Question about Plumbing
I have a wayne fuel dispensing pump model#730 that wont pump The motor & pump spin but no liquid is moving
  • 832 Answers
Check the suction line for leaks. No leaks-how about the
checkvalve? If it's okey, open and fill the priming port with fuel to full level. and start the pump. What happened? Send us your e-mail comments, and may the Lord Almighty bless you.
Posted on Oct 26, 2009
How do you program a wayne intelligent digital pulser fuel pump?
by using the supplied custom program, if you do not have it contact the manufacturer, give them your model number etc & they will be able to supply you with the software
Nov 11, 2014 | Cars & Trucks
1994 gmc jimmy gitting fuel wants to start but backfires out of carb help
There is no carb on a fuel injected vehicle,like for the
last 25 years or more
Have you checked for fuel pressure at motor with a gauge?
Have you checked fuel trim with a scan tool?
I suspect you will have to remove the top of the intake & replace
a leaking fuel pressure regulator
Google your engine & all the problems with injector spyder problems
You can go to YOU TUBE VIDEO & watch Wayne at Real Fixes Real Fast on that issue
Feb 07, 2013 | 1994 GMC Jimmy
I have a proform 730 siteline, model PFTL 70070 and the electronic display is malfunctioning. Shuts machine off, sometimes it resets itself, etc. I've checked power supplies, motor control board,...
Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk. 11_10_2011_6_11_10_pm.gif11_10_2011_6_11_30_pm.gif
Sep 10, 2011 | Proform 730 Folding Treadmill Model...
Hi, Wayne PC4 pump doesn't work. Can anyone help me?
The most common issue with these pumps is that the impeller gets stuck from non usage or from debris getting stuck in the impeller.
Take the cover off of the pump section and make sure that the impeller is free of debris and that it will turn freely. If it turns hard you may be able to free it by working it back and forth. This may take some time to do. I'm not sure about this particular pump, but on some you can get a lubricant like WD-40 worked into the pump and motor bearing also...
If the impeller is spinning frreely and the motor still does not turn on then you have a bad motor. To replace this motor will probably cost nearly the price of a new pump. It may be better to just replace the whole pump.
Heatman101
Mar 15, 2010 | Wayne Water Systems Plumbing
Wont go into spin cycle and wont drain but makes a buzzing sound while in the spin cycle
plugged or bad pump or bad drive motor. if it has a seperate pump and motor for drain could have somthing in it if the pump is driven by the main motor pump could have frozen up or motor could be bad in spin mode sometimes the timer won't make the motor run just hums ges are good for this make and model #s help us help you good luck
Dec 08, 2009 | Washing Machines
Maytag front loader wont spin
door interlock is most common 9 (SW ON RIGHT SIDE IS SPIN ENABLE /ck this first - other componets are motor controler/& motor . iffull of water the pump could be at fault.. need model # to give you the best ans. hope these will help mm
Dec 06, 2009 | Washing Machines
1997 Daewoo Nubira no fuel to motor
check volts at pump with test light, replace pump
Sep 08, 2009 | 1985 Chevrolet Corvette
Blows 6 amp fuse in top panel. On spin cycle runs the pump but motor wont rotate for spin. If left blows fuse again.
Remove the hoses and check the impeller of the pump for an obstruction.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Washing Machines
Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Plumbing Logo
316 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
