Question about Power Acoustik PWM-16 Car Audio Amplifier
Power Acoustik PWM-16 Equalizer Help
I have a Power Acoustik PWM-16 and i dont exactly know how to hook the rca's up...it has a cd input rca on the equalizer but i dont have a cd input on my cd player i have a Pioneer DEH6000 please help me figure out how to wire the rca's!
  • 396 Answers
You should be able to use your RCA output (Line Out) from your Pioneer to the input of your PWM-16. Then take the PMW output to an amplifier and then to your speakers. Your EQ only uses RCA's so an amplifier after
it would really bring the sound to life. The amp need not be huge as you have an output for subs also. You could try a line converter to change the RCA lines to speaker wire connections. Not sure if the output would be enough to power a speaker but it's worth a try.
Posted on Sep 29, 2009
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
I have a 1987 model kenwood home stereo system ihave a graphic equalizer ge 76 control amplifier kc206 synthesizer tuner kt76 power amp km206 how does the RCA connections hook up which ones go to...
First connect all sources like tuner, cassette player, Cd player into the proper RCA inputs of the control amp, then connect the output of the control amp into the input of the equalizer. Then connect the output of the equalizer into the input of the amplifier. This is how to get the best performance and proper outputs to all the right equipment. The speaker outputs of the amplifier would then go to the speakers.
Let me know if you need more help from me by addressing your post to me, or if you wish to communicate with another expert you can address your post to them I.E. @tech48 or @whoever
Thanks and good luck,
Dave
Sep 27, 2008 | Kenwood Audio Players & Recorders
Don't no how to hook it up ...
Instructions
Hook up an RCA patch cable
between the output of your car's
stereo receiver and the graphic
equalizer's RCA inputs. Use
stereo cables with male RCA
connectors.
Connect the equalizer's outputs
to the RCA inputs of your
amplifiers. How many cables you
need will depend upon the
number of amps in the system. In
most cases, you'll need two to
three to connect the equalizer to
the inputs of your amplifiers.
Hook up the equalizer to 12-volt
power. Use the same power
connections you used to connect
your amplifiers and receiver. The
equalizer's yellow wire should be
connected to a constant power
source, one that is not switched
off with the ignition, and the red
wire (not always present) to a
switched 12-volt power source.
Splice the wires by stripping the
insulation off the end of each
wire and then soldering or
crimping them together.
Connect the equalizer's blue
"turn-on" lead to the receiver's
blue wire. This turns the
equalizer on when the receiver is
powered up.
Mar 28, 2013 | Car Audio & Video
The low frequencies adjustment is not working when i turn the sub frequency on low it lowers the volume of the bass completely
check the rca cables on the back to see if you might have the sub woofer cable in wrong rca spot
this is how it should be wired from your radio front output a set of rca cables go to the radio input of the eq. if you have sub out on radio it will not be used ... eq takes place of it ... turn off subout on radio ... to use eq or preamp you must have at 2 amps 1 for mids and tweets and 1 for subs to work eq right
then from the eq you have another set of rca cables comming from the front output to your mids and tweet amp and then if you dont have a second amp u wont need rear output move over to the suboutput and run a set of rca cables from eq's sub output to sub amp this is how the audio cable section should be connected if you still dont get it to work proper then then it has a electronic issue and need to warranted out if still in warranty or buy new one .... here is a link to the install manual with a wire diagram for repair shop .....http://www.poweracoustik.com/pa2006/manual%20and%20catalog/Processors/PWM-20.pdf
Dec 27, 2010 | Power Acoustik PWM-20 4-Band Car Equalizer
Power acoustik gothic OV2 800 manual
Could not get a manual for you but did get the follwing specs. Hope they help.
Power Acoustik Ov2-800 2-Channel Class A/B Gothic Series Amplifier (800-Watt)
POWER ACOUSTIK OV2-800 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER
800-WATT 2-CHANNEL
4 ohm RMS: 150W X 2
2 ohm RMS: 180W X 2
Bridged mode MONO RMS: 360W
BRIDGED MAX: 800W
FULL MOSFET POWER SUPPLY
PWM CIRCUITRY
FULL SELECTABLE CROSSOVER
3-WAY PROTECTION CIRCUIT
TRI-MODE CAPABLE
VARIABLE LOW PASS 40 HZ - 120 HZ
VARIABLE HIGH PASS 150 HZ - 1.5 KHZ
VARIABLE 18 DB BASS BOOST @ 40 HZ
FREQ RESP: 10 HZ TO 30 KHZ
S/N RATIO: 98 DB
THD: 0.02%
2 ohm STABLE STEREO
SYSTEM DISTRESS INDICATOR
HIGH/LOW LEVEL INPUTS WITH FLOATING GROUND
4-GAUGE POWER/GROUND CONNECTION
PLATINUM RCA CONNECTORS
LINE OUTPUT WITH FLOATING GROUND
BLUE LED
CHROME TOP PLATE PANEL 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER (800-WATT)
Aug 18, 2009 | Power Acoustik GOTHIC OV2-800 Car Audio...
POWER ACOUSTIK PADVD-330 DVD Player issues.
if your pioneer radio has the light blue ipbus/changer plug on the back of the radio, you can use this adapter and turn on the <aux> in the menu where you set the clock.
http://cgi.ebay.com/Pioneer-IP-BUS-Aux-In-Input-Adapter-CD-RB10-for-iPod-a3_W0QQitemZ400030920263QQcmdZViewItem
Aug 17, 2009 | Power Acoustik PADVD-330 Car DVD Player
How to wire an eq to car stereo without an outboard amp?
no those wire is not for speakers out put that for signal in put only if there is rca jack follow the instruction and run your cable if your dont know dont guess you will burn unit audio out put if install wrong
Jun 28, 2009 | Power Acoustik PEQ-70 7-Band Car Equalizer
Equalizer doesn't turn on
hookup the remote wire of your EQ to that of the HU or just simply connect it to the positive line but it would make your EQ powered ON all the time. That remote wire of your EQ is to get a trigger signal from the HU so that it will turn the EQ "on".
Apr 20, 2009 | Power Acoustik PWM-19 4-Band Car Equalizer
Have one wire for audio sub out, but two input ports to amp
This one Wire should be for the +. Try connecting the + to the Head Unit and - to a Common Ground. At the Worst, You will Blow the Amp Fuse if not Correct. The Lead from the Head Unit is Only an Off and On from the Ignition. Please Rate My Response! Thanks!
Jan 31, 2009 | Power Acoustik PTID-8960 Car Video Player
Power Acoustik Equalizer PWM-30
i don't know about the availability of boschman but it's the best.
Jul 04, 2008 | Power Acoustik PWM-30 Car Equalizer
Car Audio & Video Logo
147 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Jose Velazquez
Jose Velazquez
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
