Picture not like it used to be :(
I have a 55" LCD 2 series from olevia that is one year old. when i came back from vacation the picture was not like it was when i left. there are moving shadows and distorted background images now and i dont know how to fix it. its like i need to degauss it but there isnt a button for it. the olivia website no longer exists so i dont know where to get assistance from.
  • 1 more comment
  • nreves Sep 29, 2009
    when i go to blu-ray/dvd its the same issue with the picture. again the tv is only about a year old. i just switched from comcast to att u-verse. i have an hdmi connection from the box to the tv. the signal im getting in is 1080i.
  • nreves Sep 30, 2009
    how do i add a picture to this comments box?
    President:
  • 1,779 Answers
LCD and Plasma sets DO NOT have degaussers in them. That was for the old Picture Tube Models. Try using a DVD on it and let me know how it looks. It sounds like a cable issue, but I don't know what type of signal your using.
Posted on Sep 28, 2009
I'm looking for an owners manual for an Olevia 332-B11 it is approx. 10 years old. Any help?
Free User Manuals and Owners Guides ManualsOnline com
Try this site. It goes faster if you have the serial number and the make handy.
hope you find your manual,
kolbrun
Feb 01, 2015 | Olevia Televison & Video
Picture rasterization
It sounds like the LCD controller board problem, usually if you cool it down the problem will go away, and comes back when it heats up again.
Nov 23, 2009 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
No sound. No picture. I just turned it on and the screen was black and there was no sound either. It has been working fine for the past 3 years. I have Dish network. They don't think it is their problem....
If you get the same results (no sound/picture) using a dvd player or other media device, then your power supply board needs servicing. If you have an extended warranty take it back...
Nov 10, 2009 | Olevia LT23HVX 23 in. LCD Television
42" TV has sound but no pictures
yea it sounds like a main-board or inverter board.. sounds like the panel of the television is loosing power and you are still getting sound..
Olevia did go out of buss.. but i know this 3rd party repair center called Amergence technology is offering to repair Olevia's. But the thing is that the whole television will have to get service they don't sell parts so you might want to give them a call and get an idea on the repair quote.. 866-965-3842
Jul 10, 2009 | Olevia LT42HVi 42 in. LCD Television
Olevia tv
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
The inverter is the high voltage board that provides variable power to the backlight lamp. This is the most common. When inverter is faulty you can get no picture, or a very dim picture that can only be seen by pointing a torch light with a 45 degree angle on the LCD surface from very near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
This is quite uncommon, but happens. If the TV had been hit or moved the LCD cable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
This is the board that controls the video signal, it is difficult to test, as there is need to read determined values on IC pins. To test this board you need to purchase a service manual and follow the troubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where you connect the video and audio cables, if a signal board is defective, then you may get no picture on particular inputs located on faulty board.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
May 25, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Olevia tv
try unpluging, wait about 30 seconds and plug back in.
Mar 23, 2009 | Olevia LT32HVE 32 in. LCD Television
OLEVIA 540-B11 42" LCD-Inverter supposedly shot craps
Ok I'm Not an expert on Olevia's but I've done enough LCD Tv's to know a few things. The inverter boards are usually located on the right and left side edges at the back of the chassis. They usually run from the top to the bottom and have multiple connectors coming out to feed the backlights in the LCD panel. I can believe Olevia might not supply them (most other companies do) except as a part of the LCD panel. In some cases, the manufacturer of the LCD panel (Olevia does not make their own panels) does not supply the boards separately to the company making the set..In terms of getting a diagram, the panel maker (probably chinese or korean) probably has one, but Olevia may not. Your best bet would be to keep an eye on a site like this one:
http://www.shopjimmy.com/
They get scrapped TV's and remove the inidividual boards for resale. I have already checked and they don't have the board you're looking for right now, but that can change. Sorry I can't be of more help!
Nov 07, 2008 | Televison & Video
Black Screen
they do not sell inverters as they are cheep and too mcuh to install check on the net and see if you can get one after market...checg your search to include far east as your search set for USA only...you can get them very cheep from Taiwan but look at local sites for export.
Aug 06, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Black screen
Does the menu display?
If not, it could be your inverter panel or in the power supply.
Apr 04, 2008 | Televison & Video
Lcd tv picture problem
My 3 yr-old 30" Olevia LCD HDTV lost picture after being on for about 1-2 min. Does any one encounters a similar problem or has any suggestion as to how or wherther it can be fixed. Thanks.
Jan 11, 2008 | Olevia LT26HVX 26 in. LCD Television
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
Electro Med Services...
