Question about Hoover U6476-900 WindTunnel Vacuum
Replacing belt but where is the motor shaft
I took my vacuum apart to find out why it wasn't sucking up dirt (otherwise known as vacuuming ha ha). I found the flat belt wasn't attached on both ends. One end was attached to the brush roller, but the other wasn't attached at all. So, I knew what the problem was and went to the manual to find out how to attach it. It said to attach the other end to the motor shaft, but I can't find it anywhere! That sounds very silly I know but the manual's picture is pretty poor and looking around my vacuum I can't seem to find anything like that to attach it to! I'm desperate because I'm sick so I'm stuck at home but I'm leaving early Friday morning to go out of town and need the vacuum to work before I go! Any pictures to show me or a video or something would be so appreciated!
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
Re: Replacing belt but where is the motor shaft
The shaft of the motor might be through the hosing on the under side of the vac where the brush is. give me the model #
Posted on Dec 18, 2007
0 characters
3 Points
Replacing the belt for the motor
One way you can do it is by taking the bottom cover off of the vacuum and take the brush roller out, put the belt around the motor shaft & then slip the brush roller into the belt and pull on the brush to get it back into its normal place. Make sure that you get your bearing blocks both turned the correct way as well when you do it this way. If the brush is fairly new, make sure that the side of the bearing block that has several "hash" marks on the edge is facing up on both blocks. If the brush is worn, turn the block until there is only one "hash" mark showing and that will move your brush bristles closer to the floor. Re-assemble the vacuum just the opposite of the way you took it apart. Hope this helps!
Feb 18, 2015 | Oreck XL Ultra Bagged Upright Vacuum
What to do when your vacuum brush stops spinning
Household vacuums come in all shapes and varieties, but many of them are similar on the inside. There is often a brush running across the length of the vacuum's nozzle, and it spins as the vacuum runs to help **** up debris. But sometimes the brush will stop running, and you'll notice a severe decline in your vacuum's performance.
Usually when the brush stops spinning, it's because something inside the vacuum is binding it up. Dirt can get lodged inside, and hair can get wrapped around a shaft. If there is too much pressure, the drive belt can even snap.
You can usually see and clean the brush just by turning the vacuum upside down, but to get to the other internal parts you have to take the vacuum apart. On canister vacuums, this is usually pretty easy because it's just the nozzle that needs to come apart. Full-size vacuums can be taken apart as well, but the process can sometimes be more involved.
If you can get the nozzle or the vacuum's base apart and get to the parts inside, you should see the brush (which is part of a long shaft), a drive belt, and some sort of mechanism that drives the brush, which is commonly a paddle or a motor.
Hair can get caught up in any of these components and cause them to not be able to spin, as can dirt and other debris. If you clean all of the components out and put the vacuum back together, it should work just fine. The brush, over time, may become frayed or damaged, and the drive belt sometimes will snap, but otherwise a good cleaning will usually make your vacuum run as good as new.
on Jun 01, 2010 | Vacuums
I have a simplicity 7350 vacuum. The belt and roller have recently been replaced. It runs fine on floor mode and has no problems with suction. When I put the vacuum in carpet mode, I do not hear the motor...
the motor spins around a steel shaft that sticks out on one end, and the belt is driven by that shaft, belts are easily damaged and broken, meaning roller wont spin. Often a burning smell of rubber is noticed after motor shaft spins on stuck belt. cause is always hair./string/something at the three contact points. motor shaft and belt, roller and vacuum body become clogged. become familiar with taking cover off roller/belt, and cleaning Checking moving parts roller/belt come out easily and simple to clean...keep spare belts.
Mar 10, 2014 | Vacuums
My dirt devil has no main suction
You need to go a bit deeper in the unit to get what is clogged. it is most likely clogged on the inside of the unit. Take off the back and remove the inner workings following the path of the suction. Not hard to do just sucks.
Jan 24, 2013 | Dirt Devil Vision Turbo W/Bonus Upright...
I need help replacing the belt on my Dirt Devile Swivel Glide.
Look for a silver motor shaft behind the brush roll but in line with where the belt sits.
If the shaft is blackened with burned rubber or rusty, it should be polished with wet dry sand paper, XTRA Fine. Then install the correct belt onto the shaft and brush, using the brush to stretch the belt forward so the brush can drop into it`s housing. Buy belts 2 at a time. They only break when you need them most. I hide my spare inside the housing.
Sep 13, 2009 | Dirt Devil SwivelGlide Bagged Upright...
I have a dirt devil featherlite bagless vacuum; model #088600. It has suction through the hose but not through the floor mode. I think there is a blockage in the hose area but cannot seem to take it apart...
there are 3 screws 2 on the left side behind the hose and 1 on the right back by the wheel.that will take the cover off.if you need to get into the bottom there is a screw on the bottom plate in the area where it looks like the belt the brush roller turning if not then your belt is probably broke.before you replace the belt clean off the motor shaft and get the old rubber off it otherwise the new belt won't last long.please leave feedback .be sure to clean your filter inside the dirt cup
May 03, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Missing part on motor shaft?
the reason the belts are burning up so quickly is the old rubber from the other belts is still on the motor shaft.clean the shaft down to the polished finish then put on a new belt.make sure your brush roller turns freely .thats the other possiblity.the brush roller might be bad.sometimes hair and dirt get twisted around the ends and keeps it from turning
Jun 28, 2008 | Dirt Devil M086700 Vision Bagless Upright...
Motor not turning
Don't forget, the agitator bursh doesn't work when the vacuum is upright. Maybe that is your problem.
Apr 01, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Doesn't suck
you need too change the belt on the bottom where the brush is take off bottom cover and underneath is the belt if its broke replace it
Dec 22, 2007 | Kenmore 35912 / 35913 Progressive Upright...
Vacuum Cleaner sucking dirt out of the cannister instead of into it.
You didn't give you model number, but check by the brush roll to see if the inlet there is clogged, hose still has a clog, filters are bad and need replacing. Does the brush roll turn, belts stretch after short usuage and will not drive the brush roll under load, may need to replace the belt.
Oct 29, 2007 | Eureka Whirlwind 4496 Bagless Upright...
Hoover U6476-900 WindTunnel Vacuum Logo
104 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
