Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Doesnt pick up water - Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
    President:
  • 1,653 Answers
Possible Causes Remedies
ReadyTools Dial may be at the wrong setting for the cleaning job <> Set ReadyTools <> Dial to either Tools / PreTreat or Floor Cleaning.
Nozzle Window may not be properly attached. <> Press down firmly on the black oval gasket at the top
Window to make sure the two tabs on the back of the Nozzle Window are snapped into the mating slots in the main housing.
Tank-in-Tank lid is not installed <> Re-install lid;
Tank lint filter is blocked <> remove all lint and debris from Tank lint screen.
Tank-in-Tank is not properly seated. <> Tank-In-Tank must be firmly seated to function; remove
and reseat Tank-in-Tank.
Poor tool position (Hand held attachments only). <> Adjust angle; apply more downward pressure.
Tank-in-Tank has picked up maximum dirty water <> Empty Tank-in-Tank
Front Clear Floor Nozzle Window ids blocked <> Remove window and clean all fibres and debris then replace.
Insufficient suction <> Clean Pre and Post Motor Filters.
Posted on Sep 28, 2009
Royal carpet extractor not picking up water well
Try to follow the suction from the machine through the dirty water tank to the front floor suction piece. Make sure the dirty water tank is seated properly. Make sure there are no suction leaks any where.
Mar 21, 2014 | Royal Procision 7910 Carpet Extractor
Hoover steamvac delux 5 brush ag doesnt **** up all the water that it puts out not even close
ITS THE DUCT PIECE ON THE FRONT OF THE DIRTY WATER TANK (DWT). ITS NOT LINED UP.
1. TAKE LID OFF OF DWT
2. SLIDE THE LITTLE SQUARE PIECE (5'X5'X1) (THE DUCT) ON THE FRONT OF THE DWT AS FAR UP AS POSSIBLE AND IF IT BENDS FORWARD FROM THE TOP, DO THAT TOO (SOME MODELS OPEN LIKE A DOOR TOP DOWN, OTHERS JUST SLIDE UP AND OUT COMPLETELY)
3. SLIDE THAT DUCT BACK DOWN AS FAR DOWN AND BACK AS IT WILL GO.
4. PUT THE LID BACK ON BY HINGING THE FRONT LATCHES ON AND THEN SNAPPING THE BACK SIDE DOWN.
5. CHECK TO SEE IF THAT DUCT PIECE ON THE FRONT IS LOOSE BY PUSHING ON IT AND SEEING IF IT MOVES UP AND DOWN.
IF IT IS, THE LID ISNT COMPLETELY ON, GO BACK TO STEP 4.
IF THE DUCT IS SNUG, CONGRATS YOU SHOULD HAVE JUST MADE YOUR STEAM VAC PICK UP THE WATER AGAIN
Jun 13, 2013 | Vacuums
Won't pick up water from the clean water side
I couldn't view u'r clip but it seems if the pipe is blocked try to remove the blockage by using a hose where you spray hot water and normal dishwashing liquid, through the pipe, to unblock it. Just do not immerse the whole machine in water! Because I do not know what machine you have. Good luck my friend!
Mar 23, 2013 | Vacuums
Does not suction/pick up trash and debris.
we have an eureka 4495 model and it doesnt want to pick up the dirt off the floor but the hoses are clean and the hose it self has suction and the roller and belt are ok and turn
Feb 02, 2011 | Eureka True Clean Upright Vacuum (Yellow)...
The Hoover Steamvac Widepath will NOT pick up water. The dispenser with cleaner DOES have water. The TANK that would receive the dirty water is NOT full. All tanks are on properly and the machine will...
Sounds like a clogged air path (no vacuum action) from the floor pick-up to the collection tank. Take the tanks off and deal with the vacuum problem alone. The collection tank should have a air exit vent--is it clear? Check the interior hose that you repaired--is it clogged? Remove the bottom plate and inspect the air path from it. Because this machine deals with water, clogs can become like concrete! Hope this helps!
Apr 12, 2010 | Hoover F6213-900 SteamVac Agility...
My dyson vacuum appears to still have suction but it doesnt
That means that the belt is stretched or worn. This causes the roller brush to not be able to turn the way its supposed to against the resistance of the carpet and therefore won't pick up well. You need to replace the belt. Here are the belts you need:
Dyson DC14 Belts
Feb 07, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
I have a very old kirby generation 3 unit that converst to a carpet shampooer. I was attemtping to shampoo the carpets but it does not seem to be picking any of the water back up out of the carpet. What...
make sure the belt on the carpet shampoo aggitator is good, (could be stretched or broken) recommend replacing that belt. also make sure your fan in the front of the machine doesnt have any chips or cracks around the center. (this will cause lower suction) a new belt should cure the problem for you.
Jan 06, 2010 | Vacuums
Vacuuming up water with Shop Vac model 84M200
when picking up dry materials use the foam sleeve that slips on and the blue cloth (assuming there all blue) over it, there should be a ring that slides over blue cloth to hold it in place over the foam sleeve, for wet pick up u can use the foam sleeve minus the blue cloth but let it dry out before picking up dry stuff, you can pick up both wet and dry with a cartrige filter that looks simular to a car air filter and it slips over the foam sleeve, but let it dry out after picking up water before picking up dry cause itll just clog it up
Oct 25, 2009 | Shop Vac 84M200 Wet/Dry Vacuum
Hoover floormate.
Can't do it. The machine vacuums in both scrub and pick-up. Sorry.
Kirk Thompson
San Juan,PR
Sep 01, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
No suction in the hose
Take the Hose out bcack run the water hose thru it full blast to unclog it then leave it hanging to dirty all the water left inside out.
Aug 20, 2008 | Bissell 6594 PowerForce Bagless Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
235 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
