Dear Sir my washing machine which is one year old started for the last couple of weeks todo unnecessarily noises and also it doesn not drain the water, showing code F05. WHAT TO DO? thank you!
    Scholar:
  • 83 Answers
F05 on an Indesit washing machine means "Pressure switch jammed on trip"
As is often the case, knowing the error code is one thing, but findng the cause is another because error codes often have several possible causes. The wording of the error code explanation suggests the pressure switch clicked on to register a water level, but when the water was drained away it remained on instead of turning off. I would guess there could be a blockage in the pressure system, or the pressure switch could be faulty. Also, if the water didn't drain properly it would cause the pressure switch to stay on too. Finally, the Indesit washing machines PCB's can give erroneous errors where the fault turns out to be with the pcb itself. This makes things very difficult if you don't have access to replacement PCB's to try.
Basically, I would keep an eye on the washing machine and try it again. If it reoccurrs then clearly it needs sorting, but if it doesn't it might have just been one of those things.
Posted on Sep 28, 2009
Roper washing machine whines intermittently throughout the entire wash, rinse and drain cycle.
Roper whining noise Washing Machines Questions ... - Fixya
www.fixya.com > Forum > Tags > whining noise > Washing Machines
Roper washing machines whining noise related questions and answers. Ask your Roper questions. Get free help from washing machine experts.
Sep 28, 2015 | Roper Washing Machines
What is causing my Kenmore top washer to make a grinding noise before the rinse cycle?
Have you replaced the clutch or spin tube? There is a brake actuator that comes with the clutch kit and if this is broken it can make a very loud grinding or clacking sound.
Jun 25, 2014 | Kenmore Washing Machines
The tub won't drain and it spins very slowly. I've also noticed, over the last couple years, some oil/rust spots on my clothes. It is a top loading washer that is over 20 years old.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 13, 2010 | Amana Washing Machines
Lights flashing water wont drain but making a humming noise
hello sir,
Please do the following checks
  1. nspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch (some models)
  4. Inspect the water pump
  5. Inspect the drive belt (belt drive only)
  6. Inspect the motor coupler
Click on the highlighted words for details on how to check.
Jun 04, 2009 | Maytag MAH2400A Front Load Washer
Strange noise upon initial start-up
try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
Jun 01, 2009 | Whirlpool LHW0050PQ Front Load Washer
My whirlpool duet is about 1.5 years old. It has been working great until the last few weeks. I have had a burning spell coming from it. Now it won't drain or spin out. Just makes a buzzing noise. The...
you may want to check your pump and see if something might be stuck,you should be able to take bottom kick plate off in front of machine.when you take it off you will see the pump.most have a filter you can unscrew and pull out to see how much junk has collected.the buzzing is usually your pump or doorswitch.
Mar 24, 2009 | Washing Machines
ASKO 1605
Hi Guys
My dishwasher this morning has desided to not work correctly.
Its a ASKO 1302 about 20 years old. It has been a very good machine.
Over the last couple of weeks during the washing cycle, the dishwasher has been making a loader noise than usual.
1. Today, the dishwasher timer, travels all the way through its cycle, but very little washing take place.
2. Soap power is still there, plates not clean!!!!
3. Water is hot
4. At the end of the cycle, there is no water in the dishwasher.
5. I'm thinking the problem could be the pump needs replacing.
What do you think?
Greg
Sep 05, 2008 | Asko 1375 Dishwasher
20 year old washing machine leaks
the tank is hooked to the pump and the pump to the drain hose, by flexible rubber couplings.
Try those couplings to see if they have deteriorated, they are cheaper to replace than to buy a new washer ort get a service man
Jul 27, 2008 | Washing Machines
Stackable Washer will not drain.
check if there is a low humming noise when on drain. if so there may be a foreign object trapped in pump. otherwise have you checked filter?
Apr 02, 2007 | Whirlpool LTG6234D Front Load Stacked...
Washing Machines Logo
214 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
