Question about Ryobi 18v Variable Speed Right Angle Drill Modelzrp240
How does tha paper go onto the sander? - Ryobi 18v Variable Speed Right Angle Drill Modelzrp240
  • 108 Answers
It is a drill, not a sander.
Posted on Oct 11, 2009
How do I change the paper?
I'm not familiar with that particular model, but they are virtually all replaced the same way. There are a few screws through the pad into the base. Simply remove them and screw the new pad on. You'll see that it's quite simple once you get the new pad in your hands.
Just be careful not to strip the head of the screw: use the right size screwdriver tip.Refer more on custom essay writing service
Custom Essay Writing Dissertation Writing Thesis Writing with Free Draft...
Jan 09, 2016 | Tools & Hardware - Others
How do I install paper to Skil Dual Action Sander model # 7372?
Sander has 2 slotted rotating rollers one on each end the paper gets fed in as you rotate roller, which will grasp paper and hold, feed/wind roller with slotted screwdriver till paper secure. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Skil nbsp7372 TYPE 1 nbspDUAL ACTION SANDER 348542
Jul 28, 2014 | Skil Tools & Hardware - Others
When I bought my sander it has what i would describe as a rubber pad onj the sander. Is this the sanding pad?
That sounds right. It is probably the type that uses adhesive backed paper. You stick the paper to the rubber pad.
Jul 14, 2012 | Dewalt DW 411 HAND PALM SANDER
Can't figure out how to load the sand paper on to the mouse sander
Just stick the sand paper sheet to the base of the mouse sander... it's velcro it will hold... match the forme of the paper with the forme of the sander's base... that's all...
Cheers!
Aug 06, 2011 | Black & Decker Mouse Sander/Polisher
How to replace the sand paper on skil sander hi speed 439
the skil 439 is a palm orbital finish sander. To replace the paper, pop the springs off the side where they take a 90 degree turn towards the work surface. To replace paper, rip a piece of standard sand paper into quarters, reverse removal and done. It's a pretty nice older sander and yes I have one.
Jul 11, 2011 | Garden
How do I secure a piece of sandpaper on the dewalt orbit palm sander?
I think your model holds the paper with glue that is on the sand paper.Just take apart the back cover of the sand paper to expose the glue.
Nov 08, 2010 | Dewalt DW421 5'' orbital sander
How do you replace he belt on a 7447 Sander
To change belt:
1) Put front roller on floor and push down until roller locks back.
2) Put on new sand paper.
3) Loosen tracking screw until front roller is released.
4) With sander running, use tracking screw to center belt.
Oct 10, 2010 | Black & Decker BR300 3''x18'' Belt Sander
I am recently widowed and don't know how to get the sand paper out of and onto the sander
At both ends of the bottom pad, there are metal fittings that have a rectangular hole in the middle of them. Take a regular head screwdriver and put the tip in the hole and carefully but firmly lift up and hold while at the same time pushing the narrow edge of the 1/3 sheet sandpaper up under the metal piece which kind of looks like a C on its edge. Then let down the metal piece with the screwdriver and that edge of the sand paper should be held in place. Do the same thing for the other end of the sandpaper, making sure to pull the sandpaper sheet tight against the rubber pad.
Oct 08, 2010 | Black & Decker 7448 1/3 Sheet Orbital...
How do I change the sanding belt on my 7447 belt sander
To change the belt, you must release tension of the rollers by pushing the front roller straight back until you hear it click and lock in position to change paper. Remove old paper and replace with new paper. Make sure if new paper has directional arrows to install properly.
Now you must release the front roller to put tension on paper. To do this push the front roller from the side that has the adjustment screw. This will release the front roller and allow it to go back into position. Be careful as it pops back quickly and with some force.
Turn on sander and adjust centering of paper with adjustment screw found near the front and side of sander.
Aug 27, 2010 | Black & Decker 3"x21"HD Vs Belt Sander
The foam part that forms the base onto which you can attach self adhesive sand paper to has fallen apart and I need to purchase the replacement foam and or aluminum backing plate
I think I found what you are looking for ... when you get there click on the picture of the type you have and follow through to check out.
Hope this helps,
RSMITH972278
P.S. PLEASE DON'T FORGET TO RATE ME !
Oct 14, 2009 | Porter Cable Cable 0330 Speed - Bloc...
Ryobi 18v Variable Speed Right Angle Drill Modelzrp240 Logo
24 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
