Question about Boating
Hole in boat
We have a kmv 528cc 17foot boot and there is a ballast hole in the side of the boat, what is its purpose?
  • 677 Answers
Its purpose is when you stop the boat it fills with water. The boat is built light in weight to get better peformance,the bad part is that it floats like a cork when you stop.To allow these ballast tanks to fill with water when you stop,creates a stable and solid hull that reduces wave reaction.Once you take off,it all drains out.It slows initial acceleration but once drained,you get the best of both worlds.Many larger and expensive boats use this same principal to get the same result.100 ft boats may take in as much as 10000 gallons.It dulls the affect of the waves.Hope this helps
Posted on Sep 29, 2009
Why does. My boat sit low in the water when i stop to fish it's. A1989 Cajun. Bass boat??????
physics.
As you go through water at any speed the force of the water flowing/being forced beneath it will cause it to rise in the water. When you are stationary there is no pressure applied to the hull. If your boat carries ballast removing some will mean that it displaces less water and will sit higher in the water when stationary.
Archimededs on water displacement?
http://en.wikipedia.org/wiki/Archimedes%27_principle
Jun 10, 2015 | Boating
My JVC DLA-X3-BU will not power on, 2 lights are red, lamp light is flashing orange, how do i get it to work?
I have a JVC DLA-X9-B projector which I think is the almost the same as the X7 and X3 the manual is the same.Its about 2 years old.It stopped working suddenly while I was watching a movie. Indicator lights were both on red and lamp light flashing orange. Replaced the lamp and it did not change the status,did cleaning filter bit , did lamp reset from the remote , did reboot and plugged it at a different ac outlet all that did not work . The lens cover is stuck at opened and the only thing you get when plugged in is the red light on and after 30 seconds the lamp light comes on orange .No fan came on no moving lens cover only flashing orange light.
From this conclusion was the power supply was working and software was a question mark either it was corrupt ,but the power cycle and lamp test start was normal and it checked the lamp and reported orange .So all the more it pointed to either the ballast or the power feeding the ballast.
I opened the projector up started with the screws at the bottom removed the the adjustable screw in legs. Removed the left and the right plastic cover ,then bottom cover, lamp cover, top cover plastic and then top metal plate cover, back cover until parts were all visible ,then put back the screw in legs a placed projector in an upright position. All this was in suspect that the ballast is the problem.
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-6.jpgThis is the top view photo.
On the right black plastic cover is the lamp fan and air duct.
At the center is the lens assembly and motors for focus lens shift etc.
on the left are stacks of electronics that are stacked board on board of about 4 or 5 layers.
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-11.jpgthis is the side view of the stacks of boards, to get to the ballast these have to be removed.NOTE LABLE ALL CABLES AFTER REMOVING THEM AS THERE ARE MANY OF THEM.Remove the side plate
Remove hdmi and land board,carefully there are connectors on bottom and all sides of this board.
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-27.jpg jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-38.jpgthen remove the next board ,remember to lable all the cables.
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-51.jpgthen the next board bellow ,carefull this one has 2 side connectors on pictures top side
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-66.jpgthis will be what it looks like.Note the bottom most is the power supply.,This feeds the ballast as well as other low voltage Dc components.THE CONNECTOR WITH THE WHITE END AND BLACK AND RED CABELS IS THE BALLAST FEED(picture above) .The ballast is located in a black plastic box above the power supply.The only way to remove it is to continue dismantling further. jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-83.jpgthis is the top view and the yellow tags you are seeing is cable labelson the wires.
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-102.jpgthis picture is with all boards removed to check for physical burn outs on components
mainly on power supply ballast feed and ballast itself.
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-123.jpgall boards out
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-146.jpgthis is the power supply board it has both low and high voltage output .Low for logic boards high output for ballast.Ballast feed from power supply should put out about 380 volts dc during projector boot up and zero during orange blinking light,(you can skip this removal of power supply if you read the 380 volts output on multimeter at boot up.Do this before taking all the boards apart but remove the side plate to access the output and check the output at boot up ,warning do not short this while reading output.
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-171.jpgpower board made by sumida and so is the ballast
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-198.jpgfinally the ballast is out this is what it looks like,do you see the dark grey wires they lead to the optocouplers (little led light sensing switch looks like a square little box all 3 are side by side)
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-227.jpg this resistor came out of the ballast ,notice physical damage like a hole in the center of it,tested it out of the board and yes its dead replaced this.
.Did all the checking one by one of the components then found one of the optocouplers had gone dead.The one located in the center of the 3 replaced that ,put it all back and got it working again.
The ballast cost 300 usd I bought one too and kept it handy just incase.
But for the meanwhile the old one is back and working just fine.
Aug 07, 2014 | JVC DLA-X3 Procision Projector
Why is there a small hole in the side of the left hand side of the hull on a 2002 regal lsr1800
it could be livewell drain(overflow) or even bilge outlet.check inside of boat.
Jun 30, 2014 | Boating
Where to hook water hose on boat motor (not in water) on ford 235 omc
if you look below the fin on the lower unit you will see some holes on both sides. their is a adaptor you can buy that will cover these holes and it will hook up to your water hose. you can get it at academe or boat supple. jerry
Oct 18, 2013 | 1993 Harley Davidson XLH Sportster 883
I have an AFI marine windshield wiper that mounts on my windshield frame on my boat. It has 3 wire connections on it covered by a rubber type boot.It is about 2 inches long and is held in by tiny screws.It...
Wow. You might be out of luck.
If you can't find an original, then I'd do one of three things:
Repair it. Buy some black liquid rubber. It's usually sold for electrical purposes, but can easily be found (I've seen it in Walmart's hardware section). It's in a metal can, with a brush in the lid, and gooey. If your rubber boot is split, I'd try taking it off & using the liquid rubber on the inside (for appearance's sake), maybe stretching the split so that the compound can get inside. Any excess can be cleaned up with acetone.
If you live in an area that has a lot of boating, find a boat junkyard. You might be able to find a used replacement. Alternatively, you can read or place postings on boat-friendly websites in the hopes that someone out there can help you find a replacement.
Fabricate. Improvise. Take it off, go to marine & auto and snowmobile parts stores & shops, show it to people, and someone might be able to come up with something (different manufacturer, different model). Think applications where weatherproofing is desirable (boats, airplanes, snowmobiles, ATVs, etc.)
Good luck to you!
Mar 03, 2011 | Computers & Internet
I have a 1989/90 procraft fisher 180. A through hull fitting forward near the keel is leaking slightly. The outer flange is gone. It looks impossible to replace. What is its purpose, and can I just...
if it isnt used then fibre glass it over but on the inside re-inforce it by fibre glassing a piece of 19mm copper pipe over the hole so it extends a least 6 inches either side of the hole depending on the size of the hole you might need two pieces thats all ,then away you go it will stand most onslaughts of the sea except a hurricane but then what will stand up to that .Us poor relations in europe i only have a local made small boat with a cabin and i have repaired it twice like this where it had been caught on rocks not by myself but the previous owner and it went twice on two different occasions in two different places and beleave me i got the brown marks both times where a strongwave made it start leaking and thinking i would lose my boat out at sea with this nice new mercury 4t engine but got back with the bilge pump on ,second time i went over the hull with a fine tooth comb but i have picked this tip up about the copper water pipe as bracing from another boat person and it works as the copper will not corrode
Aug 10, 2010 | Boating
There is a 4-inch long and 2-inch wide hole in the side of my aqua-glass tub. How can I patch this?
This going to be a 3 part solution. You can find all the materials you need a a Boat Supply Store or online. For the first step you will need all purpose filler such as FORMULA 27 ALL PURPOSE FILLER. It comes with hardener, Make sure the area you are working in is well ventilated. Follow the directions and fill inn your hole making sure to not allow it to stick out. Next you will need a Fiberglass repair kit. A kit is the best way to go since it will include everything you need. Again, good ventilation and follow the mixing instructions. You will need sandpaper, medium, fine and super fine (600 grit). If you build iu up to much you can and will need to sand it down. It will not be perfect but you can feather it into the existing area around the hole. Once this cures (hardens) you will be ready to go. The last step is cosmetic, gel coat, this is the shiny surface with the color in it. This step is up to you. It is not needed and can be difficult to match the color.
Good Luck
Mar 24, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
CHANGE STUDS ON BOAT
http://www.sailnet.com/forums/gear-maintenance/49777-dropping-keel.html
I found this site for you, I have never been involved in pulling a keel or removing lead, so you are on your own, check this out.
Feb 22, 2010 | Boating
Boating Logo
260 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
