Question about Hotpoint Ultima WF840 Front Load Washer / Dryer
Washing machine display screens got a picture of a tap on it and says h20 ,just fills with water and wont do a cycle
  • Anonymous Mar 27, 2008
    my machine keeps displaying a tap sign it fills with water but does not run the cycle
    Scholar:
  • 146 Answers
Does the tap and h2.0 go off when it is full of water?
Posted on Dec 18, 2007
  • 537 Answers
Do you have your hot and cold water turned on? Is there enough water pressure? Are there any kinks in the hose? Check also the inlets (with the hoses off), for any clogs or blockage into the washer
My Indesit 7105 has flashing H20 lights, have checked but no blockages. It fills and drains fine, It wont agitate though, any ideas?
The machine does not fill with water or 'H20' flashes in the display.
The water inlet hose is kinked. • The water inlet hose is not connected to the water supply. • The water pressure is too low. • The water tap has not been turned on to allow water to flow into the machine. • There is no water supply to the house. • The inlet valve filter is blocked. • The START/PAUSE button has not been pressed.
Faulty pressure switch machine thinks there is no water in the machine.
Apr 01, 2017 | Indesit Washing Machines
Why is code h20 flashing during the washing cycle?
The washing machine fails to load water (The wording H20 is
displayed).
• The water inlet hose is not connected to the tap.
• The hose is bent.
• The water tap is not turned on.
• There is a water shortage.
• The water pressure is insufficient.
• The START/RESET button has not been pressed.
Dado
Jul 12, 2015 | Indesit IWE91481 White 595 mm Washer Front...
Why is h20 sign popping up
The washing machine fails to load water (The wording H20 is displayed).
  • The hose is bent.
Dado
Jul 18, 2014 | Ariston Technologies Washing Machines
ARXF125 FRONT LOADER WASHING MACHINE FLASHING H20 SYMBOL DURING CYCLE
H20 is "no fill" or difficult fill. To test:Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, restart machine, if necessary. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, restart machine if necessary. Now there should be twice the flow of water than with just HOT and COLD temps. If all seems good turn off the water supply taps. Loosen the connections at the machine. Wait for the hoses to relax before unscrewing them too far. If they do not relax STOP retighten and let me know. After removing the hoses check the screens condition in the end of valve. Those screens can become fouled with lime and other debris. Use a toothbrush and a spray bottle to remove crud. Hold the end of the hoses over a bucket or in the tub of washer and turn on TAPs to check the pressure, it doesn't have to blast out of there (but it likely will if you turn TAPs too far, so be careful) still it has to be more than a weak flow. If the screens are clean and if there is good flow the water valve should function, if it doesn't it is defective and will need replaced. BUT, before you do that you should try one more thing. Make sure you UNPLUG THE MACHINE FOR THIS! Open the console and disconnect and reconnect every wire connector you see. If a connection doesn't pop right off just give it a good wiggle. The goal here is to verify that connections are good, so reseat what you can and wiggle the rest and give wires that go through plastic connectors a slight push from behind the connector. Then plug the machine back in and give it a try. It's worked for me more than once. Let me know what you find out.
Jan 21, 2013 | Washing Machines
H20 is showing on my display on my indesit
H20 means not filling with water properly.
Check hoses and that taps are fully turned on , make sure water pressure is o/k, no kinks in hoses
Mar 13, 2010 | Indesit Washing Machines
I have a hotpoint ultima wt940 washing machine,, which is displaying a tap symbol,, when it fills up at the start of the cycle,, h2o flashes on the screen,, then the machine stops. Any advice? Thanks.
H20 is indicating a problem with the water supply.
Check tap/s are turned on fully, no restriction in hose/s, and make sure that there is sufficient water pressure.
Another possibility is that the inlet valve/s are faulty inside the washer.
Please rate my solution.
Thanks.
Nov 07, 2009 | Washing Machines
Does not complete cycle comes up with -H20 on screen
Hi.
Fault code H20 is indicating that the washer is not filling correctly, check tap/s hoses, and inlet valves for water supply.
Thanks.
Nov 07, 2009 | Indesit Washing Machines
Flashing H20
h20 means no water is getting to the machine. check your washing machine taps are on and water getting to the machine and the fill hose is not kinked.
Jan 26, 2009 | Washing Machines
Error code h20
hi sounds like a faulty fill valve easy fix
Sep 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF840 Front Load Washer / Dryer Logo
103 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
