ND code we have no user guide - Washing Machines
  • yadayada
    yadayada May 11, 2010
    make and model number please
Http://www.samsung.com/us/support/search/supportSearchModelResult.do?menu=SP12&searchWord=samsungfrontendloadwasher&searchInputBox=samsung+front+end+load+washer&find_button=
Posted on Jun 03, 2010
Logitech remote how do I play disc
https://www.logitech.com/assets/44645/13/harmonyone-user-guide.pdf
You must press the DEVICE button to select among the just what the remote may control. Once you select which one, the other controls on the remote (such as PLAY) work. Page 11 of the guide above mentions this device button. Note that when you are finished using the DVD, you may have to select DEVICE again to select the TV so the buttons will then control the TV. Old remotes require you to enter codes to operate extra devices and indeed the TV but I think your remote may not require such.
Jan 14, 2018 | Logitech Televison & Video
Samsung washer won't run. Ran a load then got nd code and now only makes humming sound
please go to the manufactures website to down load the user guide its usually free to download eric
Dec 24, 2017 | Samsung Washing Machines
So how do I reset the nd code or what's the quick
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Sep 19, 2012 | Cell Phones
Is samsung starr superb support .doc files nd pdf
it will be written on the user guide of the mobile so you should read that if nthing specified then mail me at vicky.akon11@gmail.com.....i will solve your problem
Aug 01, 2010 | Samsung Star GT-S5233 Cell Phone
My viewsonic va1912wb just flat-out died. Won't turn on, no lights, no response. Is there a likely cause, and is there anything user-repairable?
You have monitor with a very common problem, a dead power supply. After 2-3 years many LCD monitor power supplies will fail just like you have described. The problem is caused by parts called capacitors overheating in the tight space of the monitor case. If you can solder then you should be able to do the repair yourself. We will have a repair guide posted 12/29 after about 5:00 central time that should get you back going again. The repair guide will be on our web site at: www.ccl-la.com If you have any questions please let me know at the address below.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 29, 2009 | ViewSonic VA1912wb Monitor
Error code nD, won't go into spin cycle
Is the Machine a FAV6800A or a FAV9800A?
Do you want to DIY the fix?
The nd error code = No Drain error code.
You could have drain line clog, an issue with the drain pump or a stuck pressure switch. Do you hear the machines drain pump turn on and pump out water before entering lnto the spin cycle? Is there water left in the tub with the nd error code? If you can provide feedback on the questions above I will help guide through the troubleshooting steps.
You will need the Service Manual to troubleshoot.
The FAV6800AW/FAV9800AW Service Manual for reference. Sears Parts Direct for reference.
Rich
Dec 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
ND Error code
Error code "nd" means it is not draining. Click on this link to get the user manual:
http://laundry.manualsonline.com/manuals/mfg/maytag/mah24.html
Then click on "GET THIS MANUAL" to download the manual.
Not draining can be caused by the controller, pump, solenoid valve, or clogged drain.
If this information was useful, please select YES to the first to rating questios. Good Luck and thank you!
Oct 22, 2009 | Maytag MAH2400A Front Load Washer
Quick books error code(-6010, -100 ) Occasionally I will not be able to access my Quickbooks file. I receive error code -6010,-100. Rebooting the computer solves the problem, but this is not an acceptable...
Solution 1: For a standalone PC install of QuickBooks
  1. Choose File > Utilities > Stop Hosting Multi-User Access.
  2. Close and reopen QuickBooks. QuickBooks should now open without error.
Solution 2: Rename the .nd file associated with the company data file:
  1. Search the computer for files with extension .nd (Example: *.nd).
  2. Locate the .nd files with the name of the company having trouble opening.
  3. Right-click the .nd file, click rename and type old at the end ( for example, company.nd would become company .nd.old).
  4. Open QuickBooks.
Solution 3: If you are running NOD32 Antivirus Software with Internet Monitor (IMON)
  1. On the computer where the QuickBooks data is stored, find the NOD32 program.
  2. Disable IMON functionality.
  3. Reboot the computer.
Solution 4: Run reboot.bat
http://support.quickbooks.intuit.com/support/Articles/SLN41401
for more help step by step visit
QuickBooks Tech Support
Feb 07, 2009 | Symantec Computers & Internet
Washing Machines Logo
150 people viewed this question
Top Washing Machines Experts
