Question about Sony XM-754HX Car Audio Amplifier
I HAVE A SONY XM 754HX AMP BUT IT GOES ON PROTECTION MODE
I HAVE A SONY XM 754HX AMP BUT EVERYTIME I TURN IT ON THERE IS NO SOUND COMING OUT OF IT AND THE HI- VOLTAGE, OVER CURRENT, OFFSET AND THE THERMAL LIGHT WOULD NOT TURN OFF. I TRIED DISCONNECTING ALL THE WIRES AND REWIRED THE WHOLE CAR BUT STILL. I CHECKED THE VOLTAGE AND CURRENT, THEY ARE FINE. I HAVE ANOTHER AMP IN THE BOOT AND THAT WORKS PERFECTLY WITH THE SAME WIRING. I CHECKED ALL CENNECTIONS AND THEY ARE FINE. IT WOULD BE GREAT IF SOME ONE CAN HELP.
  • 158 Answers
I had the same amp same problem they just wear out
Posted on Sep 28, 2009
Im have the same problem, but when I take my remote wire and touch to power and remote termanals all lights are green. I thinky power wire is to big
Posted on Sep 18, 2011
Koiiler XM8787 Amp power problem
Sometimes i goes into protection when the amp is overloading with power.. Or the amp is touching metal.. Or the ground wire aint in the right place..Or check your RCA's, Speaker wires? if their earthing your amp..
Jan 13, 2010 | Koiiler XM-8787C Car Audio Amplifier
I have a sony 2/1 channel power amplifier (XM-2165GTX) that will produce sound untill my pioneer headunit (deh-3050) hits 25 in volume..the sub then goes into protection mode and will not turn off..not...
Not enough power going to the amp..?
Solutions:
1) Your negative ground wire needs to be in a better spot.
scrape paint from the grounding surface.. This will ensure better contact between the negative power wire terminal and the vehicle ground.
2) Get thicker wiring cables.. for Positive, and Negative
3)Turn the gain right down.
Jan 12, 2010 | Sony XM-2165GTX Car Audio Amplifier
Switch on bottom of amp?
are you talking about how to turn your amp on and off? if you are then that is your remote wire. it comes from the cd player to the amp. there is no switches on amps to cut it on and off
Oct 22, 2009 | Sony XM-754HX Car Audio Amplifier
The amp turns on but goes to protection mode
Have you checked the REM wire, if it is the wiring may have gotten fried.
Or you may need to get new parts replaced within the amp.
Both issues happened to me.
Mar 27, 2009 | Car Audio & Video
Sony car stereo
When the amplifier shows an offset fault, it's generally because there is DC voltage present on the speaker terminals. The amp has shut down to protect the speakers.
Aug 14, 2008 | Sony XM-754HX Car Audio Amplifier
My amp protection light keeps coming on
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, read through the following page.
Amp in Protection Mode - Troubleshooting
Let me know if you have any other questions.
Aug 10, 2008 | Sony XM-460GTX Car Audio Amplifier
Amp protection
Hi, Off hand, I believe there is nothing wrong with the setup, maybe just not 100% compatible. It's just that the Sony Amp's protection is doing its job (just too good) and the stock radio is likewise doing it's job (but not too good). Just maybe, at poweron, the stock radio sends out a small burst output (maybe capacitor discharge) that we normally hear as a slight thump in the speakers which was when no Sony amp, ok. However, when you have added the amp, you also amplified the thump, which unfortunately the Sony protection reacts to. You can off course let it be since you have figured out a way to make it work or you can try and install a delay on for the power amp or separate it's power on from the stock stereo. The idea is to turn on the stereo with the Sony off and after a second or less, a manual switch or a delay activated switch will turn on the Sony. The idea is to switch on the Sony after the thump has finished. Good luck and hopes this gives you an idea. Pls post back how things turn up. Kind regards.
Aug 15, 2007 | Sony XM-2002GTR Car Audio Amplifier
Amp protection light
Hi again, Looks like you posted twice, in any case pls have a look at your other post @ http://www.fixya.com/support/t182326-amp_protection
Car Audio & Video Logo
368 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
