Question about Canon CanoScan LiDE 600F Flatbed Scanner
When i scan 35mm negatives which have narrower frames i get a thick black stripe down the image
  • bournefree Sep 28, 2009
    I'm using a Canon LIDE600 scanner using a negative scanning attachment. It is connected to a Dell Inspiron 1720 with 4Gb of RAM, 100Gb of free disk space. The software I'm using is Arcsoft PhotoStudio 5.5
  • 615 Answers
Need more info about the software and hardware
Posted on Sep 28, 2009
  • Norman Al-Anbar Sep 28, 2009
    Thank you for the information as I thought the Canon Lid 600 is great scanner however I checked lots of reviews and pro and cons and found out that the majorities acres that the attachment for negatives does leave a “Small footprint “that is acceptable as other software can eliminate it.
    The question is does the footprint too big to be noticeable and out of control for the Photoshop to take care of it or not?
    According to the Manuf. The footprint are commons but it is up to the end-user to see if it got bigger?
    I am sure that you are aware of such and I need to ask you if the footprint got bigger or just you needed to know if someone could fix it?
    As long as the unit is clean and working without any noticeable changes it is better if you do nothing, however if the issues are new and getting bad then yes we can start working on that.
    Let me know how this worked for you and please do not forget to rate my service so we are able to improve on it. The rating as follows 1 the service was not related to the post. 2 the service was related but not did not help at all. 3 the service was to the point and somewhat complete. 4 the service was excellent and to the point.
When using ADF, a stripe appears on paper when copying and the same appears on a scan image, but the stripe does not appear on paper copying or on scan image when using the scan bed.
When you get marks from the document feeder it is dirt on the narrow optical strip that collects the image. Hinge up the rectangular lump at the top end of the feeder and clean the glass strip with alcohol hand sanitizer on a tissue and polish off. Whilst you at it clean the glass on the scan platen.
Apr 18, 2016 | Canon Pixma MX922 Inkjet All-in-One...
Does anyone know which colour does what for a madza demio stereo wiring harness
It sounds like the the ones with red and black stripes are possitive and negatives for your speakers then the others are positives also you would need a 12v test light to see witch wires have power to them and go from there
Sep 06, 2014 | Cars & Trucks
My canon lide 700f will not calibrate to scan a 35mm film
For those having the "Executes calibration. Pull out the film and place the Film Adapter Unit at Frame 1." issue and cannot calibrate the scanner for NEGATIVE FILM, it took me ages to figure out how to solve it.
Solution: calibrate the frame, WITHOUT any film, adapter plug and placed in frame 1, and proceed to do the calibration WITH THE SCANNER COVER OPEN.
Before I tried everyhing, install new drivers for Windows 8.1, MP Navigator, and nothing happen. Now it works like the first day. Hope it helps! it certainly helped me.
Jan 29, 2013 | Canon CanoScan LiDE 700F
When I scan 35mm negatives, the pixel aspect ratio is incorrect: the resulting images are stretched out by twice their width without any change in height. I can fix this after importing the image into...
I have the same problem with mine; medium format scans are fine but 35mm scans are stretched. The same happens with both the Minolta software and with Vuescan. Has anyone manage to fix this?
Dec 26, 2009 | Konica Minolta Dimage Scan Multi PRO Film...
How to scan slides with Visioneer 9520 USB Scanner - it scans who
I have successfully used my Visioneer 9520 to scan 35mm slides, and they came out perfect. To do this, in my image editing software, I select File/Import/Acquire/Visioneer ScanManger Pro. This opens the VIsioneer scan manager window, where I select "Scan 35mm using:" and then I choose the desired scanning configuration, e.g., "35mm Better, 35mm Best, Custom" etc. See image below.
BTW: After several moves, I have lost my 35mm scanning template. Do you know where I can get another one, or do you know someone who could actually scan theirs and email the image to me? I could then create a duplicate from heavy black construction paper or card stock.
Jul 26, 2009 | Visioneer OneTouch 9520 Flatbed Scanner
Where do i put the negative to scan on hp g3010 scanner
On the lid there are thin plastic rails that frame two 35mm Negatives. Place the film in that holder, framing what you wish.
Check HP's site for the owners manual for advanced settings for your specific model to get the best results from your Negative or as HP calls it Transparent Materials Adapter (TMA)
Let us know
Good luck
Apr 14, 2009 | HP Scanjet™ G3010 Flatbed Scanner
Lines through negative scans
Clean the glass surface with Iso propyl alcohol (Industrial grade is enough). Dont use any solvent. Just for immediate usage, you can use your aftershave and clean. Clen with a soft cloth.
S. Mohan, Chennai. India
Nov 28, 2008 | Epson Expression 1680 Professional Flatbed...
Negative Scanning Problem Using Epson Scan Software
Make sure the rectangular slots at either end of the film frame are not obstructed or covered in any way. When I attempted to scan color negatives I had the same darkness problem in the scanned image. When I cleared those rectangular slots, everything was fine. I hope this helps.
Sep 28, 2008 | Epson Perfection 1670 Flatbed Scanner
Underexposed, grainy images with a light stripe running down the center
Sounds like your shutter curtain is malfunctioning. Did you bump the curtain when u loaded film & bed it... Take a close look to see if it is binding. This is a very fragile area to monkey with & should be done by a qualified repairman
Jun 26, 2007 | Canon EOS Rebel K2 35mm SLR Camera
Canon CanoScan  LiDE 600F Flatbed Scanner Logo
old marine
old marine
