Question about Cameras
I have a sony ae 200,ihave no probs using in day but when taking shots at night i get a delay with flash what settings could i try?
early1234
  • 871 Answers
SOURCE: sony cyber-shot dsc-w55 flash doesnt work
hi
the flash doesnt flash anymore, you may need to replace th bulb for that. the yellow light means its a warning that the bulb is wor out.
hope this helps
Posted on Jan 22, 2008
otacon
  • 1944 Answers
SOURCE: My Sony Cyber-shot camera DSC-W55,
Try manually turning on the flash.
Posted on Jun 09, 2008
  • 479 Answers
SOURCE: Night shots using flash giving a bluish color effect.
try reset the camera back to camera defaults by putting dial on p, menu, custom reset
Posted on Aug 20, 2008
SOURCE: Flash options for sony camera
I recently had the same frustrating problem. The top of the camera has a little black button that can change from continuous mode or single picture mode. It has to be on single picture mode to change the flash setting. After this is changed you can press the flash setting onthe dial and change the setting. I hope it works for you.
Posted on Dec 30, 2008
welcomejee
  • 10594 Answers
SOURCE: my flash not working,showing flash chraging sign.
If its Sony DSC-S730 camera then flash board is defective and requires replacement under following part number..
A1444049A ST Block Assy
Available in Part Store for $52
NOTICE: You should replace flash board if you are familiar with camera repair and be aware that flash capacitor has enough electric charge.
Posted on Feb 23, 2009
How to shoot pictures of the moon
About this result
How to photograph the supermoon: an easy way to shoot moon ...
www.techradar.com/.../photography.../how-to-photograph-the-moon-an-easy-way-to-...
  1. Cached
4 days ago - Taking pictures of the moon is one of the more popular subjects in night photography - but it's also quite tricky to get right. Use this tried and ...
How to Photograph the Moon - Photography Life
https://photographylife.com > Photography Tutorials
  1. Cached
  2. Similar
Jun 11, 2015 - Aperture: Set your aperture to f/11. Shutter Speed: Set your shutter speed to 1/125 on cameras with base ISO 100, and to 1/250 on Nikon DSLRs with base ISO 200. Lens Focus: Set your lens to manual focus (either through a switch on the lens or on the camera) and set your focus to infinity.
How To Take Stunning Pictures Of The (Super) Moon :: Digital Photo ...
www.digital-photo-secrets.com/tip/779/how-to-take-stunning-pictures-of-the-moon/
  1. Cached
  2. Similar
Aug 7, 2014 - Start with ISO 200, f11 aperture and 1/125 second. Try a test shot. Then use trial and error by changing the shutter speed until you can find the best exposure that works for your composition without overexposing the moon. Turn off auto focus.
How-To: Photograph The Moon ' Popular Photography
www.popphoto.com/how-to-photography-moon
  1. Cached
  2. Similar
4 days ago - Planning is a big part of all photography, and shooting the moon is no ... that much money on a lens like this to take impressive moon photos.
How to shoot pictures of the moon Google Search
Nov 15, 2016 | Cameras
Why can't I set self timer to take 3 shots. LUMIX dmc fz200
as far as i know the fz 200 has only 2 option , instant and delay, i may be wrong on this, if your camera has an option to use a lcd timer remote ,you set the desired number of shots with delay
Jun 01, 2015 | Cameras
When I take pictures at night or in the house when it's darker they don't come out clear or bright. I've tried changing the settings and used the flash. I would appreciate you help. Thanks
Most of the present day personal cameras cannot have a good flash output and so the THROW of light is limited, So when it is used for night shots try and use the flash as close as possible to the SUBJECT as the flash will not COVER THE SUBJECT if FAR away.
This can be the reason for the poor shots. Also try to manually set the camera for higher sensitivity .Use of a SLAVE flash will improve your shots. You can buy this as an accessory.
Jul 12, 2011 | Panasonic Lumix DMC F3 Digital Camera
D300 long shutter delay
are you using mirror lock-up or live-view feature?
Jun 02, 2009 | Nikon D300 Body Only Digital Camera
Night shoot and Indoor photo quality is not good with Fuji S5700
Your Sony camera must be more noise-free at high Iso settings than the S5700. As you view your shots on the camera, press the button with the square and the +/- symbol in it. Now you can see what Iso setting the pic was taken at. The 400, 800 and 1600 settings are all noisy on this camera. The only solution is to use a tripod with long shutter time and Iso 200 or less.
Apr 01, 2009 | Fuji FinePix S5700 Digital Camera
Not sure of setting for flash photos
Try and put the camera in the program mode.
Mar 21, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Problems taking photos at night.
Did you use flash? Did you use tripod? Generally speaking night photos with non-DSLR digital camera, W55 is non-DSLR, will be blurry unless either flash is used or a tripod is used. The issue is the camera shutter is set for a long exposure in order to get enough light that it is impossible to hold the camera steady. The color problem you mentioned is most likely your white balance. Normal white balance is sunlight at night you white balance should be Auto, Incandescent or Neon
Jul 23, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony handy cam
Unit may have been set to wrong exposure preset. Taking video at night of fireworks can be tricky as a lens openning for night shots may be overexposed when taking shots of sudden bright flashes of fireworks. You might try moving the camera vantage point at least 60 - 100 feet away. This will give the camera additional time to adjust it's optics
Jul 06, 2008 | Sony Handycam CCD-TRV37 Camcorder
Out of focus shots at night
First, check to see if you're in auto or program mode, as opposed to manual or possibly even aperture priority (if it supports it). Typically, auto or program mode sets your shutter speed to around 1/60th of a second, which is usually good enough to hand-hold a flash shot without blur. The camera should emit enough flash - within its range, of course - to get a good exposure. You typically won't get a good flash shot if your subject is more than 10-12 feet away. If you want, you should be able to go back and look at the way your camera was set for each shot with a program like Photoshop or Elements. That information is stored as "EXIF" data, and if you select a file in Photoshop CS' file manager for example, you should be able to see what the shutter speed was on any given shot. Let's suppose you look at some old, blurry night-shots - the EXIF data, that is - that should've turned out OK and your shutter speed and everything look fine. At that point, I'd try taking some flash photographs using a tripod at night which would eliminate camera-shake as a possible cause of the blurry shots. I suspect that the likely cause was your camera wasn't in the correct mode though and once you get that squared away, it'll be OK. Good luck!
Sep 13, 2005 | Olympus Camedia C-770 Digital Camera
Cameras Logo
13 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
