Question about Crown Audio Players & Recorders
The main board in the crown macro tech 2400 is dead. the manufacturer has discontinued this.pls help me find a working main board. thanks
  • ironies77 Sep 30, 2009
    SURE THE BOARD IS NO MORE. I'LL TRY EBAY. MANY THANKS
  • 360 Answers
Do you know for a fact that you do not have a working board? If there's a problem with anything from speaker mismatch to loose transits, the board will not operate. This receiver is made of discrete components so, it couldn't be that hard to fix or maintain. But if you want a new or used one, they have them on ebay though there a little pricey.
Posted on Sep 28, 2009
Crowm micro-tech 2400 goes straight to protect upon start
Ok,
Lets get this straight, you are saying that a CROWN MICRO-TECH2400 power amplifier show the two front red lights when you turn it on? Because it supposed to do that if everything is fine, when you turn your amp on and one of the lights or both don't turn on then you have a serious issue with this great amp, keep me informed in case you need further help.
Nov 07, 2013 | Crown Audio Players & Recorders
Crown macro tech 3600VZ AMPLIFIER
Haven't found one yet tho i'm wondering... what issue/problem are you having with the amp ?
Robert
Sep 14, 2008 | Crown MA-5002VZ 2-Channel Amplifier
Unit turns on but goes to red
Make sure that no more that 8 ohms are hooked up for each speaker. Or whatever the rating is for that amp
Oct 19, 2013 | Crown MA-5002VZ Macro-Tech Professional...
I have a macro 2400 that needs a chip [c2527]and transistors[d6729-4][c8188-2 I want original parts the transistors in there now are not crown and sounds weak one side is crown and the blown side when it...
Your best way is google for the parts, but you need to add UP in front of the chip code (UPC2527)
and 2S in front of the transistors (2SD & 2SC), to find them.
May 04, 2011 | Crown MA 2402 Amplifier
I have a dell dimesion 2400. the usb ports will not work. What do you suggest i do o fix this problem
1. Usually this is a setting in the BIOS (Basic input/out systems) which enables the usb ports. Sometimes a firmware upgrade from the manufacturers web site will resolve this issue. WWW.dell.com ( support).
2. This could be that the usb port have been shorted out. This will require a tech to resolve at the mother board level. Most time this will require a mother board replacement.
Mar 31, 2010 | Dell Dimension 2400 PC Desktop
Crown CE1000 amps, 1 dead channel - Can I diagnose via RJ-45?
Before asuming it is the power transistors check the power on relay first as mine had the same proble and it was because of the Relay that did not switch on the one channel or amp (remember this is a power amp and consist of two mono amps)
Nov 07, 2009 | Crown CE1000 2-Channel Amplifier
Replace main board on LG 42LC7D-UB
not sure what you're referring to as a "main board", but heres the LCD Control Board for the TV
http://cgi.ebay.com/LG-42LC7D-UB-LCD-CONTROL-BOARD-6870C-0119A_W0QQitemZ150277759127QQcmdZViewItem
Mar 13, 2009 | LG 42LC7D-UB Television
Dead no power
hi change ic surface mounted u405 on back of signal board
Nov 17, 2008 | Norcent Technologies LT-2725 27 in. LCD...
900 mhz wireless speakers?
Hi Ethan,
A Google turned out that the AR model AW871 amplified wireless speakers have replaced the AW820. Same specs – slightly different appearance.
Additionally, you may want to check out here for possible AW820.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 25, 2008 | Audio Players & Recorders
116 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
