Question about Canon PowerShot S3 IS Digital Camera
I want to buy a Sundisk 8 MG memory card for my Power shot S3 will it work in the camera?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
If you mean an 8GB card then yes, the S3 will work with it.
Posted on Sep 23, 2012
  • kakima Sep 23, 2012
  • 5 Answers
SOURCE: sd card error on canon powershot s3
I have had a similar error which turned out to be a corrupted memory card. It was replaced under warranty with no questions asked. Causes may be static electricity discharge or a high humidity/temperature combination. Either way get a new card.
Posted on Jul 31, 2008
  • 8 Answers
SOURCE: canon power shot sx 100 reads card locked
SD Memory cards have a tiny switch on the edge that marks the memory card as read only and prevents any writes. If you get the message "Card locked!" when you turn the camera on then turn the camera off, eject the SD card. With the card facing you (metal contacts facing away) the switch is on the left hand edge, slide towards the top of the card to make the card read/write again.
Posted on Dec 19, 2008
hsanfor
  • 71 Answers
SOURCE: memory card capacity for my older canon digital camera
Does you camera use CF cards?
If so the may work but some of the newer high tech CF cards are made for newer cameras.
It may be worth a shot to try the 2GB card and if it does not work, sell to someone who uses those.
Posted on Jun 17, 2009
t00nz
  • 4738 Answers
SOURCE: when i insert 4gb memory card into canon power
Your new 4GB memory card is the problem. The card would likely be an SDHC card (look on its front cover). Your A540 camera was designed well before the SDHC format came out, and your camera will not recognize it. Your camera can only use standard SD cards (2GB or less). Here's some from Amazon.
Posted on Feb 14, 2010
old marine
  • 2153 Answers
SOURCE: I have a cannon power shot SD600. I bought a
Did you get an SDHC card? The SDHC protocol was developed after the SD600 came out, and the SD600 is not compatible with it. Use SD cards with a maximum of 2GB storage capacity.
Posted on May 24, 2010
Canon power shot A610, will it support sundisk 16GB?
No. The A610 works with MMC and SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Dec 21, 2013 | Canon PowerShot A610 Digital Camera
How do i unlock my memory card:ULTA2.0 GB SunDisk?
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
BTW, It's "SanDisk" not "SunDisk".
Jan 23, 2012 | Cameras
Is it possible to recover deleted video from my canon power shot s3 is without buying software?
you can recover deleted files from camera with asoftech data recovery program... Download the program
http://www.asoftech.com/adr/
You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
Mar 06, 2011 | Canon PowerShot S3 IS Digital Camera
I PUT THE WRONG CHIP ON MY CAMERA "POWER SHOT S3
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Oct 31, 2010 | Canon PowerShot S3 IS Digital Camera
What battery do I need
The battery for the PowerShot G3 is the Canon BP-511A.
Mar 26, 2010 | Canon Accessory Kit (ACCS) Battery Case...
Need to buy DSC-T1 Memory Stick 4 MG and Battery
The memory stick can be purchased at amazon.com The battery can be purchased at bestbatt.com
Feb 05, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
Unable to save shots on memory card.
You can download the Camera User Guide here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=320&modelid=9828
As for the memory card, have you tried another one? This camera should be able to hand Compact Flash (CF) cards up to 2GB in size.
Jun 23, 2009 | Canon Cameras
SD message error
go into the settings and "format" the sd card, that should solve your problem
kind regards and please don't forget to rate us
Nov 30, 2008 | Canon PowerShot S3 IS Digital Camera
Canon PowerShot S3 IS Digital Camera Logo
54 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
