Question about HP Pavilion ze4540 PC Notebook
No caddy for hdd hp pav ze4540 - HP Pavilion ze4540 PC Notebook
  • 40 Answers
Goto ebay.com and find the hdd caddy online .. order the full kit to install a drive or second hard drive
Posted on Sep 28, 2009
Wpd file system problem
this could possible be the caddy take the HDD out of the caddy and plug into PC if HDD is picked up buy new caddy if HDD picked up but with faults use recovery software like recurrva if you plug it in and it does nothing then the HDD is kaput
Jan 12, 2014 | Verbatim EACH Drive, USB, 320GB, 2.5 in.,...
HP TouchSmart tx2 1050eo How do I get
HP has a home page,
go there and click support
then click your product.
then read the service manual. its all there, ever step every detail.
drum roll.
http://www.hp.com/
Oct 03, 2013 | BattDepot.com HP TouchSmart tx2-1050eo...
How do I remove HDD from HDD Caddy on Panasonic ToughBook CF-73
The caddy on all Panasonic Toughbooks are
held together by pressure.
I use several paperclips (unfolded) to wedge
between the side of the caddy and the small holes
which are located around the caddy. There are two
along the right side, one in the front and one in the
back and two along the left side.
I usually start with the far left side and work my way
to the back, then to the far right side, slowly prying
with pressure a few millimeters at a time.
Finally I go to the right front, then the front and
at last to the left front, almost in a circle.
It is a little tricky and may require several attempts,
but the caddy will come apart. Please try to remember
how the cable attaches to you can re-attach after
you change the hard drive.
Good Luck
Oct 28, 2012 | Panasonic Toughbook CF-73 Notebook
Toshiba satellite u400 hdd caddy adapter
Try to update your bios, so that you can boot in the proper order.
Apr 01, 2012 | Toshiba Satellite Pro U400-S1001X Notebook
Hp pav 1000 screen not lighting up
i can't get my hp pav screen to come on i replaced the motherboard because it had a bad spot on it can anyone help me
Sep 29, 2010 | HP Pavilion dv1000 Notebook
How to remove hard drive from acer 1360 aspire
Detach the machine from the power supply.
Turn the Acer Aspire 1360 over. Remove the battery.
The hard disk caddy can be seen centrally located from the battery bay (it is shiny metal). There is a piece of clear plastic attached to the back end of the caddy.
This is usually pushed back on itself under the plastic casing.
There are two screws located in the casing around where the HDD is located.
One is deepset and one is much nearer the surface.
Remove the deepset screw and put aside for later.
Get hold of the clear plastic strip attached to the HDD caddy (you may need a small screw driver to 'fish' it out). Gently pull the HDD caddy into the battery bay. It should come out quite easily, but you do need to apply consistent and mild force.
Once you have the caddy out, you will notice that there are two screws holding the HDD in it. Remove them carefully.
Remove the HDD from the caddy.
Putting back together is the reverse of the above.
Jul 22, 2009 | Computers & Internet
Does not see external USB HDD
You might check in your bios and insure that the usb is activated
Mar 14, 2009 | HP Pavilion zd8000 Notebook
Using a HDD Caddy!
Hi John!
I asume that you have that caddy, and its connected by USB?
Well, since your screen is black on your laptop you need to connect another screen by the VGA port on your laptop. Now start up your laptop, hopfully the graphics on yout motherboard is working and the screen lights up.
Now connect the caddy in a usb-port, windows will now find it and install it since its connected to an usb-port.
When the caddy is anstalled you can use it, you will find it under "My Computer"
Now you are redy to move all the files you want.
Select the file you want to move, COPY them, DO NOT cut them, if you cut them and something goes wrong you can loose them, by copy them they still are on your laptop. Copy the files, go to your HDD Caddy, open it, and paste the files. The files will now be copyed from your laptop to your HDD Caddy.
Good luck to you
If you find my answer helpful, dont forget to vote
Dec 11, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
HP Pavilion ze4540 PC Notebook Logo
46 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
