Question about RCA DISH Network(r) 311 Satellite System
Can't get the 110 satellite to lock even though I have a 71 on
Using a dp1000 satellite a friend gave me. Tested switch and satellite out at home and picked up 110, 119 118 and 129. At camp can only get the 119 and 129 even though 110 has a strong signal it won't lock. Need 110 for locals
  • 374 Answers
SOURCE: have dish receiver 510, channels i need are on
Donna,
I am sorry to hear of your troubles. I am assuming you have another receiver in the house that is an HD receiver as the 510 is not and it would not make any sense for you to have the 129 orbital without it. If you go to the other receiver and are able to get transponder 21 on the 129 bird then the issue lies in either the cabling, connectors, barrels and or wall plate, or the 510 itself. Assuming you were good to go with the hi def receiver move it to the 510 location and see if you are able to still p/u the 21 transponder. If so, the 510 is bad and needs to be replaced. If not the problem lies in the aforementioned areas. if yoou are unable to get the 21 transponder on the hi def receiver also then more than likely the dish needs to be repeaked. If I can be of more assistance let me know. Thanks for using Fix Ya.
Posted on Feb 23, 2009
SOURCE: I have a dish network 211 receiver and the 1000.2
Hi! I will be more than glad to assist you in this concern. Lets check your cable connection first if all is connected hand tight on the back of the receiver, check the sat in connection. once your done, press the menu button on the remote, that is located on the upper left of the remote, once you have the main menu, press 6,1,1 on the remote on it will go to point dish, select check switch on the point dish screen, that is on the upper right of the screen, once you select check switch, it will go to the installation summary, you will see port1-119-ok-1k.2, port2-ok-1k.2 port3-con-1k.2, select test on the butom of the screen, it will run a test up to 3 or 4, it depends on the status of the lnbf, once its done, it will show the whole screen of installation summary, port1-119-ok-1k.2, port2-110-ok-1k.2, port3-129-ok-1k.2, once you see these, the problem is fix and you need to select done and it will go back to the point dish, select done, it will show you an option on the screen, then press 0, 3 times on the remote to exist all the way out, it will go to a pic or it will show attention 015, let the progress fiish and let the programming download finish as well. that will fix the problem, just incase still no 129, please unplug the power of the box from the power outlet for 1minute, plug in then you will see attention 015, press the menu button again from the remote, once you see main menu, press on the remote, 6, 1, 3, check on the field g, 119-green, 110-green, 129-green, if you got 129-green, that fix the problem, in case there is no 129, please call 1-800-333-3474, call the tech support of dish network, ask for a service call and inform them that what you did, sometimes they will ask some information, just answer the question, that is only to verify the steps that you did, If 129 sat orbital location is needed on your programming bcoz you have an hd program or your local package broadcast on 129 sat orbital location, they will setup a service call but if the sat 129 is not needed on your programming they will inform you that you dont have to worry about it. granting its needed, they will setup a service call. if you have the extended warranty plan, the service call is $29 but if you dont have, the fee is $49, the extended warranty plan is $5.99 every month. if you have any query pls feel free to get in touch..
Posted on Sep 07, 2009
Testimonial: "Thank you for your help. I'm thinking now that I don't need the 129 satellite for my programming. Thanks again."
SOURCE: On our Dish 500 we get strong signals on both 110
Hi jmhunsinger! I will be glad to assist you in your concern. 1st let press the reset button on the front panel of the receiver for 10secs, then once its reset, you will see attention 015 this will go on a progress, then press the menu button on the remote, that is on the upper left, then you will see the main menu. once you see the main menu, press 6,1,1 on the remote and it will go to pointdish, once you see point dish, select check switch on the upper right, then it will go to install summary, on the install summary, you will see installed device, input1-110-all, input2-110-all, on the butom you will see test, select test to perform switch test, let the test finish once its done it will be back to install summary, you should see input 1-119, input2-110 and both should be all or odd-even, select cancel, then it will go to pointdish, you will see on the sat field it could be 119 or 110 and under the signal meter you will see there lock echostar, it could be 119 or 110 west, no problem if one of them will show.119 west or 110 west, then selct cancel, then press 0, 3 times on the remote then it will go to attention 015, let the progress finish until it download the programming guide, if you got the tv show, and can change the channels of the program, lets check your sat if both of them is green, press on the remote the menu button and once the mainmenu is up, press on the remote 6, 1, 3 then it will go th the sysinfo, on the field g, you should see there 119-green, 110-green, if there are two green your good to go, but if there is only 1 sat, press cancel then select on the option updates, once your on the updates screen, you should select on with out my permission, then select save, and cancel all the way out, then it will show a tv pic..turn off the receiver by pressing the power button on the remote, then once the power is off, green light on the receiver if off and the tv will show a snowy or black screen, but in a few seconds it should show attention 061, downloading vital program information, this process will update the software of your receiver, let the process finish, dont do anything just sit and relax and wait until it finish, once its done the wtv will be on a black or snowy screen and the message will disappear. press and hold the power button on the receiver for 10secs then it will pop attention 015 let the progress finish until it download the programming guide, once you got a tv show, press again the menu button on the remote and press 6,1,3 on the remote to check sysinfo and check field g if sat 119-green, 110-green. granting still 1 sat and its green, select cancel, select point dish, check switch and test, let it finish once its finish, it should show 2 sat, 119, 110. then cancel all the way out and it go on the process again and wait untill all the process finish. granting you did check on the sysinfo again and still show only 1 sat. if you have other solo receiver, try to hook up the other receiver to the room were your having a problem, run the check and test the switch on the pointdish. lets say that the other receiver got two sat-119 and 110, mean that the 1st receiver that you working at have a problem and it needs to be replace but if the 2nd receiver that you hook up and it shows the same problem, call on 1-800-333-3474 and ask for service tech, there is a problem with your dish 500.
note: replacing the receiver and asking for a tech- you need to call the same number-1-800-333-3474
if you have any query,pls feel free to get in touch
Posted on Sep 20, 2009
SOURCE: Hello- using dish 500 with
Hi CharlieO my name is Mike of DISH Network and I was reading over your post and seenwhere your 110 satellite is not locking in or on your install summary screen. Iwould be more than happy to help with this issue and to research further I willneed to look at the account to look what satellites they have setup on youraccount. I will need your account number or your phone number; I will leave mye-mail so you can contact me directly. Michael.houston@dishnetwork.com
Posted on Feb 15, 2011
raycalo
  • 358 Answers
SOURCE: My satellite is on 129 and 119 and I want 119 and
How many coax cables are you using from your dish, 1 or 2? Do you have a switch between the dish and receivers? I am assuming your have a 1000.2 dish since you say you have the 129, 119, 110. On the LNB you have 4 coax ports. Facing the LNB, the port on the far left is for 119, the next is 110, then 129, and that last on the far right is for an additional dish. If you want to get 119 and 110, just use the 2 ports on the left. Once connected, run your check switch. I hope this helps.
Posted on Jun 29, 2011
My friend has a toshiba satellite a25-s2792 computer. When she enters her network key to get onto my wireless network she gets the message "the network password needs to be 40 bits or 104 bits...
Have your friend find out what the encryption scheme is on the router. She will need to ensure that her computer is set to the same encryption algorithm in her network configuration.
Jun 05, 2017 | Toshiba Satellite A25-S2792 Notebook
My satellite is on 129 and 119 and I want 119 and 110. I have move skew, height , and azimith with no luck. I can always get back to 129 and 119. Does the satellite default to these numbers once check...
Jun 27, 2011 | RCA DISH Network(r) 311 Satellite System
Hello- using dish 500 with twin lnbf, 311 receiver. 119 locked in easy with 70 signal . When trying to find 110, I cannot get a strong enough signal to lock. 129 signal shows strong along bottom of point...
Jan 30, 2011 | RCA DISH Network(r) 311 Satellite System
Can't get Dish500 satellite system set-up
If you tripod or mount is perfectly plumb and you have the correct information for the settings at your current location then you may have a faulty piece of hardware ensure all connections are tight and that all bolts on the dish are tight. Once you get 119 try gently pulling on the top of the dish and see if that increases the signal stregth and gets you 110 since it is at a higher elevation than 119. let me know if this helps.
Dec 03, 2009 | DISH Network ViP 211 DTV Receiver
Garmin nuvi 705 won't power up
probably a bad piece in the hardware (power supply). these come with a 1 year warrenty. I would contact garmin and have them take a look (they will replace it most likely)
Jun 26, 2009 | GPS
Anti theft light blinks even though I'm driving.
you must have connected the battery opposite while jump starting and then reversed the polarity the correct way! now please have your immobiliser system checked and changed! and the number three junction block( with the door lock intergrated module)
Jun 18, 2009 | 2005 Honda Civic
Locked computer
even though it says locked click to open it anyway.
Apr 21, 2009 | Acer Aspire One Netbook 8.9" Notebook
Dish Network - Dish 500 Satellite 110 is not being recognized
You will need a DP or Legacy twin or quad, or DPP twin without using an external switch. If you use Legacy Duals, or DP Duals you will need a switch. USUALLY a SW21 is used to combine the signals but you may have a different one in use if at all.
The primary thing to remember when using a switch is that you must use the same type of LNB as switch e.g. Legacy switches with Legacy LNB's and Dish Pro switches with Dish Pro LNB's.
Check your LNB type. Legacy LNB's have only a Dish Network Logo on them, Dish Pro has DP on them and DPP have DP PLUS on them.
One of three things could be the cause:
1. Line of site. Must be clear of all obstructions to ensure adequate signal.
2. You have a faulty switch, or conflicting LNB and switch, or no switch at all.
3 you may have a bad port on the LNB.
As a fail safe check that your mount is level and plumb. You also may have the dish pointed directly at 119. Check the Skew and elevation settings as well. If LOS IS THE ISSUE YOU MAY NEED TO RELOCATE THE DISH OR REMOVE THE OBSTRUCTION.
In some extreme cases microwave towers and High Voltage lines also pose a problem but doubt this is the case for you.
Sep 04, 2008 | DISH Network 301 DTV Receiver
chances are that you have only lined up the dish to pick up one satellite. there are several satellites up there for dish and its easy to miss the ones that you need. try to line up the dish keeping this in mind. if that doesn't work, write back.
Apr 30, 2008 | Televison & Video
Lonnie, You have a simple problem,the 119 satellite is lower in the sky than the 119 if you make sure the pole you are mounted on is straight and plum ,then simply raise the dish a few elevation degrees and turn the dish to the left.Your dish is aimed low and to the right.
Oct 18, 2007 | RCA DISH Network(r) 311 Satellite System
Televison & Video Logo
423 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
