Wells Gardner PD197700 OSD Don't work - Televison & Video
How do I unlock screen controls for LG W53 27" monitor?
Press and hold the Menu button for several seconds to toggle the OSD (on-screen display) Lock on and off. The Menu button is the third button from the left in the group as you look at the front of the monitor. You should see a message on the screen when the OSD lock is disabled.
The OSD Lock feature is described in the manual and is the same for all W53 monitors. See http://www.lg.com/us/support-product/lg-W2753VC-PF for the manual of one of the monitors. The direct link to the manual came up as http://www.lg.com/us/lgecs.downloadFile.ldwf?DOC_ID=KROWM000230850&what=MANUAL&fromSystem=LG.COM&fileId=KROWM000230850.pdf&ORIGINAL_NAME_b1_a1=W2753VC_EN.pdf .
I hope this helps.
Apr 12, 2016 | LG Computers & Internet
Osd unlock
To unlock the OSD (onscreen display control), turn off the monitor and then press and hold the Menu button on the monitor. Then press the power button to turn the monitor back on. Do not release the Menu button before pressing the power button. This same step (holding the Menu button and then pressing the power button) enables the OSD lock. The menu button is the top button on the right side of the monitor (on the bezel). The power button is the bottom button of the group. AOC has the documentation for the 2036sa here: http://us.aoc.com/monitor_displays/2036sa . See page 20 of the User's Guide for the OSD lock procedure. The picture of the monitor buttons is on page 19. The guide is available as a PDF on the AOC site. Note: you will need Adobe Reader or a similar program to read the file.
I hope this helps.
Nov 01, 2012 | AOC 2036sa 20"TFT LCD Monitor
I have a dell monitor and I keep getting this notice that control menu is blocked. how can I resolve this?
For the E771MM, press and hold the OK button on the monitor for 15+ to toggle off the OSD lock. Holding the button turns on the OSD lock as well. The OK button is the rightmost of the control buttons (excluding the power button). This is a useful feature if a small child will be near the monitor or if the monitor is being used for demonstrations.
The user's manual for the Dell E771MM is here: http://support.dell.com/support/edocs/monitors/e771mm/English/index.htm .
I hope this helps.
Jul 01, 2011 | Dell E771MM 17" CRT Monitor
Cant access OSD Menu on my ViewSonic N4060, upper left message says its bloqued
The OSD lock can be toggled on and off by pressing and holding both Vol+ and Vol- on the side panel of the TV. On some of the older Viewsonic models, you have to hold the buttons for 10 seconds. I'm not sure how long you have to hold the buttons for the N4060.
I hope this helps.
Mar 22, 2011 | Televison & Video
The OSD screen is up and won`t dissengage(after trying the 10 second hold down) , also the video display say`s switch the cable leads , I don`t understand. The menu,+,-, auto buttons won`t work. What might...
try powering off your monitor and disconnect the cable at both ends. switch the ends if that doesn't work try another cable.then turn the monitor back on see if the osd menu went away.
Mar 23, 2010 | HP RY117AA w2408 24" Widescreen LCD
Gardner Bender #GVT-392 Solenoid Voltage Tester manual where can i download one at
Google " gardner bender GVT-392 manual".... there is plenty of hits good luck
Dec 31, 2009 | Gardner Bender #GVT-392 Solenoid Voltage...
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
Electro Med Services...
