Question about Eiki LC-XG210 Projector Multimedia Projector
Fan Failure Error
I was receiving a Fan Failure error. I am well out of any warranty period as the unit is nearly 5 years old so I opened her up and found that one of the front two fans was locked up. I pulled the part number off the fan and ordered a replacement. The fan hooks up with +12V, Gnd, and a Sense line. No problem. I replaced the fan and the unit powers up just fine and spins all 3 fans nicely. However, after about 30 seconds the unit shuts down with a Temp light. I then took a table top fan and powered the unit up with this 'added' cooling. Again the unit ran for 30 seconds and shut down with a Temp light. I know the unit is definitely NOT overheating at this point. Does anybody know if the temp sensor goes bad or if there is a cap or resistor that fails? Anything else I should look for?
Oh yeah, my bulb only has about 500 hours on it. My previous bulbs all lasted 2,500+ hours.
  • 2,237 Answers
The temp sensor probably wore out when the fan did. just replace the sensor. usually located on the lamp housing or near the fans. looks like a transistor.
Posted on Nov 17, 2009
Solution for u2 error
it sound like the outdoor pcb has failed, if your unit is less then 5 years old it will be under warranty. if your unit is a rxd50/60/71jvea it will be a fan motor and pcb
Mar 16, 2012 | Cfm Daikin R410a Split System Air...
On the circle 1 part red says systemm error e74
You are experiencing a hardware failure, better know as the red ring of death. Microsoft recomends the following
Step 1: Confirm the E74 error loadTOCNode(2, 'moreinformation'); To verify that your console is displaying the E74 error message, follow these steps:
  1. Turn off the console.
  2. Turn on the console.
  3. Verify that your console displays the E74 error message.
Step 2: Submit a console repair request loadTOCNode(2, 'moreinformation'); If you are experiencing this problem, your Xbox 360 console must be repaired at our service center.
Start the repair process online. (http://service.xbox.com/)
For more information about how to contact Xbox Support directly, please visit the following website: www.xbox.com/support/contact (http://www.xbox.com/support/contact) Microsoft covers repairs for the E74 error for a period of three (3) years from the original purchase date of the console. If you are outside the initial three-year warranty period, you can still receive console repair service from Microsoft for a fee for the E74 error. For more information about the E74 warranty extension, see the following article: 969905 (http://support.microsoft.com/kb/969905/ ) About the E74 warranty extension for Xbox 360 consoles
Jul 30, 2011 | Microsoft Xbox 360 Console
Sreen system error e 74
This problem occurs when the Xbox 360 console experiences a hardware failure. To verify that your console is displaying the E74 error message, follow these steps:
If you are experiencing this problem, your Xbox 360 console must be repaired..... Microsoft covers repairs for the E74 error for a period of three (3) years from the original purchase date of the console. If you are outside the initial three-year warranty period, you can still receive console repair service from Microsoft for a fee for the E74 error.
https://myservice.xbox.com/en-us/Pages/Welcome.aspx
Jan 01, 2011 | Microsoft Xbox 360 Console
Tv desn't turn on,power light just flashes ten times and then stops and then again
Error Indication Information
Error No. Error Information ERROR DESCRIPTION LAMP LED OSD LAMP OFF
(Note 3) (Note 4)
POWER LED TEMP LED
Note:
1.When any of the above errors has occurred, the LED will flash as shown above every 5 seconds.
2.When two or more errors have occurred at the same time, the LED will light up or flash as shown above, and then
change to another every 5 seconds in turn.
3.Warning OSD appears when the Air Filter is clogged 90%, accumulated operation time of the Lamp reaches 5000 hours,
or accumulated operation time of the Air Filter reaches 400 hours.
4.LAMP OFF: The LED will flash right after the Lamp goes off.
5.IC2301 is mounted on LCD Main C.B.A. which is included in the Projection Unit.
6.IC6001 is mounted on TV Main C.B.A.
Clogged air filter
more than 90%
15)
16)
17)
18)
1)
2)
3)
4)
5)
6)
7)
11)
8)
9)
10)
12)
13)
14)
- flashes 5 times -
every 5 seconds
IC2301(pin82) detects the clogged air filter, then indicates the
error when the air filter is clogged 90%.
Front Fan stop or
Lamp Fan stop
flashes orange
once every
5 seconds
IC2301(pin12) detects the Front FAN stop or Lamp
FAN stop, then indicates the error when the Front FAN
or Lamp FAN is stopped.
Lamp Cover open
Temperature Sensor
short or open
flashes orange
twice every
5 seconds
flashes orange
3 times every
5 seconds
flashes green for
140 seconds.
flashing red for
60 seconds.
light up red.
flashes once
every 5 seconds
flashes once
every 5 seconds
flashes red for
10 minutes
flashes once
every 5 seconds
Abnormal
Temperature
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Request for Lamp
Replacement - - lights up
Power Ballast Error
(abnormal
Lamp voltage)
flashes 3 times
every 5 seconds
Power Ballast Error
(abnormal
temperature)
flashes 4 times
every 5 seconds
Power Ballast Error
(other causes) - -
Request for Filter
Cleaning -
Abnormal Voltage
on 16 V line of
LCD Main C.B.A.
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Abnormal Voltage
on 14 V line of
LCD Main C.B.A.
flashes 3 times
every 5 seconds
flashes 3 times
every 5 seconds
Abnormal Voltage
on 7 V line of
LCD Main C.B.A.
flashes 4 times
every 5 seconds
flashes 4 times
every 5 seconds
IC2301(pin76) detects the Lamp Cover Unit condition
(open or close), then indicates the error when the
Lamp Cover Unit is open.
IC6001(pin85) detects the Duct FAN stop, then
indicates the error when the Duct FAN is stopped.
IC2301(pin74 and 75) detects open or short of the Temperature
Sensor (R2911) on Front Thermistor C.B.A., then indicates the
error when Temperature Sensor is open or shorted.
(The error is not detected for 1 minute after Lamp ON.)
IC2301(pin74 and 75) detects the temperature attached near
the Front FAN by the Temperature Sensor (R2911) on Front
Thermistor C.B.A., then indicates the error when the
temperature becomes more than 43 C (109 F).
IC6001(pin86 and 87) detects open or short of the
Temperature Sensor (R2901) on Lamp Thermistor C.B.A.,
then indicates the error when Temperature Sensor is open or
shorted.
(The error is not detected for 4 minutes after Lamp ON.)
the Lamp by the Temperature Sensor (R2901) on Lamp
temperature becomes more than 60 C (140 F).
IC2301(pin11) detects the error of LCD Power C.B.A.,
then indicates the error when the temperature fuse
(117 C)(243 F) in LCD Power C.B.A. is open.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp
is cracked.
IC2301(pin11) detects the error of the Lamp, then indicates the
error when the Lamp is short-circuit.
IC2301(pin48) detects +16V line voltage on LCD Main
C.B.A., then indicates the error when the voltage
becomes less than +13V.
IC2301(pin47) detects +14V line voltage on LCD Main
becomes less than +11V.
IC2301(pin45) detects +7V line voltage on LCD Main
becomes less than +5.7V.
IC2301(pin44) detects +3.3V line voltage on LCD Main
becomes less than +2.5V.
flashes 3 times
every 5 seconds
flashes 4 times
every 5 seconds
Abnormal Voltage
on 3.3 V line of
LCD Main C.B.A.
- flashes 5 times
every 5 seconds
Forced cooling
The failure of Lamp
light up
Temperature Sensor
short or open
Abnormal
Temperature
Duct Fan stop -
When accumulated operation time of the the Lamp reaches
5000 hours, OSD (replacing the Lamp) appears on the screen.
Note: The Lamp time is stored in EEPROM (IC2305).
When accumulated operation time of the Air Filter reaches 400
hours, OSD (cleaning the Air Filter) appears on the screen.
Note: The Filter time is stored in EEPROM (IC2305).
During forced cooling, this indication is indicated.
IC2301 (pin11) detects the failure of light up processing of
the Lamp, then the POWER LED is changed as follows.
1) POWER LED flashes green for 140 seconds (while turning on).
2) POWER LED flashes red for 60 seconds (while cooling).
3) POWER LED lights up red (standby).
Note: If the Lamp will not light after attempting turning on the
power 2 or 3 times, the Lamp, the LCD Power C.B.A. or the
LCD Main C.B.A. may be defective.
Error Symptom Problem Possible Solutio
May 30, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Acer Aspire 5570 getting SMART failure error on HDD
Definitely a hard drive problem, you'll need to replace the drive and reinstall all the software.
Apr 04, 2010 | Acer TravelMate 507T Notebook
I have an admiral refigerator (top freezer) less than 3 years old. The unit sat in a vacant house unplugged for about a year and now will not cool. Any suggestions
Good day,
Check in the freezer compartment to see if you can hear the fan motor running. They will freeze up if left off for extended periods of time.
Another fan motor on the bottom back near the compressor can suffer the same fate.
If both check O.K. Then since it's under 5 years you could have a refrigerant leak or a compressor problem that is under factory warranty.
Call your selling dealer for service.
Feb 05, 2010 | Maytag Admiral Top-Freezer Refrigerator
Unit will not run.
Error code 01 - unit has a sealed system leak; most warranties are 5 years.
Dec 30, 2009 | Kenmore 54701 Dehumidifier
Epson Stylus CX3200 Error
Possible scanner failure.
Turn off your printer. Disconnect it from your computer. Toggle the transportation lock on the scanner unit if there is any. It has to be in the unlock position. Turn the printer back on.
If your unit is not yet a year old, please contact epson for your warranty options.
To help you find an epson certified servicer near to your area, please log on to epson.com.
Apr 28, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Toshiba Satellite Laptop Cooling Failure
The fan has failed - warranty if in the time period since purchase.
Jun 30, 2008 | Toshiba Satellite Laptop Cooler
LG refrigerator error message ER IF
ok if unit is under 1 year old call a tech because you might need a new motor fan and new main board . make sure you out let is properly grounded
Jun 30, 2008 | LG LFX25960ST Stainless Steel French Door...
Eiki LC-XG210 Projector Multimedia Projector Logo
1,244 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
neOen
Level 1 Expert
Jaime Hernandez
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
