Question about Kohler Barrington Pressure Lite Elongated Toilet by - 15 Inch Bowl Height
When flushed, not enough water flow to empty sides and waste
When flushed, not enough water flow to empty sides of bowl. Lots of pressure but not enough water to empty all the waste.
  • Danny Clark
    Danny Clark May 11, 2010
    If you hold the handle down does it then provide enough water?
  • 396 Answers
Mineral deposits can form in the holes around the rim where the flush water enters the bowl. This lessens the water flow and weakens the flush action. Clean out these holes with a stiff piece of wire or something similar.
Also, if your toilet is one of the types which has a syphon hole in the front part of the bottom of the bowl, these also can get stopped up with mineral deposits. Use a screw driver, ice pick, or something similar and try to chip out these deposits.
Posted on Oct 10, 2009
  • 38 Answers
Make sure water level is sat at factory settings. there should be a black line that reads WATER LEVEL. If this is not the problem. then you have calci buildup. get a gal. of muratic acid,plunge all water out of toilet bowl. then dump in at least 1/2 gal. let set over nite. with water turned off. get up turn on water then flush. You mite have to do it twrice. hope this helps you.... duane.
Posted on Oct 04, 2009
Why doesn't the waste go all the way down? It takes several flushes.
Welcome to our new world of water conservation. If you have a toilet that isn't newer....you have something in your trap weir. Or your flapper is malfunctioning. Or your float valve isn't filling your tank correctly. Or your bowl scouring ports could be clogged. There are sooo many things that could cause this....
.New toilets do this because their design to use less water has reached the point of no-longer working to clear the bowl contents. Plain and simple. It has became the norm to flush once for #1's and flush (how ever many it takes to flush all waste) for #2's.
Back to old styles...You can remove the tank top and inspect the water level in the tank(should be about a 1/2" below overflow tube when full), inspect the flapper(flush the toilet and see if your flapper is staying up long enough to allow enough water to enter the bowl to cause a syphon action that ends with a suction sound and complete emptying of the water from the bowl), flush your toilet and look in the bowl to see if the water spraying from your rim is adequately dispensing water to scour the sides of the bowl, and also look at the jet that shoots water from the bottom of the bowl...aimed toward the outlet portion of the very bottom of the interior bowl. This jet is what starts the syphon action that empties your bowl. If you have something stuck in your trap weir....you probably need to call your Plumber to auger the object out or break it down to a size that will pass into the sewer.
The small ports that spray your sides can be cleared with a 3/16" stiff nylon brush...the jet down below can be cleared with a 1" stiff nylon brush. Flapper malfunction is repaired by replacing the flapper. Incorrect water level in the tank can be fixed by adjusting the valve float. but chances are that if it is all of a sudden malfunctioning...it probably needs to be replaced...good luck and always know how to turn your water off before starting work on your plumbing.
Be gentle with the parts inside your toilet tank. Using a calcium remover when clearing bowl inner ports and jets will help tremendously....but be certain to read the container and follow all handling/use instructions you read. Be careful.....Nick
Mar 06, 2015 | Plumbing
Why wont my have a cimarron k3489 toilet fully flush? the water empties from the tank but the water from the bowl does not go down.
That's an interesting one! Does the flush valve close properly so the tank can refill? Does the float valve allow the tank to refill fully, to near the top of the overflow? That can be adjusted, if it doesn't.
Check fhe flush valve - you may have an obstruction under it. Also check the water port from the bowl side - feel up inside the port for obstructions or buildup of hard water deposits.
WASH YOUR HANDS THOROUGHLY afterwards.
Jul 29, 2014 | Kohler K-3489 Cimarron Comfort Height...
When flushing , the bowl will not drain properly or fast enough to discharge the waste,also the bowl will not fill back up to the correct level with clean water, Acts as if there is some type of blockage...
It sounds like there is a buildup of waste at the top of the trap in the toilet. A closet snake should resolve the problem. You do not have to snake more than a couple of feet of the drain if the buildup is at the top of the trap which is always dry. Try the closet snake and a couple of buckets of hot water while flushing the bowl. Rigid makes a good closet snake and is worth the cost. After clearing, make it a habit of holding down the lever until you hear the tank empty when flushing down solids. Especially with the 1.6 gallon tanks.
Sep 11, 2013 | Toto Promenade, 1.6 GPF, Elongated...
Can't get enough water in toilet bowl to flush the waste
Adjust your tower to let the bowl fill up more.....google your problem if you dont understand...depends on what kind of tower you have....should have teeth on the tower itself to make it fill more...try pulling up on the float...
Mar 15, 2012 | Jacuzzi Bath Perfecta EZ33 959 White round...
Have brand new 3489 cimmaron 1 piece toilet. tank empties on flush but no suction empty on bowl. water only eventually leaves bowl
It may be the wax ring expanded and is restricting the flow.
If you did not install the unit FYI ..the wax ring is inserted between the toilet and the waste pipe to prevent leakage. Sometimes it moves out of place when the toilet gets installed and blocks the flow
Feb 23, 2011 | Kohler Home
Just hooked up new pressure asist tank & bowl,turned on water to it,and it want flush.what i mean about want flush, is it will flush but water does'nt go down,as if it's not staying open long enough.
Sounds like you have a clogged drainline or vent-stack. Fill a large bucket with about three gallons of water and dump it quickly into the bowl. If the drainline/vent is clear, the toilet will "flush" like a gravity toilet and the water will drain from the bowl almost as fast as you can pour it in.
If the water level in the bowl slowly rises (as if it's about to overflow) and then slowly drains, you have a clog somewhere.
All toilets, regardless of their flushing mechanism, require a clear, unoibstructed drain/waste/vent system to extract waste.
If the toilet "flushes" with the bucket of water, you may want to call Flushmate tech support (the number is on top of the tank) or check out the installation and troubleshooting videos at howto.flushmate.com.
Hope this helps.
Aug 18, 2010 | Sloan M-101526-F42 Flushmate?® Complete...
Macerator keeps going off even when not flushed.
Water pressure makes the unit turn on and off. It will only activate on it's own when enough water pressure is present. Most likely it can be water leaking from the toilet tank into the bowl, and from the bowl into the pump. Or could also be that waste water is slowly draining back into the pump through the check valve on the discharge elbow, creating enough water pressure that it will make the unit kick on and off.
Aug 06, 2010 | Saniflo & Saniplus& Macerator Pump
Basement toilet drains slow sometimes ,other times doesnt want to go down all the way. seems as if there is no pressure to remove waste
if the toilet is old or not cleaned proper, the water jets that shoot the water into the bowl might be clogged. If the jets are clogged with moldor hard water build up the toilet will not flush proper. If you can take a 3 gallon bucket of water and pour straight into the bowl and it flushes fine you have a water pressure problem as described above. the problem also might be that your water inlet system is not letting in enough water to fill the tank. If this is the problem you need to replace the water inlet mechanisim, such as a fluid master. If you use a blue water device that hangs on the side of the tank in the back of the toilet you might have a peice of it under the flapper that takes the water to the bowl when being flushed. Check under the flapper if you put cleaners in the tank.
Mar 23, 2010 | Crane Plumbing Toilet To Go Tall...
My daughter flushed he winter hat down the toilet. How do i get it out?
Kids eh?
.. I had my son flush LOTS of wipes down ours ...
*** STEP 1 ... DISCONNECT THE MAINS POWER SUPPLY!!!! ***
You'll need to drain the main toilet bowl of water and remove the toilet bowl away from the sanoflo. This may require that you also empty the cistern and stop the water from entering it (do you have an inline valve to the cistern supply pipe?)
When you have emptied the water and removed the toilet bowl there should be a large Jubilee clip attaching the saniflow to the WC waste outlet. Loosten this and remove it so you can see into the saniflo where the WC waste goes.
You should be able to see the object and reach it with your hands. I would suggest wearing some rubber gloves to protect your hands from getting gunk in cuts etc.
If you cannot get to the object, you'll need to empty out the other pipes to the Saniflo and remove the unit. When you have done this you'll need a star driver to open up the unit and get to the object inside. I would suggest that since most of the saniflo range have an internal grille to stop objects such as this actually hitting the macerator that you should be able to reach it just by disconnecting the WC waste connection
If this helps please leave feedback
Feb 09, 2010 | Saniflo 013/003/005 Sanibest Toilet with...
Have to flush 2 or 3 times to empty toilet bowl
hello, this is a standard toilet you will need to inspect the flapper that is the rubber flap that holds the water up in the tank it works when you pull the lever it pulls the chain upward and lets the water flow if this flapper is old it may not stay up long enough for the water to flow. open the tank top and flush the toilet see if this flapper is staying up long enough and giving the tank enough time to empty if not change this rubber flapper its inexpensive part.
if this is not the reason then you need to adjust your water filler valve there should be a small screw on top of the pivoting float arm
if you have to adjust it for the water limit line inside the tank this will be the proper amount of water needed to flush once completely
also check that the chain lenth on the pull lever is not pulling the flapper down quicker than its supposed to,
try this let me know your results
hope it helps
Dec 15, 2008 | American Standard Home
Kohler Barrington Pressure Lite Elongated Toilet by  - 15 Inch Bowl Height Logo
311 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
