Question about Troy-Bilt 31cc 2-Cycle Gas Powered Blower/Vacuum #TB320BV
Will not continue to run after relasing choke, no
Will not continue to run after releasing choke, no matter how long you let it warm up.
  • 486 Answers
You have a fuel starvation (lean condition) issue
fuel system needs cleaning
fuel lines
filter
carburetor cleaning and replace gaskets/diaphragms
Posted on Nov 09, 2009
Engine starts but won't continue to run. Choke doesn't stay closed after starting. will stay running only if I hold choke closed manually.
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
Aug 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
M842 chainsaw wont start when hot
I suspect your warm start procedure is the fault, the manual is not correct IMO. Any choke on a warm engine causes flooding, try this, if no better post back or return it for warranty replacement.
Start Procedure
Cold:
  1. Ignition on/off to on.
  2. Set compression release – optional step even if saw is equipped with a compression release.
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts. (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull).
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 13, 2010 | McCulloch Garden
It Won't Start
Read your manual very carefully. I think it is flooded. Read line 3 (cold and warm). read them again. Read 5 in your manual. Most overlook the attempt to start , continue with the choke closed and the saw floods. You have an additional visual indicator, watch the decompression valve, when cold; once it pops turn off the choke. The warm procedure is very close to mine.
Start Procedure
Cold:
Warm:
If it still will not start return it for a replacement or your money back. Anything you do may render any warranty invalid.
Did you purchase this in a big box store? What is your elevation?
All new saws regardless of maker are set to run extremely lean to meet EPA mandated air quality standards. They are also fitted with a device to restrict richening the carburetor beyond initial factory settings this too required by the EPA. Most big box stores put them on the shelf and sell them to the consumer with no thought of how elevation may impact saw performance or longevity. Homeowners usually are not concerned about changes in the saws performance until it quits operating. This combination results in many destroyed saws and homeowner saws of most brands being called trash!
Find a local chainsaw seller/mechanic. If they pull a saw off the shelf and hand it to you without making some adjustment or minimally ensuring it will run hand it back and leave. You can get this service at a big box store cheaper. Find a different seller/mechanic and try again. A good dealer will help you arrive at a saw that will meet your needs. He will ensure it runs properly and you have an understanding of how to properly operate it. Should a problem arise you have somewhere to go and if you were courteous with your dealer someone in your corner helping you rectify your problem.
Lou
Mar 08, 2010 | Husqvarna 450 e-series 18" Chain Saw
It starts and runs but when you turn it off it won't restart.
I think the warm start procedure in the manual is causing it to flood. Try it like this, if you continue having problems reply below and we will try something else. PLEASE read #3 (Cold and Warm) a few times before attempting to start. Try it without 1/2 choke (your manual); completely open.
Start Procedure
Cold:
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed or at 1/2 choke position.
Hope this helps.
Lou
Feb 21, 2010 | Poulan Garden
18"poulan chainsaw
Start at 1.5 CCW form lightly seated then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
I think your starting procedure may be the cause of flooding. Flooded is the #1 cause of hard starts in 2-cycle engines. Read carefully the recommended start in your manual. most miss the second note. It should be similar to this (read 3, read it again):
Warm start in the manual says 1/2 choke BS. Close choke, (sets fast idle) open choke, pull rope.
Start Procedure
Cold:
  5. Push (open) choke pull starter until it starts (usually first pull).
Warm:
  4. Push (open) choke, pull starter until it starts (usually first pull).
If you still have trouble reply as you did before. I will get back to you. HTH
Lou
Feb 18, 2010 | Poulan Garden
The engine is flooding while trying to start
Clean the air filter and spark arrestor (muffler)
Drain and refill the feul tank with mix less then 1.5 months old.
Start Procedure
Cold:
Warm:
If it still does not start reply (with what you have done and we will continue. HTH
Lou
Feb 06, 2010 | Garden
Mcculloch 3516 chain saw, does not always start.
It must have spark, fuel and compression to run. Your task is to figure out which is missing.
Sometimes electrical components quit operating once beyond a certain temperature. Does it always start cold and become tempermental when warm?
IMO most hard start problems on a chainsaw with a good fuel delivery system are flooded.
Start Procedure
Cold:
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) - Don’t pull with choke closed.
The 3516 is a MTD McCulloch (Chinese). These saws are in a class by themselves. Good Luck
Lou
Nov 15, 2009 | McCulloch Garden
2ooo yamaha stops running when it gets warm any
The carb probably is dirty or has some water in the float bowl, if you can first remove the float bowl without removing carb to see if there is any water or foriegn matter in the bowl try not to splill gas while removing so you can see what is in there
Jul 08, 2009 | 2000 Yamaha DT 125 R
Engine dies when choke is relased
This means the engine is running lean the choke lessens the airflow to give it a richer fuel mixture (more parts gas to air ratio)
*first you should check the spark plug--
This can be caused by faulty gaskets.
I would also make sure the floats work and that the needle and seat (connectet to the floats) work also the needle tip can become worn over time it should make a v shape.
when you clean the carb you should get every jet and hole with carb cleaner and you should use high air pressure through the jets and clear any grime clogged in the middle of the jet passages.
make sure you have the right air to fuel mixture (32:1)
be careful an engine with the choke on too long can strip away the oil lubrication protecting the cylinder from being scored
Apr 24, 2009 | Yamaha G5 Motorcycles
MOWER RUNS FIVE MINUTES THEN STOP AFTER IT WARMS UP
Check your automatic choke ... a cold mower needs more choke, and the auto-choke should release when the motor warms and runs smoothly. If the choke is sticking, the motor will die when it gets warmed up, then start again after it cools down.
Apr 12, 2009 | Mtd 22" Yard Machine Push Mower
Troy-Bilt 31cc 2-Cycle Gas Powered Blower/Vacuum #TB320BV Logo
773 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
