Question about Epson Stylus Pro 7800 InkJet Printer
Service call error 100000 EO printer driver doesn't match control panel
    President:
  • 1,653 Answers
This is actually a CPU address Error (load Misalignment)
This is caused by a defective circuit board of faulty soldering on the CPU, program issues or a generation error.
The recommended remedies are to reload the firmware with the latest available firmware from Epson and if unsuccessful replace the main board (C472 MAIN).
You can download the latest firmware and drivers from Epson Support at
http://www.epson.co.uk/Printers-and-All-In-Ones/Large-Format/Epson-Stylus-Pro-7800/Drivers-Support?supportLandingPage=true
Posted on Sep 28, 2009
My printer won't print. my computer is hooked up to it, and it doesn't give any error messages. it just doesn't do anything.
Go to Control Panel/Printers. Right click on your printer's name, and hit Print Test Page. If printer prints a page out, then the problem is likely with the software you're using to print - make sure you have selected the right printer in the dropdown. If the printer's name doesn't show in the Printers folder of Control Panel, the driver for it has not been installed. Do so and try again.
Jun 18, 2011 | Lexmark X2670 All-In-One Printer
Spooler service is not running Model Z32
There are several ways to resolve printer spooler error, probably because there are many variations of this error.
The error caused by faulty software can be resolved by deleting all the information found in the directory.
Thereafter, navigate to the Control Panel, click on Administrative Tools and then services icon.
Find the service labeled Print Spooler, highlight it and restart the process. If that doesn't work, the program might be corrupted.
Click on start, then Run. Search for the document labeled services.msc, and this will trigger the opening of another window.
On this window, scroll down and click "Print Spooler". Check its setting and turn on automatic mode.
Click Okay, and restart the machine. If you're lucky, this might be all you have to do.
Still doesn't work? Navigate to the Add/Remove Programs screen of the Control Panel.
Find the all the software responsible for making the printer run including the drivers, and uninstall them. Be sure to be thorough about it, or the problem may not be solved.
Download the latest copy of your printer's software from the manufacturer and reinstall it.
May 17, 2011 | Lexmark Office Equipment & Supplies
Error message spooler subsystem app not working
Apr 12, 2011 | HP Photosmart C4480 All-In-One InkJet...
The printer spooler service is not running.
Ok go START>>RUN>>type in services.msc and press enter. When the services window comes up, scroll down until you find Print Spooler, double click on it, and set it to Enabled and Automatic, Start it, & reboot. this will enable your print spooler.
Feb 22, 2010 | HP LaserJet 1020 Printer
Electric kitchen aid double oven gives eo message
there should be more of a code like fo/eo or f2/eo or f3/eo or f5 /0o .. if you have # 1 = analog t digital l failure / replace control..= #2 shorted key pad / = replace control /? # 3 oven tempt sensor = repl oven sensor or fuse .// # 5 ck door /latch sw = replace component .. hope this helped . mm ( re/ck codes and see if one of thes matches your problem .. mm pls leave feed back ..
Dec 12, 2009 | Washing Machines
Memory error 100000
This indicates that the Black Cartridge has a memory chip error or is missing. You will need to remove the cartridge and make sure there is no protective covering over the chip area orf the cartridge and then reinstall it. If the issue persists then try using a new cartridge and if it still persists you will need to call a service engineer or take the unit to a repair shop.
Jun 29, 2009 | HP LaserJet 3600n Printer
6010 error canon pixma mp600
You did not state which version of windowns that you are using . Try this . Go to the control panel printers and delete the printer. Go to the canon website and get the software drivers for your version of windows.  Instal the printer using the windows install routine telling it where the driver is located when it asks. If this doesn not work , pleas ewrite back. I am not positive as I dis seardches on you error code and am fairly certain that the code means wrong driver for OS.
http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
Dec 14, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Error message EO F2
that fault refers to a shorted key panel, recommended repair is to replace replace Electronic Range Control/Clock (erc)
Feb 24, 2008 | Kenmore 95592 / 95594 / 95595 / 95599...
Epson Stylus Pro 7800 InkJet Printer Logo
127 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
