Question about Acer Aspire 5315 Notebook
My speakers do not work, it says no audio output installed
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 10 Answers
Hi dear,
If your lappy says that no audio output installed it means either your audio driver got uninstalled or it got updated so you have to either reinstall it again or rollback to previous driver verson. so follow the path.
start>control panel>system (computer logo)>device manager>sound, video, game controllers>driver> if driver is not working properly then install it from the back up CD which you may hav got with your laptop.
and if driver is working properly then see the roll back driver option. press it and let it go back to previous driver verson. manu path is same for it..
here to help you
anil
Posted on Sep 28, 2009
  • Anil Meena
    Anil Meena Sep 28, 2009
    If your probelm get solved then please vote me ...
    here to help u
    aideranil
  • aahoy Dec 30, 2010
    When you make a fresh OS instlation and you have deleted all drivers dont install nothing audio driver from your Acer resource CD just update your OS instalation a couple of time and then install the latest Realteck High Definitin Audio Driver and update your OS and for me it worked the sound problem get solved.The rollback it works when laptop worked before the sound, or if you want, that prevent all problems than make a restore point od your system, when works all configuration prplerly and when you have a problem then you just restore your system, but whatc out because all your data will you lost what you installed after you made the restore point.
Why would only 5 of 6 speakers work after new head unit car audio install?
Either that speaker is not connected or, the speaker is blown. To test: Disconnect that speaker from the stereo and, using a 9volt battery, tap the speaker's + and - to the battery's + and -. You should hear a "pop". That would indicate that the speaker works. DO NOT connect the 9 volt battery to the stereo side of the speaker wire!!!! 3_24_2016_7_22_43_pm.png
Mar 10, 2015 | Car Audio & Video
CB Plays out PA Speaker
it is possible that the PA speaker output is intended for a normal (unpowered, unamplified) speaker. Perhaps in your case the audio you hear from the PA speaker is only signal leakage from the PA Speaker connection.
To know.. connect a regular speaker to the PA speaker connector (any speaker, home audio, old car 6x9....). If the PA works and drives the temporary speaker OK, and you hear no CB receive, then the PA output is for a normal speaker, with leakage of CB audio.
It is just a guess, but easy to try.
May 04, 2014 | Radio Communications
No Audio Output Device Installed
might need to go in a do a system restore to a point before the upgarade
Dec 20, 2012 | HP Touchsmart 610-1030y 23" Lcd Desktop...
Where is the audio output on my aspire 4540
how did you connect external digital speakers when you cannot find the audio out port.that is the port where you connected.ok. try installing drivers for your system to get sound
Apr 07, 2012 | Acer Computers & Internet
My pc says no audio output device installed,but in device manager it says its working properly and the drivers are up to date
Well it is possible that the audio driver installed is not the one compatible with you computer board. Try downloading the specific driver needed for your computer's official website. This should solve your problem.
Sep 06, 2011 | Computers & Internet
My desktop speakers not working but cable all plugged in and audio device working.
Hi tamjidzaee ,
Please follow the below steps to solve the problem that you have mentioned :-
  1. Check if the sound driver has been installed in your system, you can check this by going in the control panel's sound and audio devices option , if you find all options disabled and it reads no playback devices and no recording devices, then you have no sound driver installed. Therefore in this case you would require to install your sound driver using your motherboard cd.
  2. If you see your sound driver is installed in the audio options of the control panel and you also see the sound driver's name , then you need to check the volume in the volume settings to check if it has not been muted accidentally , if it has been muted , then please un mute it and things should work fine.
  3. A good idea would be use a headset and plug it into your motherboard in the slot where the speakers output is received , mostly the green round slot.
  4. If you have a front head phone option then you can try using it as well, if the headphone or headset works fine, then we are sure about two , things that the driver is installed successfully and there is a sound output from the audio output slots.
  5. Now, when you have checked the sound via headsets then you need to make sure that you are connecting your speakers in the green slot or the same slot which is working for headsets, remember headsets can be used to check the output in the back panel of your cabinet as well as front panel of your cabinet.
  6. Also check if there is any fuse in your speaker which has blown up so that you can replace it and it would start working, check the power cables and confirm they are not properly connected.
If the speakers work fine , then it's all ok , but if they don't you need to replace the speakers by checking them with your friend's pc or any other audio output device.
Hope his helps.
May 11, 2011 | Computers & Internet
My one speaker is not working but separately both are working.output from pc is comming for both.
101 % Working first you have to download
1. Universal audio architecture which will enable your motherboard to detect audio driver it
can be downloaded from here.
2. then install audio driver
Jan 30, 2011 | Creative Labs INSPIRE 2.1 Computer...
No sound at laptop speaker but audio output is ok
I have lenovo notepad 3000n100 with winXP sp2.
I downloaded realtek audio from ibm site and installed.
Now sound is coming at my output port but the in-built laptop speaker is not giving any sound output.
The hardware is ok as the sound was coming at in-built speaker before formatting. The previous audio driver set up file i have lost.
Plz help.
Apr 16, 2009 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Altec lansing sudio problem
1)Please install a motherboard cd to your system without failure..
after that it will work properperley..
2)In the volume control set the speakers to windows default option..then the speakers will get ready to through output..
Oct 18, 2007 | Altec Lansing Multimedia Computer Speakers
Acer Aspire 5315 Notebook Logo
107 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
