 if not sending.
If this is a multifuncitoning device clear all printing on the PC and try fax again.
Mar 11, 2010 | HP OfficeJet 6310 All-in-One Printer...
Can a sharp ux-p410 retrieve old sent faxes from its memory
No, your fax machine only records the fax number of the last 50 transactions
Oct 19, 2009 | Sharp Office Equipment & Supplies
"Call Blocked" appears in the 6310 display on incoming calls...
"Call blocked" refers to the phone system caller ID name; this has nothing to do with the Fax function of the HP6310. Some callers block their name from showing up on your phone's call ID display.
Aug 16, 2009 | HP Officejet 6310 All-In-One InkJet...
HP officejet 6310 All-in-One When I try to print a copy of an airline reservation, from the ticket, or selected "print" on computer, it doesn't run off the ticket. It prints Page 1 of 1 on top of the page...
Make sure you're using the website's printer-friendly option when printing the ticket. Look for an option on the webpage (not in the pull-down file menu) that will correctly format the information for printing.
Aug 10, 2009 | HP Office Equipment & Supplies
When copying or printing a fax, a vertical black line 2-3 mm line
try cleaning the rollers with water in the feeder at the top check the glass too too see if it's dirty
Jun 27, 2009 | HP Officejet 6310 All-In-One InkJet...
When I attempt to print on 6310, it goes to fax mode
go to control panel >printers andfaxes and see which printer is set as he default printer....it is the fax rgt now.....rgt click on the pirnter icon and change it to the default printer.....should work....
Jun 24, 2009 | HP Officejet 6310 All-In-One InkJet...
Fax services not available from Computer
I work with Hp
It is not that you cant fax from the solution centre
but the fact that windows vista has an updated version of the registry which
will not allow faxing from the pc unless you have windows Vista ultimate.
Im not trying to blame Microsoft instead of Hp but I have taken calls where customers cannot fax using hp solution centre in vista and I started checking the registry and there is one component in Windows Vista Ultimate that is present which willl allow you to fax but This same registry entry is not there in other Windows Vista's.
That is why I prefer using windows Xp rather to Darn Vista
Jun 19, 2009 | HP Officejet 6310 All-In-One InkJet...
Hp office jet 4255 printer not printing anything or copying
ok..first try to make a copy and check if it copies fine or not..
if it copies then hardware is working fine..
turn off the laptop and unplug the USB cable..
turn on the laptop and wait for 5mins and then connect the USB cable..once the USB cable is connected do not try printing..wait for the hardware to get installed..
and then go to the printers folder and check if the printer icon says 0 ready..if it says then try printing..that should work
Feb 19, 2009 | HP OfficeJet 4255 All-In-One InkJet...
HP Officejet 6310 All-In-One InkJet Printer Logo
101 people viewed this question
Seeker5211
Seeker5211
