Question about Sony Televison & Video
I have a Vega Trinitron XBR KV-36XBR250 30 inch
I have a Vega Trinitron XBR KV-36XBR250 36 inch that is 10 years old. We have had no problem with it until now. The picture flashes on and off and the display (4) appears - then this repeats. The sound is fine. It seems fine for a while until we change a station or forward the DVR. The red light stays on with no blinking. We had the cable guy come out thinking it was the DVR connection, but to no avail. Do we need a new remote for the TV??
  • pegmarsh Oct 05, 2009
    What does solder mean?? do you mean sodder?
  • Sony Master
  • 5,138 Answers
Its a Good Chance your CRT is shorting out,You can try replacing CRT board on Neck of picture tube, sometimes you get lucky and its CRT socket pinns on crt board, but I would replace crt board first and If it is Picture Tube, Its Not Worth fixing! Most of the time Hori output will short along with FBT being bad then if you replace them then you find out TUBE is bad and that was what caused other parts to go out!
But first if you can solder, resolder all poor connection Look for any swollen or puffed up capacitors if you see any like that they are Bad, then its up to you about getting crt board.
Posted on Sep 28, 2009
  • ladywinn
    ladywinn Oct 05, 2009
    Solder is what you have to do on Boards to repair or remove Bad Parts.
  • ladywinn
    Did some check and if you replace CRT BOARD it is board that connects to Picture Tube this will Fix your Problem! Call Encompass see if they have Part 1-800-638-3328 or Call Mats 1-800-628-1118 Tell them you need a CRT Board for Sony TV,KV- 36XBR250
MY sony trinitron XBR TV does not stay on.
what's wrong with my Sony trinitron XBR tv's timer
Apr 27, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture or sound when powered up. Red Standby light flashes continually. My Sony KV 36 XBR250 Wega Trinitron XBR is about 10 years old and has worked perfectly up to this point. What could be the...
Did you get your set fixed or did you replace it? My same set did the same thing. Turned it off for 2-3hrs after watching it and when I tried to power it up- nothing but the sound it would normally make just before the major power up, sort of a relay click sound. No picture or sound but the red light blinks non-stop.
Jan 20, 2010 | Sony KV-36XBR250 TV
Sony trinitron xbr (9 years old) failing to power up
Turn it off u leave on to long ur CRT Tube will dies soner.Resolder the FBT,the flyback transformer, the big block of plastic with a red wire with a cap hook to the and the transistor beside it.This transformer is the HV to the CRT to get power.
Jan 15, 2010 | Sony FD Trinitron KD-34XBR960 34" TV
Trinitron XBR Try to turn on but light just
Look for the service manual, it contains the explanation of the flashing light codes, it will tell you what part is faulty.
Jun 26, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron XBR, Stand By Mode?
The 6 or 7 blinks usually indicate a problem in the horizontal circuit. Since the TV recovered once, the problem is most likely to be a bad solder connection in that area. If you can solder, resolder any connections on the board that appear grainy or have rings. That may resolve the problem. If not, update this and we'll look elsewhere for defective parts.
Dan
Sep 16, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
3 year old VEGA TV: LED indicator 9 times blinking
Use remote control:
display, 5, volume +, power
I can turn on my TV, though with the fault codes on-screen. Holp it helps.
Sep 06, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
32 xbr vega trinitron PIP wont turn off
Just press any channel number and PIP will disappears :)
Dec 25, 2007 | Sony KV-36XBR400 36" TV
Televison & Video Logo
53 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
