Question about Troy Bilt Tb70ss Gas Trimmer
How do you rewind the pull string? - Troy Bilt Tb70ss Gas Trimmer
2 Suggested Answers
  • 13 Answers
SOURCE: Describe your troybilt tb70ss pull string Problem.
Do you have mfg instructions? Can be very tricky without following instructions
Posted on Sep 29, 2009
The pull string isn't pulling back into
while it is apart turn it counter clockwise. you will be able to tell in the first few turns if your going in the right direction
Oct 11, 2014 | Garden
Pull string is to loose
as big as a pain it is. you have to unscrew the pull mount and rewind it outside the wheel. they tend to loop over the top and this happens when you pull hard and let it snap back by letting it go. cord loops over the top. next time you pull it pulls it over the top and each time you do it, it becomes looser.
Apr 21, 2014 | Troy Bilt Tb70ss Gas Trimmer
My craftsman incredi-pull gas powered trimmer/edger's string wont go back in
The rewind is sticking due to congealed grease, take the rewind off (as a complete unit) soak in hot strong soapy water pulling the string in and out to help flush the dirty grease out from around the pulley and spring. Once you feel it is cleaned allow it to dry and then apply a squirt or two of a dry lube like the graphite used for locks.
Mar 03, 2010 | Craftsman Garden
Sep 29, 2009 | Troy Bilt Tb70ss Gas Trimmer
Pull string for Weed Eater Featherlite Plus came out
If you have the starter spool out (the one the rope goes in)...Here is what to do. Take the starter spool and change the rope out putting it back exactly as it was. Leave the rope hanging. Hold the spool and set it down on the rewind spring. Turn the spool on the rewind spring until you feel it is tight enough. While turning, hold the rope in the little slot in the spool so it can go around without hanging up. Once it is tight, get the rope in line with the spool opening and SLOWLY let the rope rewind. Put on the handle and put the unit back together.Good luck...Lee
Sep 06, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Pull string broke on crafstman 6.75 mower
when the rope broke you first must rewind sring and load tension on it first then install spring while it is underload clamp with vise grips until string is fed through then release slowly allowing string to recoil
Jul 15, 2009 | Toro Lawn Mower With Toro Power Tools
Won't retract the pull string
The pull cord assembly either has something jammed in there or it's busted. Take the 3 or 4 bolts out that hold in on to the top, and inspect it for damage. If there's nothing in there or it's not damaged it might have just slipped off the spring. Rewind your cord and reinstall it.
Jun 27, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Troy Bilt Tb70ss Gas Trimmer Logo
74 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
