Question about Sharp AR-208D Printer
How add developer to sharp ar-208d
Need to know how to add developer power to a sharp ar-208d. my copies are all coming out blank.
Set-up for this copier sure isn't well-documented. We just got ours working today, by following the instructions here: https://www.businessneedz.com/Manuals/ar168s_setup.pdf (yes, it lists a different model number, but the instructions worked, and were linked from the ar-208d product page from the supplier)
Posted on Feb 23, 2010
Error Code F2 - 64 of photocopier Sharp AR 5816s
If you have the install disc , Go into remove programs and uninstall it . then reinstall it . up date as there may be a new driver for it.
Feb 25, 2015 | Sharp Ar-208d Duplex Copier, Printer,...
Developer in my sharp ar-5520s mfp
if you want change developer,pullout toner cartridge open blue screw,remove developer unit ,open 3 screws,remove black cover remove old developer and add new
Apr 30, 2010 | Sharp SF 2020 Copier
No need developer.When your machine need developer,it show developer signal.blank page print means,charger problem please check corona wear may be it broken or displace.
Jan 07, 2010 | Sharp AR-208D Printer
Sharp al 2040 cs copy comes out blank
Check the drum or developer unit whether they are rotating and make sure there is developer installed. Then clean the main charge unit and check transfer corona wire if dirty or broken and replace.
Nov 30, 2009 | Sharp AR-5316 Advanced Digital Imager...
My sharp copier AR-205 will not copy and the letter CH or showing up
Install the developer unit and toner cartridge properly and close the copier side covers well ie the front and the right covers.
Nov 24, 2009 | Sharp AR-M205 Copier
No error message but copier light doesn't come or number of copies doesn't work
let it run eventually the toner lite will come on, sharp copiers will run an extended period trying to add toner to the developer. developer is 70% iron filings and 30% toner as it uses the toner it cycles more in to stay at the proper level.
Apr 14, 2009 | Office Equipment & Supplies
Sharp AR-208D copier needs developer - how to add?
Set-up for this copier sure isn't well-documented. We just got ours working today, found out how to add the toner by following the instructions here: https://www.businessneedz.com/Manuals/ar168s_setup.pdf (yes, it lists a different model number, but the instructions worked, and were linked from the ar-208d product page from the supplier)
Apr 02, 2009 | Sharp AR-208D Printer
Sharp AR 5316e copier
check if the developer that comes in a silver bag has been installed and the screw that fastens the scanner has been removed.
Jun 19, 2008 | Sharp SF 2020 Copier
Add developer in sharp AR-5316
That model uses a TD cartridge so when you replace the toner the developer is included. The crum chip on the TD cartridge will reset the counters and sets the developer.
Dec 30, 2007 | Sharp AR-5316 Advanced Digital Imager...
Problem with sharp ar168d
If you do not have developer in the machine it will not print. let me know if you have it or not.
Nov 14, 2007 | Sharp AR-M455N Copier
Sharp AR-208D Printer Logo
229 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
