Question about Kenmore 44109 / 44102 Side by Side Refrigerator
Ice maker Kenmore Side by side
Water does not dispense into the ice maker. Water dispenser works well.
I checked what I could and doesn't look frozen?
thank you so much.
Mark_Eva@comcast.net
    Scholar:
  • 146 Answers
You have two separate solenoids to your ice and water. One controls the water the other the ice maker. Check the ice maker solenoid and see if it is getting 110v to it and is opening. You will find it in back of the refer under the cardboard panel. Just follow the hoses.
Posted on Dec 18, 2007
Kenmore Elite side by side 106.4442 603. Out of power for 24 hrs and after that the ice dispenser doesn't work properly. It makes ice and dispenses water but no ice is coming out. Could it be a frozen...
During the power outage im sure some of the ice melted and then refroze into a big block in the ice bucket did you remove the ice bucket and empty all the ice from it?
Aug 24, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water will not dispense to ice maker
The water dispenser in the door of my Kenmore side by side will not work. The ice dispenser does work. What do I need to do to fix it?
Thanks Kel
Sep 06, 2009 | KitchenAid KSCS25FKSS Side by Side...
Ice Dispenser clogged with frozen ice
I have the same problem. Found this posting:
http://www.applianceblog.com/mainforums/sears-kenmore/10491-kenmore-ice-maker-dispenser-door-shute-clogging-missing-heating-element.html
Maybe our heater is not working?
Jul 05, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Water dispenser works, but ice maker not working.
i have the same problem right now.. water supply is goodand water dispenses from dispenser. tray that makes cubes not getting any water. looking for help also.
Dec 27, 2008 | Kenmore 53642 / 53644 Side by Side...
ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Nov 20, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker failure
1) Check the filler tube which allows water to enter the dispenser through the back wall of the freezer. This tube may be frozen inside. You can pull the tube out gently and clear it.
2) The inlet valve may be faulty/blocked. Where the water connects to the water valves behind the fridge, try to swap the plugs around from the one valve to the other. They should be colour coded. Then try dispensing water. If water runs into the ice-maker then the ice maker valve is faulty/blocked.
Oct 23, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore Side by Side Refrigerator Ice Maker Not Working
A couple things to check here. First see if there is ice in the tray. If so chances are the ice maker will need to be replaced however these are very reliable ice makers. If no ice in the tray pull up on the ejector blade (don't worry you won't break it) turn clockwise to start the ice maker thru a cycle. The ejector blade is the long white bar with fingers on it that run the length of the tray. Once it completes a cycle it should fill with water. If no water then either the fill tube is frozen over and will need to be defrosted or the water valve is bad.
Sep 30, 2007 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore 44109 / 44102 Side by Side Refrigerator Logo
117 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
tootsie mason
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
