Question about Toshiba Satellite A35-S1592 Notebook
Toshiba Satellite A35 S159 AC PROBLEM Can a laptop run just on the ac without the battery? I just watched a video on youtube and the guy said if you want to save your battery you can take it out and run on straight AC adapter power I am having problems while AC is plugged into computer and wall outlet that my computer starts acting like its only on battery power and doesn't recognize the ac is actually plugged in. Someone here said to clean the battery connectors with alcohol and q tip. Can't it just run without the battery if I take the battery out? There are some very useful techniques on the internet on getting your battery to last longer. Like letting it run out occasionally, changing your power settings, screen lighting, etc.
  • 687 Answers
Yet you need to set up what is called a hardware profile so that you can use the Laptop on either AC power only or on AC Power and Battery. Although it is normally used for docking it can still be used for the battery.
One profile for the office where the laptop is docked and the network adapter enabled, and a second profile can be created for use when you are working away from the office that disables the network adapter but enables the modem.
To set up hardware profiles in XP, complete the following steps:
  1. On the desktop, right click the My Computer icon and select Properties.
  2. From the Hardware tab, click the Hardware Profile button.
  3. Under the list of available hardware profile, select Docked Profile or Undocked Profile and click Copy.
  4. Type in a new name for the profile and Click OK.
  5. Select the new profile and click Properties. Select the check box beside This is a portable computer. Select the docking state for the profile. Click the option to Always include this profile when Windows starts. Click OK.
  6. You can now use Device Manager to enable and disable devices for a hardware profile.
Some people do say that if you totally discharge a rechargeable battery and then fully recharge it you will get a greater AmpHour from it but this will be negligible as all batteries have a standard number of Amps that it will deliver built into it, it may fall with age. Although rechargeable batteries don't just fail like normal dry cells they tend to fail over a period of time and fool us a bit.
LOL
Posted on Sep 28, 2009
  • SpideRaY
    SpideRaY Sep 28, 2009
    Almost forgot you will need to go into the Device manager and disable the the correct subdivision normally at the top of the
    - (your PC's name)
    +Batteries
    +Microsoft AC Adapter.
    +Microsoft ACPI Compliant Control Method Battery (disable this on the AC Only profile)
    Rename the existing profile to AC + Battery Power and copy and rename the new one to AC Power Only
    NOTE: This will only work on a laptop as desktops don't have a rechargableable ACPI compliant battery to disable.
    LOL
2 Suggested Answers
  • 173 Answers
SOURCE: Toshiba A35-S159 Recovery and Applications/Drivers DVD
check this link and it will fix your problem
http://www.csd.toshiba.com/cgibin/tais/su/su_sc_modItemList.jsp?moid=510753&rpn=PSA30U&ct=DL&BV_SessionID=@@@@1769039768.1195802154@@@@&BV_EngineID=cccgaddmijfjmdecgfkceghdgngdgmn.0
if you have any more queries rever back..
Posted on Nov 23, 2007
Can't find hard drive on my toshiba satalite toshiba a35-s159
1) Make SURE you remove ALL power before removing the Harddrive.
Remove the AC adapter (Charger) and Battery.
2) http://www.irisvista.com/tech/laptops/toshiba-satellite-a35/complete-disassembly-1.htm
Page 3
Go down to Steps 19 and 20. Click on the photos to enlarge,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a35/complete-disassembly-3.htm
[ The page numbers are in white at the Bottom, and Top of the pages.
Page1::Page2::Page3::Page4::Find another model ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 17, 2012 | Toshiba Satellite A35-S159 Notebook
The power jack is broken and I need to replaced it. I have one available now but looks like I need to remove the mother board from the laptop. How is that done?
with great difficulty, you may be in luck and find an online guide with video on youtube.
There is a service guide for the A30, this should help with stripping the laptop, it takes a while to load, http://tim.id.au/laptops/toshiba/satellite%20a30.pdf
Oct 05, 2010 | Toshiba Satellite A35-S159 Notebook
Toshiba A35 S159
you forgot the most important item in the whole equation the battery.How long will the computer stay on with the battery?One quick fix,try using a toothbruch to clean the contact on the battery and on the computer.This might work.I think the computer is fine. The battery might be bad,
Sep 28, 2009 | Toshiba Satellite A35-S159 Notebook
I need to install drivers for a35-s159.The Toshiba support page no longer supports this model.I need the modem and Ethernet drivers according to my hardware mngr
Wow, I can't believe they removed it from their support page. bummer.
You can try a simple Windows Update.
It should detect the missing drivers.
Let me know if it doesn't.
Jun 15, 2009 | Toshiba Satellite A35-S159 Notebook
TOSHIBA
You can purchase it here. Click on system boards to view the boards available for your model.
Thanks and please take a moment to rate as fixya.
Dec 05, 2008 | Toshiba Satellite A35-S159 Notebook
A35-S159 TOSHIBA satellite
Toshiba no longer supports the A35-S159 laptop.I found my drivers here free! http://www.gzrcw.net/drivers/toshiba/Satellite/drivers_1176.html
Sep 26, 2008 | Toshiba Satellite A35-S159 Notebook
Lcd toshiba A35-s159
your correct the lcd inverter or the lappy lcd bulb is shot
ebay toshiba satellite a35 lcd inverter buy that link me
bakerandre2000@yahoo.com i walk you you need a screw driver
Apr 12, 2008 | Toshiba Satellite A35-S159 Notebook
Toshiba Satellite A35-S159 Shut down
If it does the same thing when it's plugged in, it might be time for a trip to the service center.
Mar 21, 2008 | Toshiba Satellite A35-S159 Notebook
Will not power up
pull battery and cord. push on / off button for 60 sec. put battery back in and plugg in power and boot up.. something else to try is some one elses battery to boot up in.
Jan 07, 2008 | Toshiba Satellite A35-S159 Notebook
Toshiba Satellite A35-S1592 Notebook Logo
311 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
