Question about Dell 1703FPs 17" TFT LCD Flat Panel Monitor
My dell monitor 1703fps comes on for about 2 seconds
Monitor comes on for about 2 seconds than the screen goes black. I took it apart and everything looks like it is attached. Is it the fuse? or the turn on button?
  • 22 Answers
I think if you can service your monitor please see all the filter capacitor i think capacitors leak and need for replacement.
Posted on Oct 01, 2009
Dell monitor 1703FPs
you backlights are going off.y ou need to replace the power supply in this monitor very comon problem
Dec 30, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
Every time I turn on the monitor it will work for 1 second and then gets a black screen
Hi ,
Check when you boot the system is there any display coming and when Operating system boots you get any Balck screen if it comes then there is a issue with the Graphics card in the system.
Pc and monitor turn on, monitor goes off after few seconds
Please don't get advise from India, this model has a known "Inverter" problem. Order a new one on ebay, and replace it... Problem solved!!
Sep 24, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
How do I get the case open on my Dell Ultra Sharp 1703FPs?
kenm951, You may want to see some vids on YOUTUBE that show disassembly of LCD monitors. Some of the longer ones (8 to 12min) are ok, but audio leaves something to be desired. The big question to you is why would you even want to open up your monitor?????? Bye for now. I'm louie12fix on fixya
May 06, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
Monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
The screen afetr minimum use
Hi John,
Its a possible loos contact in the VGA port that connects your monitor to the PC. Switch off everything, check for all possible loose connections, inside & outside the PC's cabinet, rectify if any found and restart.
If the problem still persists then there's something wrong with the Power Options Settings that you may access thru control panel. I recommend that under the First Tag i.e. Power Schemes select "Never" in all the dialogue boxes for turning off Monitor, Hard Drives & System Standby and under the 3rd Tag i.e. Hibernate, make sure to uncheck the box next to Enable Hibernation.
That's about it. I feel this should solve your problem.
May 05, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Powering on
checked your monitor with a qualified proffesional.
Apr 01, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Black Screen
No, this is typical problem for defective inverter. Mostly screen appears for some seconds and then turn to black. If you are technician, you can use this link :-).
http://www.lcdrepair.us/1702inverter1900x.html
Oct 01, 2007 | Dell 1703FPs 17" TFT LCD Flat Panel...
Blank after 2 seconds
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps.
Jun 14, 2007 | Dell UltraSharp 1703FP Flat panel TFT 17"...
Black screen
Try pressing the 3rd button, as it toggles the Analog or Digital inputs...
Oct 05, 2006 | Dell 1703FPs 17" TFT LCD Flat Panel...
Dell 1703FPs 17" TFT LCD Flat Panel Monitor Logo
465 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
