Question about Kenmore Dryers
The plastic pieces inside the drum came off. - Kenmore Dryers
  • 61 Answers
That is called a baffle lift top of dryer up and replace missing screws in baffle
Posted on Sep 29, 2009
There is a plastic oval piece that fits between the inside of dryer door and outer drum. This piece broke apart. Is this the cause of the noise when dryer is on? Close can easily get caught between frame...
Most frigidaire dryers have front felt seals with nylon slides on top that the front of the drum rides on. Without M# can't be sure if yours is like this.
Dec 28, 2010 | Frigidaire Electric Dryer
Hotpoint aquarius wm64 loud banging noise when spinning with full load no noise when spinning empty i have found small pieces of plastic inside drum
Several possibilities here.
First and fore most is the drum support or main drum bearigs are failing., more likely to be drum support
The pieces of plastic you refer to are from inside the outer drum, because what is happening is the inner drum is catching the outer drum, and breaking the plastic inside.
You are going to have to strip it down to determine the exact cause, what I expect you will find is that the alloy 3 legged drom support has corroded away,a nd the drum has come loose.
Hope this helps you solve your problem
Nov 28, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Loud noise that sounds like a train coming from drum
Check inside the drum for loose plastic bars that run front to back. You will need to release the top to tighten them if they exist. With top open, check the drive belt condition and replace it if it is cracked, pieces missing, or running loose. To release the belt, open a panel in back and release whatever creates tension in the belt (usually remove a large spring). With belt off, turn the drum by hand to check the rear bearing and whatever provides a bearing for the front edge of the drum--some dryers use plastic plates on the cabinet side for the drum to turn on, and others have actual rollers that the drum turns on. If rollers, check each one for missing pieces or warped surfaces of the rollers. If plates, check each one for wear through to the metal. Hope this helps.
Nov 17, 2009 | Computers & Internet
Bra wire stuck between the drums in hotpoint WD440 Aquarius washer dryer
Look all around the inner tub with a torch , if you spot the wire sticking through grasp it firmly with pliers and pull out , dont let it go , if it slips completely between drums it is more difficult to get to.
Nov 08, 2009 | Hotpoint Aquarius WD63 Front Load...
Something rolling inside the Drum
The rear half of the outer tub, with bearing is part # 131525500 and it looks like the back "spider" shaft is not available as a separate part from the inner drum. The "spider" shaft is most likely worn or damaged and in need of replacement also.
131618500
Then, there's that strut
134564200
Now, two pain in the back side hours of your labor and you've got your washer back, at more than what a new one would cost! Junk it and get a new larger capacity front loader.
Please don't rate this, as anything but the top rating will lower my score. I'm just giving you my honest opinion, that your machine is not economical to repair. I've owned a LG front loader for over 6 years and think they are the best, but there are other good front loaders out there also.
May 19, 2009 | Frigidaire GSTF1670A Front Load Washer
Money (change) caught inside interior drum plastic pieces.
Remove the top lid.
Rotate the drum until a vane is at the 12 o'clock position.
Remove the screws from the drum holding the vane in place.
May 10, 2009 | Kenmore 63942 Dryer
How to take apart drum assembly on kenmore front load washer
Is this a HE2,5,4 model? Can you give me the model number from inside the door. If it's a front loader. The only way you can get it out is to totally tare it down, cement, springs, shocks, and crack apart the outer tub. Very very labor intense. Usually if the unit is out of warranty, the cost of a tech to do it isn't worth it. What's the issure with it?
Jan 24, 2009 | Washing Machines
Whirlpool Ultimate Care II drum does not spin.
Depending on your washing machine model, the drum and motor are connected by 2 plastice yellow circular pieces, with a black rubber washer in the middle with holes where the pegs or rods go into. The 2 plastic circular pieces have 3 pegs or rods if you will, that connect to the black rubber washer via 3 holes. Sometimes, one or both of the 2 plastic circular piece pegs get broken off or the rubber washer cracks and breaks apart, so that the motor will not turn the drum. If thats the case, you can purchase the 2 circular pieces and black washer piece as a set.
Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Dryer putting black smears on clothes
The white plastic pieces just inside the font of the drum are the front bearings there are aboutfour of these, you will need to take the front of the machine to put them in, your clothes are probably picking up black smeres from where the plastis bearings have worn.
Oct 18, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Need to replace direct drive drum on Kitchenaid Superba side by side
May need to know your entire model # located on the inside in the refrigerator section. That plastic piece may unscrew but be a reverse thread.
Oct 07, 2007 | KitchenAid Superba Architect KSCS25INSS...
Dryers Logo
66 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
