Big Screen RCA Tv Model #P60923BL or OM60923BL
No power.. Could it be a fuse? Where is the fuse box?
  • bamones Dec 20, 2007
    Thanks.. it worked!!!
    Novelist:
    Champion:
  • 232 Answers
Bamones, it`s possible but not likely, remove AC cord from wall outlet, remove back from set and follow the AC cord where it goes into the set, fuse is right beside where the AC cord attatches to the board, if the glass is black you have a dead short in the power supply, if it`s open but not black then try replacing the fuse, amperage is marked on the silver metal end of the fuse, look for a number followed by the letter "A". Example;
5A 125V would be a five amp fuse rated at 125 volts, DO NOT replace with any other value, good luck, BMW Rider
Posted on Dec 19, 2007
I need a new screen protector for my older RCA big screen TV
I have a screen protector from a 1998 RCA older model big box style tv
Mar 15, 2010 | RCA P56930BL 56" Rear Projection...
How to remove high voltage distribution box rated at 250 volts this is problem with rca model p60923bl tv no power on press power on button tv clicks 3 times and turn off no picture.
If you are talking about the HV splitter in the front of the set----remove the front grill(screws behind set on either side) and then the inspection plate behind it----the splitter will have a red wire coming from the HV transformer and 3 more red wires going to each of the picture tubes--If the splitter is bad remove the wire from the high voltage transformer that goes into it(it should pull out and if may be hard to get it out) with it out and not touching anything (isolate it well clear of anything) the set should then come on and you should hear a hiss from the wire you removed---if the set stays on shut it off quickly and replace the block---most of them are available on the internet at a reasonable cost.
hope this was helpful.
Aug 11, 2009 | Televison & Video
BIG SCREEN rca d53w19, where are the fuses????
There is one fuse if you look in the rear of the set on the left side follow the power cord as the cord plugs into the Main filter board which has the fuse. Its located right next to the power cord on the right side of that board
May 27, 2009 | RCA D52W19 52" Rear Projection Television
Line up red blue yellow
hello it sound's like you need to set your. convergence on your set. or you will need to replace the (ICchip's ) on your convergence board. to fix the problem. your having. !!! me know after you try to reset the convergence on your set. and we can go from there."GOOD LUCK" and thank you
Jan 03, 2009 | RCA Televison & Video
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Rca 52 in rear projection... start up menu always on
The setup menu will repeat until it is completed and/or something is hooked up.
On my TV it kept reoccurring until I connected up the wire from the roof antenna, even though I had cable already installed.
Check your manual for setup instructions or if you do not have one, Google the make, model number and "owners manual" to see one online.
Hope this helps. :)
Mar 31, 2008 | Televison & Video
No power no sound
oh noh!!! I suggest you should an AVR (automatic voltage regulator), these will help to control the flactuations of power. try also check the power supply (its either 110 or 220 volts), just make sure it is compatible to your default power supply.
Feb 05, 2008 | RCA HD52W58 52" TV
RCA big screen tv
whenever fuse blows every time it is the indication of short circuit in tv. so please do not put fuse unless you know the cause of blowing fuse. these are the reasons of blowing fuse. 1 main filter cap.short. 2 rectifier diode short. 3 swithing transistor short 4 horizontal output transistor short 5 caps & diodes connected to flyback transformer short. 6 print short. 7 at last if every thing ok then flyback transformer defective. hope this will help. if you are not a tech person call skilled tech to fix it. good luck
Sep 24, 2007 | RCA P60828 TV
RCA 52" Big Screen TV model;P52920BL Chassis;PTK195KB PICTURE BOWED AFTER FUSE BLOWN.
You have bad convergence IC's.. If your not experienced in troubleshooting electronics or soldering, you should have a trained tech take a gander at the set. Its not worth risking life and limb to save a few bucks, Good Luck
Jul 30, 2006 | RCA P52920BL 52" Rear Projection...
Televison & Video Logo
120 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
