Question about Compaq Keyboard
My keys are not working properly, having trouble
My keys are not working properly, having trouble with the keys not working when pressed normally have to press really hard for them to work. how do i clean underneath the keys please.
    Problem Solver:
  • 13 Answers
Use a can of compressed air to loosen dirt. Then turn kboard over and litely tap on back. You will be amazed at what falls out of the keyboard.
Posted on Sep 28, 2009
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Have trouble with computer freeup when trying to go to links in e-mails. have to go to ctr alt delete to clear screen. then internet freezes and I have to reboot computer.
It seems that your OS has registry problem, so I would suggest you to fix it properly with the help of these tips given below:-
- start PC in safe mode, normally Pressing F8 key when windows starts up.
- In Safe Mode create a new user, with administrator privileges and protect it with password.
- Remove any Antivirus.
- Download Intel software Partner reliable program RegInOut to optimize your internet and fix OS registry properly
- Restart your PC normally and log on to the new account created.
Hopefully you will get better results
Jun 12, 2013 | Computers & Internet
Error code c-2152
C 2152 : Transfer belt separation.Check the main motor connector for proper connection,check the image transfer pressure/retraction position sensor and clutch.For reset the error turn OFF the copier press and hold pressed the Utility key and turn ON the copier,wait to Trouble reset message appaire on the display and release the utility key and touch the trouble reset ,turn OFF the copier ,wait 1 minutes and turn ON.
Mar 03, 2013 | OCE Office Equipment & Supplies
In mu nokia n73 when I press key 1 it open gallery,press 3 it appears 2 and press call key it open camera please help me
Try to reset your phone to its normal mode. go to phone settings... then click factory settings, your phone will function properly on its normal settings. thanks
Mar 12, 2011 | Cell Phones
How do you put windows into safe mode?
Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 26, 2010 | Computers & Internet
I am getting a flashin L and can't make copies?
L1 = Scanner (reading) feed trouble Scanner (reading)
L3 = Scanner (reading) return trouble Scanner (reading)
Reset method :
* Entering the simulation mode
1) Clear key ON - Exposure mode select key ON - Clear key ON - Exposure mode select key ON
(The machine is ready for entry of the main code of simulation.)
2) Main code input by 10-key ? Start key ON
3) Sub code input by 10-key ? Start key ON
The machine enters the selected simulation mode.
Press the start key to start the operation of the selected simulation.
Main Code =(14 Used to cancel the self diag other than U2 trouble.)
Sub code = 0
* Canceling the simulation and returning to the normal mode
1) Press the clear key.
Copy SIM 14
Sep 07, 2010 | Sharp AL 800 Copier
How to solved code H4 Xerox Xc1245
This code is akmost always a false code. I would try clearing it by entering the following key sequence:
Press "Clear" then "Exposure Mode" then "Clear" then "Exposure Mode" (Note that the exposure mode key is the far left key and that these 4 keys must be pressed within 4 seconds)
The display should have gone blank if these 4 keys were pressed properly.
Now enter 14 as if you were making 14 copies then press the Print Button.
This should clear the H4 code and the machine should operate normally.
If not and the H4 comes back then you have either a thermal fuse or heater lamp failure.
Good Lucj
Nov 09, 2009 | Xerox XC356 Copier
Keyboard keys not working properly
the problem you're having is a setting in your control panel. I don't know what OS you're using but if it is Vista, go to control panel and click on ease of acces...and click on MAKE THE KEYBOARD EASIER TO USE...unclick Turn on StickyKeys, Togglekeys and filter keys. Then go to control panel and open Keyboard...and increase the repeat and delay rate. If all these doesnt work...it means it might be a hardware problem
Jun 14, 2009 | Computers & Internet
Keyboard Fn key
Try hooking up and external key board see if that works ok, and if it does you may want to try to find a new or used key board for your laptop. The key board may be shot, It should be fairly easy to change to a new board, Hopefully That will help you diag. the problem..
Jan 06, 2008 | Acer Aspire 5630 Notebook
Compaq Keyboard Logo
201 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
