Question about Dometic Rooftop RV Air Conditioner
How to remove the complete roof top ac unit , 1980 GMC Tioga RV
  • Dometic Master
  • 6,674 Answers
Shut off Any AC power (hydro) to it, remove ceiling assy (inside part) and you'll see 4 bolts going up through lower assy, and into base of upper assy (roof unit) . Remove those 4 bolts and any wiring harness connected from lower to upper unit. Lift it off. If your just replacing the upper assy, leave hydro wires hooked up to lower assy , and let it hang, while you clean surface on roof for new install. Re-install 4 bolts and tighten equally until gasket is approx 1/2 thickness it was before tightening. Re-install wiring harness plug in to lower unit etc. If not replacing, but removing entire assy (upper and lower) be sure to Marette and tape hydro wires as well as any 12 volt wires, and tuck away safely. Install a vent on current opening , or whatever you choose.
Posted on Jul 14, 2010
Sounds like fan is clicking on roof top dometic RV ac unit, but fan is not hitting anything.
check fan shaft and blade to make sure mud dober or mouse didn't build nest in there. if they did remove it and see if it works.
May 30, 2015 | Dometic Rooftop RV Air Conditioner
My carrier ac roof top ducted unit started spitting out small amounts of water now and then, I changed filter. Now with ac in off position I am hearing a humming noise coming from the unit, what can this...
Don't really understand what you mean by roof top duct unit .if it's a roof top unit and water is leaking down your vent then you have a clogged drain line .
Mar 02, 2018 | Dometic Rooftop RV Air Conditioner
Need to replace inside AC control switch (Coleman) on 1977 Tioga RV.
If controls are at the ceiling, get model and serial number off bottom of upper (roof) unit and stop at an RV service, and sales place and see if they have new in stock. If not they should be able to order you a new one for around $100 Cdn. You get the whole ceiling assembly . Or contact : http://www.rvcomfort.com/rvp/tech_info/parts_doc.php
Jul 28, 2011 | Heating & Cooling
RV AC is working fine, but the water is leaking from the ceiling Where is the drain tube on the unit, The AC unit is a roof type, Duo Therm serial # 43404934, Part # 3105459
Normally, the condensate will drain out of the unit onto the roof and off the edge to the ground. Remove your cover inside (probably 2 screws) and tighten the 4 bolts you will find inside. If they are tight, go to your RV supply place and get new roof gasket. Remove the AC and insert the new gasket and resecure the AC to your roof.
Thanks for your question @ FixYa.com
Jul 26, 2011 | Dometic Rooftop RV Air Conditioner
Hi' I have a coleman roof top AC unit on a 1991 Tioga i just purchused a couple of months ago! When i turn on the AC it makes a humming sound...no fans spin or no air comes out! If i let it hum for...
The blower motor is seized up...you will need to get up top and remove the cover...then remove the fan blades and the motor and replace the motor....sometimes a temp. fix will be to get WD-40 and then oil worked into the bearings...but that is usually a very short lived fix...
Replacing the motor can be frustrating and time consuming, so you may want to hire someone to do it for you...you may also find that a replacement unit is more cost effective..
heatman101
Jun 14, 2011 | Dometic Rooftop RV Air Conditioner
Was given a roof top ac for a popup camper need help
Make and model of unit should be on base of roof assy, please reply with that so we can be sure we have right wiring info for you. Although they are pretty common, let's be sure.
Jul 30, 2010 | Dometic Rooftop RV Air Conditioner
Roof top A/C cover removal
The covers just have screws that go from the top down through that hold them on. Once the screws are removed the top cover should come off the bottom I am not sure about the bottom one the whole unit may have to come off for that one.
Jan 13, 2010 | Dometic Rooftop RV Air Conditioner
How difficult / expensive is it to install a heat strip in a Dometic roof top AC? The unit I have has a mark on the knob for heat, but I suspect it was never installed.
Fairly easy. The only thing that you must figure out is how many amps the heat strips will draw. Make sure the fuses and the breaker switch can handle them. And be aware your electric bills will shoot up.
Oct 20, 2009 | Dometic Rooftop RV Air Conditioner
Seal for roof top ac unit
I just spoke with the mechanic at my RV dealership and he said the sticky side goes on the a/c unit. You only have to turn it on it's side to do this. Just wait 1 hour after re-installing the unit on your RV before turning it on.
Apr 17, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
241 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
