Question about Konica Minolta DiMAGE Z6 Digital Camera
I have a Minolta Dimage A1 Camera.I have lost the
I have a Minolta Dimage A1 Camera. I have lost the lens sun shade.Is it possible to get a replacement ?
Obertelli
  • 3006 Answers
SOURCE: Looking for camera parts.
These are frequently lost and are fashioned of purest unobtanium.
When mine disappeared I bought a non-working A2 on eBay very cheaply and carefully removed the old eyecup from it and glued it onto mine, it also had the benefit of providing spare body covers, a lens hood, battery and a strap. A cheaper alternative is to buy a non-original replacement, see item number 220440673814 on eBay, or search for seller birthdayboy; the eyecups he sells are good, but it looks ugly and gets in the way as it isn't flush with the back of the camera.
Don't re-sell the donor camera if you buy one: sooner or later you'll need the flexible circuit board from inside it, as the one in your camera WILL eventually fail to power the viewfinder lcd backlight. The old camera will serve to show you how to dismantle and repair your original one. It's one of those jobs which is so fiddly and time-consuming that a professional repair is totally uneconomic.
Posted on Jun 23, 2009
Obertelli
  • 3006 Answers
SOURCE: My Minolta DiMage A1 displays
If you're lucky, the CF card is faulty. It's going to be a very old card now if it's the original one supplied/bought with your A1. You've never upgraded to a larger card in all this time so it suggests you've never needed to. 128 and 256mb cards are virtually worthless now, so I'd be amazed if you couldn't get one for free via Yahoo FreeCycle. You can also try reformatting your card in a card reader/writer, but A1's and A2's often won't recognise a card formatted in this way and it can render them permanently unreadable by all A1/A2/A200 cameras.
If you're unlucky, then you've bent or broken one or more of the pins inside the card slot which connect to your card when you insert it. To check, get a bright torch and look down inside the card slot. Any bent pins will be self evident as there should be a neat double row of pins and missing pins will show up as gaps.
If you have bent pins then you've nothing to lose by trying to carefully straighten them, if you can't or if the pins are broken, then your camera is effectively irrepairable. Scrap A1's and A2's can both provide the part, but retreiving them from the donor camera is really difficult and so far I've never managed to refit one successfully and I've done a few now. A pro repair is simply not cost effective, especially when a perfectly good used A1 goes for around £40-£50 and the better A2's go for around £80-£100. If you're in North America you can expect prices to be even lower.
Posted on Jun 27, 2009
BillB-SA
  • 2761 Answers
SOURCE: minolta dimage g400 camera...cannot get the lens to close
Your problem is likely due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may require professional repair.
Posted on Oct 20, 2009
SOURCE: We have a Minolta Dimage A1 the CCD is broken and
I have sent my A1 to Sony Canada on Sept 24 and on Oct 28 Purolator ring at the door with my A1 repaired like a new one. Anybody with an A1 with the CCD problem have tell Sony that they know a guy that had a free repair and as I am concern they will do it for free. Thank's Sony Canada
Posted on Oct 30, 2009
  • 10 Answers
SOURCE: Cam cannot mak any pictures. ''Error 2''
I have already answer to this problem. To try on solve it you need to remove the metal front cover and check if the socket of the large flat coming fron the back of camera is complete inserted on his shell, or if you damage the cable because the camera drop down
Posted on Nov 08, 2009
What is the biggest size memory card for my Dimage A1 Minolta Camera?
An older camera, the DiMage A1 came with a 16mb card. Some cameras are picky about which cards work best. Compact Flash cards are sold in different speeds and your camera may work faster with a faster card. This camera can use Compact Flash type I or type II, and is compatible with the microdrive card. Since this camera was introduced the capacities of Compact Flash cards have increased dramatically so I believe you should be able to use a larger card with no problems but I would check out some of the online photography sites to read about other's experiences. Here is one good resource:
http://www.imaging-resource.com/
Hope this helps!
Sep 13, 2016 | Minolta Cameras
Camera doesn't acknowledge card when inserted into camera
Hi
Whats the capacity of your memory card? check for compatibility of card, since memory cards that have 4gb to 8gb are not compatible with some cameras. check as well from your cameras manufacturer if they have a firmware that will support such cards for your device/camera.
Hope this helps
May 10, 2009 | Konica Minolta DiMAGE A1 Digital Camera
Camera viewing screen greyed out
If this also shows up on the pictures it could be a defective Sony CCD issue. If so, Sony will fix your Minolta camera for free (with free shipping) regardless of warranty. You need to do this before March 31, 2008 so get going! See this link:
http://camerarepair.blogspot.com/2007/11/sony-konica-minolta-cameras.html
The Dimage models that Sony is accepting for the recall repair are:
Dimage 7HI, 7I, A1, Xi, F300, XT, X20, S414.
Dec 22, 2007 | Konica Minolta DiMAGE A1 Digital Camera
Same PINK problema!
Hope you still have the camera. If so, Sony will fix your Minolta camera for free (with free shipping) regardless of warranty. You need to do this before March 31, 2008 so get going! See this link:
http://esupport.sony.com/US/perl/news-item.pl?template_id=1&news_id=131#
Aug 22, 2007 | Konica Minolta DiMAGE A1 Digital Camera
Pink screen
This sounds like a defective Sony CCD issue. If so, Sony will fix your Minolta camera for free (with free shipping) regardless of warranty. You need to do this before March 31, 2008 so get going! See this link:
Aug 08, 2007 | Konica Minolta DiMAGE A1 Digital Camera
Lens knocked out of alignment?
hi, as per my experience symptoms you described is related to ccd. I think ccd replacement is must.It is really hard and costly to fix this problem but if you have bill and warranty dont worry. Just go to KonicaMinolta shop. good luck...
Aug 01, 2006 | Konica Minolta DiMAGE A1 Digital Camera
Is it possible to control the DiMAGE A1 from the PC? (when the DiMAGE A1 is connected to PC.)
Yes, it is possible to control the camera from PC with "DiMAGE Capture".(sold separately)
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Is it possible to use the transformer when using DiMAGE A1 abroad?
Here are trans transformer and electric transformer (small model is mainly for overseas travel). There is no problem when using trans transformer, however when using electric transformer, there are many models which cannot be used with battery charger, precision instruments and so on.
What are the white balance modes available with the camera?
The following White balance settings are available for the A1: AUTO, Preset (Daylight, Tungsten, Fluorescent, Shade, Cloudy, Flash and Custom1 to 3) The following slight adjustment is possible: * At setting Daylight, Tungsten, Shade, Cloudy and Flash: +3 to -3 (one unit is approximately equal to a 10 mired shift.) *At fluorescent lamp setting: equivalent to 7 fluorescent lamp(3 -wavelength colored fluorescent bulb, 3 wavelength white fluorescent lamp, 3 -wavelength neutral white fluorescent lamp, 3-wavelength daylight fluorescent lamp, white fluorescent, neutral white fluorescent, daylight fluorescent lamp)
What optional accessories are available for the DiMAGE A1?
The followings are available as optional accessories for DiMAGE A1: 1. Battery pack BP-400 2. Digital Utility Bag DUB-100 3. DiMAGE Capture which software can be controlled DiMAGE A1 from PC ( It will be available September ,2003)
Konica Minolta DiMAGE Z6 Digital Camera Logo
15 people viewed this question
Top Konica Minolta Cameras Experts
Willem.
Willem.
ktpierce
Level 1 Expert
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
