Question about Samsung S860 Digital Camera
Camera has stopped working without any explanation
Our Samsung was purchased October 29, 2008. I have a copy of the sales receipt from Circuit City. The camera has shut down. New batteries do not revive it. I think it is within the warranty and request your address for the purpose of sending this one back to you and obtaining cash or a new camera. Thank you.
Regards,
Joe Davidson
Virginia Transformer Corp.
(C) 276-358-0298
(W) 540-345-9892 X157
joe_davidson@vatransformer.com
SOURCE: displays "low battery" always
I had exactly this problem and found the solution - I was using the wrong type of batteries.
You might be doing the same so what you need to do is check to see what mAh the batteries you're using. I was using Energizer rechargables with 1300mAh when the camera stopped working and switched to 2500mAh rechargables (on the advice of a friend) as a last desperate attempt to get it to work and it solved my problem. I got 2500mAh Energizer rechargables and would advise the same but you should go for batteries with at least 2100mAh.
I hope this helps some people :)
Posted on Jun 12, 2008
  • 225 Answers
SOURCE: camera wont stay turned on
If it still takes good pictures, do not worry about it. It could just be a startup test. If you cannot use your camera now, maybe you have a lens jam. Jams need to be fixed by pros.
Posted on Nov 13, 2008
cpt100
  • 154 Answers
SOURCE: Samsung i70 problem
Yes, we had few situation with different digital cameras and professinal camcorders damaged in I/O port board due to power surge type damage. It is rare but depending on design of circuitry combination with laptop system. Due to the current present on usb port it is important to turn the camera off before unplugging the camera or any electronic devices. Remedy for the damage requires repair by technician. -James
Posted on Mar 30, 2009
  • 70 Answers
SOURCE: Camera shows low Battery and goes off even if u insert a new one
are you using NiMh rechargeable batteries?
If yes, check that they are fully charged. If that doesn't do the trick, sounds like it might be a power circuit issue. Samsung is in Secaucus, NJ
or SamsungUSA on the web
Posted on Apr 15, 2009
  • 11967 Answers
SOURCE: Samsung L313 camera - lense is not retracting when off &...
You could return it (recommended) or try these: Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 07, 2010
Want to upgrade to windows 7 plain home
Windows 7 sales (except Pro) stopped almost two years ago. You may be able to find discs on the second hand market but not from Microsoft or a registered dealer. You can still get Win 7 Pro.
Support lifecycle
Microsoft ended the sale of new retail copies of Windows 7 in October 2014, and the sale of new OEM licenses for Windows 7 Home Basic, Home Premium, and Ultimate ended on October 31, 2014. Professional currently remains available to OEMs, primarily as part of downgrade rights for Windows 8 licenses. OEM sales of PCs with Windows 7 Professional preinstalled will end on October 31, 2016.[96] The sale of non-Professional OEM licences was stopped on October 31, 2014.[97]Mainstream support for 7 ended on January 13, 2015. Extended support will end on January 14, 2020
Apr 01, 2016 | Computers & Internet
Model Pan TH50PX75U Purchased May 18, 2007 at Circuit City,Sore 443. Problem: I do hear "high voltage spark sound" from the unit. A few weeks ago, the spark sound was somewhat weak, but since...
Hi
Your Unit is in high voltage short circuit Spark Gap! i can fix this trouble! sir do you have experience in electronic repairing? or are you a technician!?
Thanks!!!
May 05, 2008 | Televison & Video
I have paid for an extended warranty on my double oven but cannot find the papers. Who would I call to get this information and speak about service? Thank you, Arden Teplow
wherever you purchased the extended warranty should keep records and the sale person at that store regardless if it was your salesman should be able to assist you with this... i work for home depot,lowes, circuit city,best buy and lg electronic extended warranties all the time... hopefully they registered you in the system and they can help.... if you have the receipt proving you purchased the extended warranty would make it alot easier go to the store and ask for help.... hope this helps you out please vote......
Jan 03, 2011 | Jenn-Air Ovens
Purchased tv from circuit city when going out of business was told warranty would begin on date of purchase from manufacturer. 30 days later tv went black. manufacturer says they don't warranty product...
Your warranty should very well be honored and yes, the warranty does start right when you leave the store as long as you have the original receipt, otherwise, they might just honor the production date via serial number. If you have the original receipt, then you need to tell them this and speak to someone higher up, like a manager. It is not your fault Circuit City went out of business.
Apr 04, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
Onkyo TX-SR806 7.1 Channels Receiver I bought a reciver just 4 days back. It worked fine for 2 days and yesterday when i tried to increase the volume, it shut off. I tried troubleshooting to see if there...
If you have disconnected all connections from the receiver including your sources and the unit shuts down and goes in protect then there is an internal shortcircuit on the receiver and you would need to send that to an authorized service center. Now, since you just bought it 4 days ago, if you purchased it from an authorized dealer of Onkyo you could have it replaced since its way within the 30 day return policy. But, if you have purchased it from circuit city, unfortunately your option would only be the service center for repairs. If you send it to an authorized service center, you would need to put in a copy of your sales receipt together with a brief description of the issue you are encountering. Where did you purchase your 806?
Mar 03, 2009 | Onkyo TX-SR604 Receiver
Cannon Powershot A720 IS, wont turn on.
Where do you live? Look up Canon on your computer and find out where they are located. The nearest one to you.
Jun 09, 2017 | Canon PowerShot A720 IS Digital Camera
Broken Leap Frog Leapster Learning Game System
I purchased a Leapfrog Leapster in end of June sales last year for my daughter's birthday in October 2008. When she first turned it on it froze but after restarting played fine for 2 hrs then died and refused to work again. Fortunately I had kept my receipt (Target) but was still worried about it having been 4 months prior. They ended up giving me a store credit as they no more in stock at that store and I picked one up from another Target without having to pay the difference between my original sale price. I know you don't have the receipt but you could contact the place of purchase and ask them even if they are able to send off for repairs or put you in contact with the right people. Hope it helps a little ...
Nov 16, 2008 | Toys
In Nov 2007 I purchased a computer (HP-a6200n-Serial No.:CNX74301SY) from Circuit City. This computer was equipped with a Lexmark 2500 Series printer. I received an adequate amount of documentation with...
Hopefully you kept copies of the rebate and receipt in case you have to prove it. I would contact the folks where I sent the rebate to. If you get no resolution this way, see if Circuit City would take care of you. I had this happen with a store online, and they gave me part of my rebate back and store credit and it wasn't even their screw up, and this was a year later. I would also Google and see if anyone else has had this issue on this deal.
Sep 28, 2008 | Computers & Internet
Warranty
I believe you might be able to get a copy of the receipt if you payed with credit card. I know you can do this at Circuit City. If you purchased one of their protection plans. If you read the pamphlet that they give you when you purchase the plan, it states at the bottom that user must retain this certificate and receipt for proof of purchase. Thats how they make their money in the hopes you will lose your stuff and never use it. Thats why I like circuit city they keep that sort of thing on file. You can still give it a try as I would.
Here is the their number for questions regarding this 1-888-237-8289.
Good luck hope this was some help,
Lee
Jun 15, 2008 | Dell GX270 P4 256/40/48X/XPP/NONE...
Shattered?
heres what I did,
called samsung, they told me to go here https://www.samsungcamerausa.com/cs/
and fill out a repair request, I did that.
They also said it has to be under the 1 year warranty, and they need proof of that, so I went to circuit city and gave them the charge card I paid for it with and they printed out the receipt.
I sent it via UPS and I got it back in a month or so
Nov 05, 2007 | Samsung NV3 Digital Camera
Samsung S860 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
