Question about Kenmore Elite 45986 Front Load Washer
My washer continually fills with water
My washer has a constant drip or small stream of continuous water coming into the washer itself. If I do not shut off the water manually, the drum will fill up over night. This has happened in the past but stopped. Now it has started again and I can't get it to quit. Please help.
  • 61 Answers
Your fill valve is stuck open replace fill valve
Posted on Sep 29, 2009
I have an MAV7600 Maytag washer the hot water fill valve drip after the cycle complates
if the washer keeps taking water and even when the washer is on the off position.
The problem could be a bad water valve.
Mar 15, 2012 | Maytag MAV7600 Top Load Washer
Frigidaire fwsb5700ds0 top load washer is dripping water from the water fill spout..why would this be occuring?
sounds like you may have a bad inlet water valve the solenoid is not closing all the way... you may be able to try and shut water off and remove hoses and clean screens out of valve itself. first unplug unit and if water continues to drip then that is going to be your problem as that elements anything electrical energizing the valve and shows you have a faulty solenoid not closing all the way...\
hope this helps good luck
Jan 06, 2011 | Frigidaire FWSB5700DS Top Load Washer
Water continues to drip into the tub even after all cycles have completed. my tub is filling up with water, I have turned off the water to the machine but it continues.
The water inlet valve needs to be replaced. It's not shutting off the water completely. It's located where the water hoses connect to the washer.
Oct 09, 2010 | Maytag Washing Machines
Washer stops by itself, have to press start continuously
I would check the inverter on top of the motor. The flashin led light is a code the code legend is on the wiring schematics behind the control panel
May 07, 2010 | GE WBSE3120B Top Load Washer
No cold water filling into washer
The water inlet valve solenoid has probably gone bad. You can check it using a multimeter for continuity. These can go bad on just one side, so the solenoid is most likely faulty on the cold water side.
Sep 20, 2009 | Kenmore 22422 Top Load Washer
Water continues to drip in after complete cycle
Check the solenoids at the water inlet valve. They can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid. I will attach a photo for reference. A bad solenoid will permit water to leak through to the tub. Hope this helped and best wishes.
Aug 30, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Water Level and Water continues to drip after cycle has ended.
The water dripping into the tub is caused by the fill valve solenoid not closing completely. The fix is to replace the fill valve. The overfilling of the washer is caused by the pressure switch. Over time the diaphram within the pressure switch becomes fatiqued & fails. The fix for this is to replace it as well... Hope this helps... Bill
May 18, 2009 | Maytag MER5775Q Electric Kitchen Range
Leak
Your inlet water valve where the fill hoses attach is stuck open.
Mar 18, 2009 | Washing Machines
Whirlpool washer continuouse water water runninng into tub
try turning the mach off while it is spinning and filling.if it continues to fill or drip heavy,the mixing valve is not closing completely and needs to be replaced.if the water stops when the mach is turned off,there is a problem with the pressure switch.
Sep 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Cold water dripping from input
It (unlikely) could be a forign voltage causing your problem. Just unplug the machine and verify the problem continues. Assuming that it does, you likely have debris inside your inlet valve. Since it not servicable, it would need to be replaced. To do this, unplug the unit. Using a putty knife or small flat blad screw driver, push on the 2 clips where the top of the washer meet the front panel while lifting the top. (a flash light will help you see these) The valve is usually held on be 1/4 or 5/16 screws. A replacement valve can be purchased from a local appliance parts store or on line from the manufacture.
Jun 09, 2008 | Amana NAV5800A Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
198 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
